Some little topic on the new TI-Nspire CX CR4 hardware.
(hardware revision W+ manufactured since November 2015)
New screen, with a new buffer geometry.
The new buffer is 90° rotated making it 240x320 instead of 320x240, and mirrored.
To give you an idea, if you run on a CR4 some code which does not support the new screen it looks like this :
Therefore, TI just completely broke the compatibility with all existing Ndless programs - diabolically brilliant. :P
So either we will have to rebuild all existing Ndless programs, most authors having moved on, and for some of which the source code is not available...
Either a future CR4 Ndless could have some kind of a compatibility layer...
But even in the latter case, it would imply writing the screen buffer two times (normal writing of the original program + fix writing), and so it would have a high performance cost for programs constantly refreshing the screen (nDoom, nQuake, emulators...)- we can expect a halving of the fps if there is no CR4 update.
As a result, natural antidowngrade protection: OS / Boot2 / Diags versions 4.0.0 and earlier will not work properly.
Versions 4.0.1 or newer are mandatory.
The CR4 therefore obviously comes with a new Diags, the CR CX IV DVT (2015/06/08) Diag in Version 4.0.1.45 built on August 18 , 2015.
New boot1 as already stated, version 4.0.1.43 built on July 20, 2015.
Here the bootlog:- Boot Loader Stage 1 (4.0.1.43)Build: 2015/7/20, 14:47:25
- Copyright (c) 2006-2015 Texas Instruments Incorporated
- Using production keys
- Last boot progress: 0
- Available system memory: 28072
- Checking for NAND: NAND Flash ID: Generic 1 GBit (0xA1)
- SDRAM size: 64 MB
- Wakeup Event: ON.
- SDRAM memory test: Pass
- Clearing SDRAM...Done.
- Clocks: CPU = 156MHz AHB = 78MHz APB = 39MHz
- Boot option: Normal
- Loading from BOOT2 partition...
- 100%
- BOOT1: loading complete (168 ticks), launching <BOOT2> image.
Boot1 has a new boot combo : [doc][enter][1] allowing to reflash the Manuf partition with an RS232 sent image.
Perhaps finally a way to repair TI-Nspire CX calculators whose Manuf has been damaged.
