查看: 11102|回复: 33
[fx-9860/9750] Where‘s my “买了个9750”?
发表于 2009-10-3 10:14:54 | 显示全部楼层 |阅读模式
It was lost.I cannot find it...
发表于 2009-10-3 10:18:07 | 显示全部楼层
You can go to My Posts find!
发表于 2009-10-3 10:19:06 | 显示全部楼层
 楼主| 发表于 2009-10-3 10:48:40 | 显示全部楼层
But I cannot find it in "各类计算器讨论"...
发表于 2009-10-3 10:50:58 | 显示全部楼层
Oh,
~~Why?
 楼主| 发表于 2009-10-3 11:03:30 | 显示全部楼层
............I found it.
发表于 2009-10-3 16:57:03 | 显示全部楼层
I can't understand you !!!
 楼主| 发表于 2009-10-3 17:59:18 | 显示全部楼层
Why?
 楼主| 发表于 2009-10-3 17:59:38 | 显示全部楼层
My computer has been ill...
发表于 2009-10-3 18:00:56 | 显示全部楼层
Ai~~~
 楼主| 发表于 2009-10-3 18:07:00 | 显示全部楼层
It is wrong...Ahhhhhhhh...
发表于 2009-10-3 18:46:02 | 显示全部楼层
DEL
发表于 2009-10-3 18:46:59 | 显示全部楼层
del
发表于 2009-10-3 18:48:00 | 显示全部楼层
del
发表于 2009-10-3 18:52:26 | 显示全部楼层
sorry,I should correct it。
Can you use English?
 楼主| 发表于 2009-10-3 19:09:07 | 显示全部楼层
Yes,I can.But a little....
 楼主| 发表于 2009-10-3 19:11:33 | 显示全部楼层
疯不狂三楼“I am find”两个动词了
h19950115 发表于 2009-10-3 18:48
这句话不完全对。两个动词中间就用动词不定式,成了I am to find也不行
发表于 2009-10-3 19:14:09 | 显示全部楼层
应该是i have found it
发表于 2009-10-3 19:16:12 | 显示全部楼层
过去式也可以的!
发表于 2009-10-3 19:19:59 | 显示全部楼层
棒棒餹bbt 发表于 2009-10-3 19:11
I'm finding...
GMT+8, 2025-1-5 07:26 , Processed in 0.099074 second(s), 19 queries .
