查看: 4654|回复: 2
[Nspire] 新买的CX CAS无法充电
发表于 2012-9-21 08:40:14 | 显示全部楼层 |阅读模式
在美国买的CX-CAS.亚马逊上买的。拿回来冲了好几个小时的电,还是百分之0.主要是一点都没冲进去,拔掉电源就自动关机,再开根本开不了。。各种方法都试了,都不行。。。怎么回事呢。。
发表于 2012-9-21 12:05:36 | 显示全部楼层
你是没电又开不了机吧?请狗急跳墙登录 ndlessy.wordpress.com,在FAQ或者类似栏目中有相关说明。需进入自检后充电。英文。(目前我在用手机没法给你转过来
发表于 2012-9-22 20:15:49 | 显示全部楼层
以下引用自ExtendeD的博客ndlessly.wordpress.comThe TI-Nspire CX falls into a reboot loop and ran out of battery[size=1.167em]You then can’t open the maintenance menu as suggested above.
[size=1.167em]
[size=1.167em]Press the Reset button, and:
  • Hold the the following keys at boot time: Esc+Menu+Minus
  • This brings the diagnostics menu. Choose the option to run the battery tests.
  • Plug the TI-Nspire to a computer
  • Wait for the battery to reach a level of 30%
  • Exit the diags tool, and try to open the maintenance menu and follow the procedure above (“The TI-Nspire CX falls into a reboot loop”).
[size=1.167em]
[size=1.167em](Credits to TI-Planet.org for this procedure)
GMT+8, 2025-1-22 23:43 , Processed in 0.057498 second(s), 23 queries .
