查看: 13820|回复: 25
[Nspire] TI Nspire CAS with clickpad 64MB photos
发表于 2013-8-17 19:11:13 | 显示全部楼层 |阅读模式
Eng
the previous subject address : http://www.cncalc.org/thread-9123-1-1.html
According to critor says in 8th floor ,this time i got the photo .
the reason why i got it rather now than a week before is that my friend's father went. i didn't disturb him.
here's photos ,dont complain about the picture element
i dont know whether you can see the whole photo ,zip file with in this subject
maybe download need money ,so i offer for 10 people everybody 2 money
Chs
之前的主题地址:看上面
根据critor在8L所说我拍了几张
之所以今天拿到而不是上周是因为我同学的父亲去世了,上周我不敢打搅他。
这就是照片了,像素什么的笑笑就可以了
可能论坛会压缩图片,我不知道,因此附上压缩文件
可能花2金钱,准备10人份的
desktop.zip
1.71 MB, 下载次数: 60
 楼主| 发表于 2013-8-17 19:13:10 | 显示全部楼层
我去,org打成com不是我的错啊这个
以前在5d6d时代,我们的论坛确实有一个cncalc.com的域名  发表于 2013-8-18 07:02
发表于 2013-8-17 19:27:38 | 显示全部楼层
回帖奖励 +2 金钱
神奇的64MB版本
还有给你同学父亲默哀……
发表于 2013-8-17 19:28:39 | 显示全部楼层
回帖奖励 +2 金钱
That`s cool! @critor  and sorry to your classmate`s father.
Sorry for my english and thanks to google translate.
发表于 2013-8-17 22:04:28 | 显示全部楼层
回帖奖励 +2 金钱
Sorry to hear about your classmate's father.
Remember I said that a normal nSpire(Non-CX/CM)only has 20MB?
Maybe your nSpire is a Prototype with 64MB Memory.
But why your nSpire is able to update OS?
发表于 2013-8-17 22:06:07 | 显示全部楼层
And how did you get it back?
 楼主| 发表于 2013-8-17 22:25:51 | 显示全部楼层
I did't get it back , i just borrow it form HIM
发表于 2013-8-18 07:00:18 | 显示全部楼层
Remember I said that a normal nSpire(Non-CX/CM)only  ...
Some prototypes could also be upgraded. By the way I'm wondering if the NAND size is stored in manuf. As far as I know, nspire OS should be able to work with different NAND size, your see, nspire_emu allows you to change the NAND size.
发表于 2013-8-18 07:18:50 来自手机 | 显示全部楼层
回帖奖励 +2 金钱
楼主试试拆机吧……来张NAND照片?
还有我怀疑这是否是误测?楼主装个nPAL试试。
发表于 2013-8-18 08:52:13 | 显示全部楼层
回帖奖励 +2 金钱
Sorry to hear about your friend father. :(
Very interesting pictures.
You could try to install nPal in order to check if those 64MB are really there and usable ;)
Could we have a photo of the serial number on the back of the calculator?
If it's a prototype or development unit it'll be easy to find out and it will even give us some information.
Yes, photos of the PCB and of the NAND CHIP would be great too, but let's start by easy things. ;)
 楼主| 发表于 2013-8-18 15:06:56 | 显示全部楼层
as you see the os is 3.2 , so nPal has to wait .
please give me address of nPal .
i will give the photo next weekend .
发表于 2013-8-18 15:27:20 | 显示全部楼层
i will give th ...
As the developer of nPal, I'm sorry to say that the condition is a little bit complex.
If you want to use English version, just go ahead http://www.cncalc.org/thread-8930-1-1.html .
But if you want to use Chinese version, you should download http://www.cncalc.org/thread-8843-1-2.html  first, and then download the Beta2 binary in http://www.cncalc.org/thread-8930-1-1.html .
Installation is easy, just send the nPal folder to nspire and open sdlpal.tns.
发表于 2013-8-18 20:12:06 | 显示全部楼层
If you've got a normal Nspire, then it would mean than we can use 64MB on some normal Nspire, which would be great! ;)
 楼主| 发表于 2013-8-19 12:13:50 | 显示全部楼层
If you wan ...
just download beta2 is ok? i will have a try
发表于 2013-8-19 12:26:51 | 显示全部楼层
Beta2 doesn't include game resource file.
Just download Beta1 is OK.
发表于 2013-8-21 06:26:54 | 显示全部楼层
I have released nPal V1 Final.You can download it at
http://www.cncalc.org/thread-9273-1-1.html
Everything you need is included.
 楼主| 发表于 2013-8-21 12:10:27 | 显示全部楼层
黑白机能装,周末回家上图
发表于 2013-8-21 16:32:55 | 显示全部楼层
回帖奖励 +2 金钱
{:049:}{:044:}Sorry, but you have made too many mistakes in the topic, for example, you should say 'passed away' instead of 'went', 'download need' ought to be 'downloading needs', 'so i offer for 10 people everybody 2 money' is supposed to be 'so I will offer each of the following 10 people for 2 coins', and so on.
I wish all of our forum members to speak English more correctly.{:001:}{:tongue:}
感谢金币{:grin:}
参与人数 1金钱 +2 收起 理由
_14522 + 2 you need
 楼主| 发表于 2013-8-24 17:31:26 | 显示全部楼层
yzskyt 发表于 2013-8-21 16:32
Sorry, but you have made too many mistakes in the topic, for example, you should say ' ...
I dont think my friend's father's death is a discussion
if you want money i can give you more
发表于 2013-8-24 18:29:36 | 显示全部楼层
Could you get us a photo of the full serial on the back?
I only know about TI-Nspire CAS ClickPad prototypes DVT1.2 and DVT2.0.
It seems to be something else here ;)
GMT+8, 2025-2-2 05:59 , Processed in 0.063007 second(s), 22 queries .
