查看: 6664|回复: 19
[Nspire] Ndless 3.6 is here
发表于 2014-3-16 05:24:18 | 显示全部楼层 |阅读模式
Hi, I copy/pasted this news from TI-Planet, to let you know ;)
This weekend, we celebrate the return of Ndless on the TI-Nspire, with finally a version compatible with OS 3.6!
There is no longer any need to try to downgrade now, since Ndless 3.6 runs on the latest TI-Nspire OS to date : 3.6.0.546 as well as 3.6.0.550.
Ndless 3.1, read this too: https://tiplanet.org/forum/viewtopic.php?f=17&t=14085
nLaunchy users, read this too: http://tiplanet.org/forum/viewtopic.php?f=43&t=14084
The installation process is different from that of Ndless 3.1, since the exploits used are obviously different.
Installation tutorial : http://tiplanet.org/ndless/
In short, you will need to:
  • from the computer, send the files 'ndless_installer.tns' and 'ndless_ressources_36.tns' into a 'ndless' folder at the user-accessible root level of the calculator (directly in 'My Documents').
  • on the calculator, open the file 'ndless_installer.tns' and press:
Note that unlike Ndless 3.1, Ndless 3.6 is disabled by any restart of the calculator.
But in return, once you've transfered those files to your calculator, you will no longer need a computer to install it again - you can only just repeat the last step above
The Ndless 3.1 programs that do not contain hardcoded routines address in their code, which is most, will work seamlessly on Ndless 3.6 without modification.
This is particularly the case of nDoom and Nintendo emulators, among others.
Some other Ndless 3.1 programs (rarer or not) have been updated for compatibility with Ndless 3.6 and now work interchangeably with both versions
polydumper 4.0
(critor)
nsNandMgr 2.0
(critor)
mViewer CX 4.3
(critor)
Extract needed files to emulate your TI-Nspire
Swiss-knife for the Flash-NAND of the TI-Nspire
Image reader for
PNG, JPG, GIF
nClock
(Levak)
nProtect
(Excale)
Display time and much more
Protect you Nspire filesystem from unwanted visits
Some programs aren't "appropriate" anymore on OS 3.6, so they've been updated to simply "not do anything" if 3.6 is detected, so that costly mistakes are avoided.
nTNOC
(critor)
nPatch
(critor)
Supprime des fichiers inutiles pour gagner de la mémoireCorrige un bug au niveau de la taille de l'OS avec Ndless
Other rarer and / or minor Ndless 3.1 programs have unfortunately not (yet) been updated by their author with Ndless 3.6 compatibility, so you need to avoid them so far :
  • nHide (Excale)
  • RootDoc (Excale)
  • TNS2XML (Excale)
  • ThemeEditor (Levak)
  • NavDiags (Levak)
  • FixPrint (Levak)
  • cx2cxc (Levak)
  • Deldico (Levak)
  • vpatch (Levak)
Ndless 3.6 : archives_voir.php?id=35304
Official website : http://ndless.me
Thanks Extended (and others) - Enjoy :)
Source : http://tiplanet.org/forum/viewtopic.php?f=43&t=14086
参与人数 3金钱 +6 收起 理由
HHX-XXM + 2 Great
yzskyt + 2 Great.
549597890 + 2 fabulous~
发表于 2014-3-16 08:11:58 来自手机 | 显示全部楼层
crazy,good news
发表于 2014-3-16 08:23:15 | 显示全部楼层
mark!!
发表于 2014-3-16 08:49:25 来自手机 | 显示全部楼层
It's rather an important contribution to TI community!
发表于 2014-3-16 08:57:08 | 显示全部楼层
That's awesome!
发表于 2014-3-16 09:29:46 | 显示全部楼层
ohhhhhhhhhhhhhhhh you are Handsome guy. i love you!!!!!!!!!!
发表于 2014-3-16 10:12:37 | 显示全部楼层
some users have mentioned about that there is something wrong with their Nintendo emulators on os 3.6 with ndless 3.6.
Their nspires  cannot launch Nintendo emulators.@critor
发表于 2014-3-16 10:37:20 | 显示全部楼层
Oh!That is great work
发表于 2014-3-16 12:28:39 | 显示全部楼层
it's amazing!
发表于 2014-3-16 12:33:48 来自手机 | 显示全部楼层
Wow!
发表于 2014-3-16 12:56:55 来自手机 | 显示全部楼层
Great!
发表于 2014-3-16 15:35:55 | 显示全部楼层
thats good
发表于 2014-3-16 16:05:02 | 显示全部楼层
549597890 发表于 2014-3-16 10:12
some users have mentioned about that there is something wrong with their Nintendo emulators on os 3. ...
Yes ?
Do you have some source about this ?
And which Nintendo emulator?
GBC? GBA? Famicom/NES?
发表于 2014-3-16 16:41:26 | 显示全部楼层
critor 发表于 2014-3-16 16:05
Yes ?
sorry for bothering you ~~
someone ask for the situation thus i asked you.
It turned out  that those guys forget to send a bios file in their nspire{:blink:}
发表于 2014-3-16 17:55:03 | 显示全部楼层
"ndless3.6" looks not the same as any old version...so i suspected that it was not ndless...
(It is my private persuasion that it was a "friendly to ndless program" platform)[{:041:}]
so...why not set up a new name for this platform?
If my opinion is incorrect,please point it out...
发表于 2014-3-16 19:06:11 来自手机 | 显示全部楼层
(It is ...
ndless从很早的版本到现在,每一个版本的安装方式都很不同……
发表于 2014-3-16 19:22:02 | 显示全部楼层
Ah, that's the GBA emulator.
Ok, thank you :)
发表于 2014-3-16 21:08:16 来自手机 | 显示全部楼层
因为利用不同的bug。。这次听说是用lua的bug做的
发表于 2014-3-16 21:17:03 来自手机 | 显示全部楼层
Ok, thank you :)
gba not run,but gbc run very smoothly-_-|||When you run gba emulator, press the enter key will restart the calculator, and  ndless will quit.
发表于 2014-3-16 23:39:46 | 显示全部楼层
Sorry, GBA emulator did run correctly when I did test it some days ago, and I've had several reports today that it was still running correctly.
Try again with another ROM  or BIOS ?
GMT+8, 2025-1-23 10:33 , Processed in 0.113186 second(s), 22 queries .
