查看: 7778|回复: 8
[fx-9860/9750] 新9860GII OS 求人测试
发表于 2014-3-20 13:26:27 | 显示全部楼层 |阅读模式
更新:
TeamFX要的是OS 2.02而不是2.01 。。。我觉得应该是没有的 如果有人买了最新的GIISD 请来说说你的系统版本号
What I would need is a dump from an fx-9860GII SD, USB Power Graphic 2, with OS 2.02 or higher
---下面是以前的内容---
刚看到TeamFX(他也是国外一大神)在我们论坛上询问新版9860 OS的问题。
问题就是http://www.casio.com.cn/cal/graphic/fx-9860GII%20SD/index.html 这里面提到了9860GII的功能里有语法提示和eACT guide。
虽然我比较怀疑是CASIO中国做网页的时候搞错了,图可能是slim的(因为从图中看GII的键盘上没有多出一个help功能,而且这个页面里还有旧版GSD的图)。但是也不排除GII版终于加进了内置help这个功能。
我手头只有SLIM 没办法测试新系统,求有9860GII(或GIISD)的朋友测试一下
这里是新版os(OS 2.01)下载链接(含9860GII和9860G)
http://pan.baidu.com/s/1c0gS7DI
如果真的多了语法提示,TeamFX要求把OS用fxRemote这个工具(网盘里已提供)dump下来给他。
http://www.cncalc.org/forum.php? ... =137860&fromuid=438
求验证~
P.S.新的OS升级程序可见CASIO吃一堑长一智,已经把updatebin文件整合在一个dll里了。。。不过相信这是难不倒大神们的XD
P.P.S.论坛里一直有无名朋友持之以恒地举报我的网盘……到现在我还是没办法把大部分CASIO的资源放到百度盘上。我还是想声明一下这些东西都是可以在CASIO官网上免费下载的……朋友有什么问题请来找我聊……
发表于 2015-2-2 06:42:45 | 显示全部楼层
deleted
发表于 2014-3-20 22:03:34 来自手机 | 显示全部楼层
语法提示是啥。。
发表于 2014-3-20 23:03:32 | 显示全部楼层
deleted
发表于 2014-3-20 23:25:41 | 显示全部楼层
deleted
 楼主| 发表于 2014-3-21 10:42:12 | 显示全部楼层
TeamFX 发表于 2014-3-20 23:03
What I would need is a dump from an fx-9860GII SD, USB Power Graphic 2, with OS 2.02 or higher.
On  ...
I don't think there is an OS 2.02 , because both Chinese version and English version of edu.casio.com just provide the OS 2.01. And it seems the new GII page in CASIO China has been there for a long time.
I don't know if this can prove something:
I downloaded the picture which shows the Syntax Help function and it was edited by Photoshop CS3.
While the picture of New GII was edited by Photoshop CS6.
I think the picture of Syntax Help was a mistake of CASIO China and actually comes from 9860G Slim...LOL
真相大白!  发表于 2014-3-21 10:48
发表于 2014-3-21 23:06:49 | 显示全部楼层
deleted
发表于 2014-12-14 18:16:58 | 显示全部楼层
系统真不知道那个号
GMT+8, 2025-1-31 01:22 , Processed in 0.064483 second(s), 21 queries .
