查看: 4405|回复: 6
[89/92/V200] voyage200 nspire cp功能对照+合影
发表于 2014-4-22 21:47:48 | 显示全部楼层 |阅读模式
图在
文字选自wiki
Voyage 200 vs. TI-Nspire CAS[edit]
This section contains a pro and con list. Please help improve it by integrating both sides into a moreneutral presentation. (July 2011)
TI-Nspire CAS has some advantages over the Voyage 200 or TI-89:
  • Larger and higher resolution screen, color LCD in the CX models, compared to the Voyage, making graphs more detailed, especially in 3D.
  • The Nspire user interface has more similarities to traditional PC interfaces, for example: To copy, press Ctrl+C, like in a computer. This simplifies the learning curve for some users. The V200 also works like this.
  • Students create and save all of their work as documents with notes, thus enabling teachers to see problem-solving techniques and assess individual student understanding. These documents can be sent to other handhelds, or to a PC, where they can be edited or printed using the Nspire software.
  • Symbolic mathematics templates on the input as well as output, or "PrettyPrint" - the ability to show the results as they would normally be written. The Voyage 200 and TI-89 did this to output, while input remained standard.
  • More powerful compared to the Voyage 200. The Nspire can handle bigger matrices, a broader selection of equations and functions, all more quickly, since the processor is more powerful and more RAM is available.
  • Space – the new CX models have up to 100 MB of user memory and the grayscale Nspires had about 20 MB of user memory, compared to the TI-89 Titanium and Voyage 200's 188 KB RAM and 2.7 MB Flash ROM.
  • Graphing has been updated, giving users the option to derive or integrate a function in-graph.
  • There is a spreadsheet function which is similar to a list editor. Data from spreadsheets and lists can be analyzed and graphed.
  • Data and statistics functions have been improved.
  • It is possible to view several pages of data at once, effectively splitting the screen between each page. The user can interact with any portion at a time.
  • The newer versions of the Nspire OS are capable of opening files that contain images.
  • The Nspire has a new Vernier DataQuest function which can be used to collect data from any sensors connected to the Lab Cradle, which allows up to 5 sensors, or one sensor probe can be connected via USB port on top of the handheld.
However, there are some things that the TI-Nspire lacks when compared to the Voyage 200 and TI-89:
  • The V200 and TI-89 can solve many algebraic equations, and data input on the TI-89 can be easier for the user than the Nspire.
  • All versions of the V200 OS can graph in 3D while this was introduced in an OS update for the Nspire.
  • The TI-89 and V200 have better programming capabilities – their built-in language has more I/O and graphics commands, and they also support native assembly programming. The Nspire only has C and assembly support through the jailbreaking program Ndless.
  • Third-party apps using native code (like ME*Pro and the Symbolic Math Guide (SMG)) are not available on the TI-Nspire, but newer versions of the OS can run Lua scripts.
  • The Voyage features a full QWERTY keyboard, which makes programming and other text input easier for the user. However, some tests do not allow calculators with a QWERTY keyboard.[2][18]
发表于 2014-4-22 22:00:34 | 显示全部楼层
口水ing
恍惚加一起够新的CX。不过一个CX也有这么多~  发表于 2014-4-22 22:26
发表于 2014-4-22 22:15:13 | 显示全部楼层
酷睿i7好评
谢谢!可惜1代移动款  发表于 2014-4-22 22:27
发表于 2014-4-22 22:47:19 | 显示全部楼层
壕无人性
人性不可泯灭  发表于 2014-4-22 23:51
发表于 2014-4-23 10:11:24 | 显示全部楼层
{:014:}赞一个!
发表于 2014-4-23 11:52:23 | 显示全部楼层
那个ti92机子,应该比日本人搞的那些basic语言计算器强多了。
当然强的多得多。moto 68k,190k的可用ram,1兆以上的可用rom 可惜体积微大。按键手感不舒服。没有官方机上C支持,第三方的ide界面太惨。  发表于 2014-4-23 12:04
 楼主| 发表于 2014-4-23 16:34:20 | 显示全部楼层
更新英文功能对比
GMT+8, 2025-1-23 10:43 , Processed in 0.047268 second(s), 22 queries .
