查看: 4014|回复: 8
[Nspire] 【ns新发现】安装sd卡的可能
发表于 2014-4-25 23:29:58 | 显示全部楼层 |阅读模式
今天进自检时偶然发现的
sd mmc
sd mmc
参与人数 1金钱 +3 收起 理由
549597890 + 3 看见过
 楼主| 发表于 2014-4-26 00:18:54 | 显示全部楼层
不过具体怎么用呢
发表于 2014-4-26 00:50:33 来自手机 | 显示全部楼层
这都让你发现了
发表于 2014-4-26 05:15:58 | 显示全部楼层
Yes, the diagnostic software is mentionning SD/MMC memory cards in various strings.
And oldest TI-Nspire ClickPad 1.x diagnostic versions even have some code to deal with them.
But of course, there is no SD/MMC reader in the TI-Nspire.
It *might*, and note I insist on the 'might', be possible to connect one through the J04/Dock connector.
Or it might just be some old code TI hasn't removed, code which was used when the TI-Nspire handhelds were still development boards.
Have a look at this early 2007 TI-Nspire ClickPad development board.
You'll be able to spot a SD/MMC reader. ;)
发表于 2014-4-26 09:16:05 | 显示全部楼层
回帖奖励 +10 金钱
And oldest TI-N ...
Amazing!Can it work on the development boards?
发表于 2014-4-26 12:23:44 | 显示全部楼层
感觉没有必要。。现在把128m装满。打开我的文档要等十多秒。。。再弄个卡。。。
发表于 2014-4-26 19:11:49 | 显示全部楼层
According to code and strings present in the oldest 1.1.xxxx diagnostic softwares, the SD/MMC reader was working and could be used to reflash the NOR chip (Boot1) and NAND chip.
The newer TI-Nspire CX diagnostic software still looks for an SD card when you trigger the "test image" test for example:
great!  发表于 2014-4-26 21:36
发表于 2014-4-26 21:06:04 | 显示全部楼层
怎么进自检?
发表于 2014-4-27 00:04:58 | 显示全部楼层
The Diagnostic software is triggered by holding the following keys while resetting the calculator:
  • TouchPad keypad: ns_es.jpg
  • ClickPad keypad: ns_es.jpg
GMT+8, 2025-1-23 10:26 , Processed in 0.069215 second(s), 22 queries .
