查看: 11072|回复: 16
HP Prime 新固件即将发布,支持双指缩放
发表于 2014-5-8 02:22:53 | 显示全部楼层 |阅读模式
根据HP Prime的Facebook页面,Prime固件一个新的大更新即将(预计5月底)发布
下面是预告全文
Here's a shortlist of the upcoming changes in the new HP Prime firmware. We have listened to you as users and have adapted some of the changes you've mentioned. Also, a lot of bugs in the previous edition were solved.
Thank you for your ongoing support and 'critisism', we do value this!
New Functionality (Connectivity Kit)
1. Application has had major improvements to the user interface. Please refer to the included connectivity kit users guide for instructions and details.
2. Support for the HP Wireless Classroom network has been introduced. Please see http://www.hp-prime.com/ for details on the Wireless Classroom kit.
3. Greatly enhanced communication speed over USB link to calculator.
New Functionality (Calculator Software)
1. Improved touch support throughout system. This includes pinch to zoom support in graphing applications, and kinetic scrolling.
2. Pressing HELP in an open command line will attempt to find the name of the command prior to the cursor position to display system help for that command.
3. Includes revision 2 of the on calculator help files.
4. Greatly enhanced robustness and capability of statistics 2 variable logistic fit.
5. Wireless support for capable units turned on. Wireless icon will appear in the right top corner menu.
6. Calculator Unit-to-Unit communications has now been enabled on units that can support it.
7. Numerical values now can be displayed with digit groupings. Examples include: 1,234.567 1 234.567 and 1’234,567
8. Two new numerical display formats introduced.
9. Vectors are now displayed as a single line object until they become a matrix. This aids distinguishing vector and matrices apart further.
10. User selectable first day of week setting for use through the system.
11. First boot unlock and settings wizard. User will be asked to confirm language selection and some initial settings.
12. Inference application now can do Chi^2 calculations and Linear Regression T calculations.
13. Geometry application has been completely redone and is much faster, consistent, and capable then before.
14. Enhanced color pickers allowing a greater range of color selection.
15. Pressing ENTER will now open chooser in a dialog, or toggle checkbox.
16. Enhanced unit object display to ensure a more standard form with complex units.
17. TRIANGLE, FILLPOLY and LINE commands can now draw multiple objects in a consistent way with each other. Useful for very complicated 3D drawing in user programs.
18. INPUT command can now create multiple page dialogs and contain choose boxes, check boxes and grouped check boxes. It can also allow specific item types and gives control of parsing behavior for input. It also supports size and position control.
New Functionality (Virtual Calculator)
1. A horizontal skin has been included for use with monitors that are restricted in the vertical pixel range.
 楼主| 发表于 2014-5-30 05:06:10 | 显示全部楼层
固件今天已经发布,可以到如下地址下载。
ftp://ftp.hp.com/pub/calculators/Prime/
 楼主| 发表于 2014-5-8 04:30:53 | 显示全部楼层
以下是本人的渣翻译
新功能 (连接套件)
1. 应用程序用户界面有重大改进,具体请参考连接套件的用户指南。
2. 引入了对HP教室无线网套件的支持,具体请点链接http://www.hp-prime.com/
3. 大程度增强了USB链接的通信速度
新功能(计算器软件)
1. 改进了系统对触摸的支持,包括在绘图应用中的双指缩放,以及页面滚动功能。
2. 当在命令行被打开的情况下按下HELP键将会尝试去优先搜寻命令的名字,并在光标位置显示该命令的系统帮助。
3. 包括了第二版计算器帮助文件
4. 极大的增强了稳定性和双变量统计逻辑拟合的能力
5. 当支持的无线单元被打开的时候,右上角菜单会出线无线的图标。
6. 计算器现在已经支持点对点通信,只要双方都支持这个功能
7. 数值显示将支持数字归组,比如1,234.567 1 234.567 和 1’234,567
8. 引入了两种新的数值显示格式
9. 矢量在变成矩阵之前将以单行显示。这将有助于区分矢量和矩阵。
10. 用户可以通过系统设定一周的开始日
11. 在第一次启动解锁和设置向导的时候,用户将会被要求确认语言和一些其它初始选项的设置。
12. "推理"这个应用程序现在可以做卡方计算以及线性回归T计算。
13. "几何"这个应用程序被完全重做了,比以前要更快,更一致,更强大。
14. 增强了颜色选取功能,现在可以选择更多种颜色。
15. 按下ENTER键讲打开一个选择的对话框,或者勾选/清空复选框
16. 增强了单位对象的显示,确保了复杂单位的标准格式。
17. TRIANGLE, FILLPOLY 和 LINE 命令现在可以画多个一致的物件
18. INPUT 命令现在可以创建多页对话框以及选择框,复选框和复选框组。还可以容许特定的组件类型,用于输入行为分析的控件。还将支持控件的大小和位置。
新功能 (模拟器)
1. 增加了一个新的纵向的皮肤,用于一些纵向分辨率不足的显示器。
发表于 2014-5-8 10:21:51 | 显示全部楼层
我在http://h30499.www3.hp.com/t5/Calculators/Firmware-for-HP-PRIME-GRAPHING-CALCULATOR/td-p/6225935#.U2rauvmSwp1下了一个,不知道是不是。
 楼主| 发表于 2014-5-8 16:50:20 | 显示全部楼层
zhj6408 发表于 2014-5-8 10:21
我在http://h30499.www3.hp.com/t5/Calculators/Firmware-for-HP-PRIME-GRAPHING-CALCULATOR/td-p/6225935# ...
不是,你这个是去年的
发表于 2014-5-8 22:57:30 | 显示全部楼层
prime用户终于迎来多点触控了
发表于 2014-5-11 17:12:14 | 显示全部楼层
这个似乎现在就有
发表于 2014-5-18 15:19:10 | 显示全部楼层
自己能刷机吗?听说不行
可以  发表于 2014-5-18 15:27
可以  发表于 2014-5-18 15:26
发表于 2014-5-30 17:47:38 | 显示全部楼层
kopkop 发表于 2014-5-30 05:06
固件今天已经发布,可以到如下地址下载。
怎么更新?
 楼主| 发表于 2014-5-30 18:15:16 | 显示全部楼层
tojohideki 发表于 2014-5-30 17:47
怎么更新?
教程在这里
http://www.educalc.net/2336439.page
发表于 2014-5-30 20:23:57 | 显示全部楼层
kopkop 发表于 2014-5-30 18:15
教程在这里
里面没有usbtool.exe,如果自己改文件路径升级时会卡住
 楼主| 发表于 2014-5-30 21:37:01 | 显示全部楼层
我手头没有Prime,下面这个网站是HP官方推出的,选择Downloads页面可以下载到最新的固件和connectivity kit
http://hp-prime.com/
升级方法有wiki,不过是德文版的,可以用Google Translate 或者Chrome浏览器自动翻译成英文后对应操纵。
http://wiki.hp-prime.de/index.php?title=Firmware
发表于 2014-5-31 09:46:00 | 显示全部楼层
按楼主指示,已升级,比老版本的确强多。谢谢楼主提醒。
发表于 2014-5-31 21:28:34 | 显示全部楼层
下载相关文件解压后,用新文件覆盖usbtool.exe所在文件夹中的文件,再升级即可。
发表于 2014-5-31 22:37:15 | 显示全部楼层
还是不行,刷完之后无法开机,只能进recovery,显示CodeEntry:0x0
HP Prime recovery mode V13
发表于 2014-6-1 02:40:37 | 显示全部楼层
要打开connectivity kit,计算机显示已经安装驱动,再将HP prime设置为刷机状态(捅prime后面的复位孔不要松手,按面板上symb键)显示 HP Prime recovery mode V13后,再对usbboot.exe进行相关操作。不用设置路径,我已经成功了。
发表于 2014-6-2 14:10:07 来自手机 | 显示全部楼层
新的系统矩阵没法正常使用了
GMT+8, 2025-1-22 17:42 , Processed in 0.073742 second(s), 21 queries .
