查看: 10108|回复: 19
[Nspire] OS TI-Nspire 3.9 available on TI servers
发表于 2014-5-30 03:45:33 | 显示全部楼层 |阅读模式
Planned to be realesed on June 4th, it is finally tonight that the TI-Nspire OS 3.9 files have been uploaded on the TI servers, although they are not linked from their web pages for now.
The full version number is 3.9.0.461 and it was built on May 16, 2014.
As already announced, once installed it forbids you to go back to any older version, setting the minimum version accepted by the calculator to 3.9.0.455.
If you install this OS on your TI-Nspire CX with hardware revision J or later, you definetely give up on Ndless 3.6.
On the other TI-Nspire calculators, it is theoretically possible to go back, but only through the use of specific hardware tools you probably don't have on hand, in order to reflash an Nlaunchy compatible Boot2.
Apart from that, the increase in size is negligible, the OS having apparently grown up from the previous version by just over 10KB.
Included Boot2 images are still version 3.2.4.7 for the TI-Nspire CX and 3.0.1.131 for the TI-Nspire monochrome, and the TI-84 ROM for the TI-Nspire non-CAS remains version 2.56MP.
Overall, this seems to be a minor update in user features, but a major update from another point of view with a radical stop to Ndless 3.6 which had just been born.
Downloads :
Source : http://tiplanet.org/forum/viewtopic.php?p=163953&lang=en
参与人数 1金钱 +3 收起 理由
549597890 + 3 ×××news
发表于 2014-5-30 16:26:16 | 显示全部楼层
额,可以翻译一下吗?看不懂
楼主是来自tiplanet的外国友人,没有用法语已经很好了不是嘛……少年好好学英语呀  发表于 2014-5-30 17:32
发表于 2014-5-30 17:30:37 | 显示全部楼层
今晚,Ti-Nspire OS 3.9(预计于6月-四日发布)的系统安装文件已经上传到了TI服务器。当然目前在官网上还是没有链接。
完整版本号是3.9.0.461,文件于2014年5月16日生成。
正如之前所宣布的,一旦安装该系统,它会将计算器最低支持的系统版本设为3.9.0.455,因此无法回滚到旧版系统。
如果你在硬件版本为J或之后的Ti-Nspire CX上安装此系统,你将永远告别Ndless 3.6。
在其他型号的Ti-Nspire计算器上,理论上还是可以恢复到旧版系统的,但是需要使用你很可能没有的特定的硬件工具,它是用来重刷一个兼容Nlaunchy的Boot2的.
除此之外,这次的系统文件体积增长微乎其微,较之上一个版本仅仅增长了10KB。
内置的Boot2仍然是3.2.4.7版本(Ti-Nspire CX)和3.0.1.131版本(Ti-Nspire黑白屏机),Ti-Nspire非CAS版本的Ti-84 ROM也还是2.56MP版本。
总而言之,这次升级只是用户功能提升的一小步,而却是彻底扼杀新生的Ndless 3.6的一大步。
——Translated by Ulysses
额,我英文确实很烂啦,不过我是哈萨克人,学英语的要求不高呀,平时英语都只是随便学的,唉  发表于 2014-5-31 20:59
参与人数 1金钱 +6 收起 理由
549597890 + 6 辛苦
发表于 2014-5-30 18:05:04 | 显示全部楼层
看不懂,具体更新了些什么,没有在功能上有所改进吗,难道只是扼杀了Ndless 3.6吗
发表于 2014-5-30 18:18:15 | 显示全部楼层
仅仅是来堵死ndless的吗。。。
发表于 2014-5-30 20:08:45 | 显示全部楼层
hikari.uiharu 发表于 2014-5-30 18:18
仅仅是来堵死ndless的吗。。。
看样子是
为何TI不肯发布自己的SDK,大不了限制一下考试模式
发表于 2014-5-30 22:17:14 | 显示全部楼层
除了新买的机器似乎都没影响。。谁会去升级呢
发表于 2014-5-30 22:50:20 | 显示全部楼层
I wonder whether it has some corrections about calculation.
发表于 2014-5-30 23:42:05 | 显示全部楼层
其实很好理解,这是要垄断。 不再让第二方第三方第四方…… 再参与到底层开发中来。 这个系统,这个平台,只能是TI自己的后花园而独享。
发表于 2014-5-31 11:17:19 来自手机 | 显示全部楼层
TI为什么就非要堵Ndless?怕NS的系统被盗版移植吗?
发表于 2014-6-2 16:11:00 来自手机 | 显示全部楼层
堵ndless…
发表于 2014-6-5 12:43:31 | 显示全部楼层
我死也不升级了
发表于 2014-6-5 19:23:12 | 显示全部楼层
到底什么时候出正式版的啊
 楼主| 发表于 2014-6-26 02:45:25 | 显示全部楼层
New OS 3.9.0.463, now available on TI servers:
https://tiplanet.org/forum/viewtopic.php?p=167214#p167214
发表于 2014-6-26 08:08:09 | 显示全部楼层
终于在官网上有升级文件了,我安装了下,感觉和原来的一样啊,到底升级了什么?
发表于 2014-6-26 08:15:21 来自手机 | 显示全部楼层
critor 发表于 2014-6-26 02:45  New OS 3.9.0.463, now available on TI servers:  https://tiplanet.org/forum/viewtopic.php?p=167214#p1 ...
I think this update does not have change on functions,because 3.9 is nearly the same to 3.6 except for minimum version
发表于 2014-6-26 09:15:05 | 显示全部楼层
很早以前就向德州仪器反映,request的输入框太短了,过了一年了还没有改进
发表于 2014-6-27 15:53:48 | 显示全部楼层
已经更新半个月了,所有遇到过的 bug 都没有再遇到,非常稳定。字典好像有问题,没有与版本匹配的字典
发表于 2014-6-27 16:15:30 | 显示全部楼层
假如没有升级boot2, 可以考虑与3.1组双系统,在3.1里面装词典,两系统共用。
发表于 2014-6-28 08:51:07 | 显示全部楼层
升级了。。不知道升级了什么。。。
GMT+8, 2025-1-22 21:00 , Processed in 0.090554 second(s), 26 queries .
