查看: 19879|回复: 10
[HP系列] HP Calculator Connectivity Kit (CONNX3) for HP40gs adnd HP39gs
发表于 2015-3-27 11:46:29 | 显示全部楼层 |阅读模式
程序名称: HP Calculator Connectivity Kit (CONNX3) for HP40gs adnd HP39gs
平台: HP-39G
版本号:
类型: 其他
作者: 未知
大小(K): 6000
更新日期: 2015-03-27
描述: HP Calculator Connectivity Kit (CONNX3) for HP40gs adnd HP39gs
The HP40gs connectivity kit allows you to transfer aplets(tm), list, matrices, programs and notes from HP 39G Series (HP 39g+ and HP 39gs) or HP 40G Series calculator to PCs. In order to use the HP 40Gs connectivity kit, you must have installed the HP 40G (HP 39G) USB drivers (available on the CD) and have properly connected your HP 40G Series (or HP 39G Series) calculator to your PC using the provided USB cable.
Key features for this version - RS-232 support and flash ROM "download" support.
CONNX3 Version 2.1 Build 1330
For use with HP39g+, HP39gs and HP40gs Graphing Calculators.
Computer Operating System: Microsoft Windows 2000, Microsoft Windows 98, Microsoft Windows ME, Microsoft Windows XP.
Download Conn3x (File Size: 6 MB)
You may see the following screen:
/im/dbedu/1467486.png
Attach the Calculator to the PC and it turn on. You should see the following screen:
/im/dbedu/1468482.png
If you don't, then the USB driver has not been install. To install the USB driver, click here for the procedure to download the USB driver and installation Procedure.
Tagged By: Null-Modem Emulator (com0com), HP 40gs Virtual Calculator to HP Connect 3X, HP Connectivity Kit for HP 39g+ , HP 39gs Emulator for Trainers, HP 40gs CAS.
源代码: 闭源
自己懒得翻译了,就用有道翻译了
惠普计算器连接工具包(CONNX3)HP40gs adnd HP39gs
HP40gs连接工具包允许您传递aplets(tm),列表,矩阵,程序和笔记从惠普39 g系列(惠普39 g +和惠普39 gs)或40 g系列计算器惠普电脑。 为了使用惠普40 g连接套件,您必须已经安装了惠普40g(惠普39g)的USB驱动程序(可以在CD)和惠普已经正确连接你40 g系列(或惠普39 g系列)计算器,你的电脑使用提供的USB电缆。
这个版本的关键特性——rs - 232支持和闪速存储器支持“下载”。
CONNX3建造1330 2.1版本
使用 HP39g + , HP39gs HP40gs 图形计算器。
计算机操作系统:微软Windows 2000,Windows 98,微软Windows ME,微软Windows XP。
下载Conn3x (文件大小:6 MB)
您可能会看到下面的屏幕:
将计算器附加到电脑,打开。 您应该看到下面的屏幕:
如果你没看到,那么说明USB驱动程序还没有安装。 安装USB驱动程序, 点击这里的过程USB驱动程序下载和安装程序。
hpconn3x1330.zip
6.15 MB, 下载次数: 327, 下载积分: 金钱 -1
1407487.zip
27.34 KB, 下载次数: 202, 下载积分: 金钱 -1
usb驱动
发表于 2015-7-11 21:26:36 | 显示全部楼层
支持64位的win8.1吗
发表于 2015-7-12 11:56:28 | 显示全部楼层
HP39gII下载试试
发表于 2016-9-30 21:43:59 | 显示全部楼层
driver?
发表于 2017-10-6 18:54:21 | 显示全部楼层
这个计算器编程功能比较强大,用来给小孩子练习数学计算
发表于 2017-12-6 12:21:08 | 显示全部楼层
谢谢
发表于 2017-12-9 18:56:11 | 显示全部楼层
谢谢了
发表于 2018-4-13 15:37:20 | 显示全部楼层
哦 不小心点了下载 ,其实都已经有了 还是谢谢哈
发表于 2018-11-5 20:06:50 | 显示全部楼层
39GII支持吗?
发表于 2018-11-7 10:07:59 | 显示全部楼层
好东西,下了用用看
发表于 2020-3-9 18:54:23 | 显示全部楼层
不支持win10.64位哦
GMT+8, 2025-1-22 17:56 , Processed in 0.047767 second(s), 24 queries .
