查看: 5027|回复: 5
[Nspire] TI CM-C CAS可否刷到OS3.6系统?我只会降到OS3.1,还请各位大神指教
发表于 2015-12-29 17:39:29 | 显示全部楼层 |阅读模式
TI CM-C CAS可否刷到OS3.6系统?我只会降到OS3.1,还请各位大神指教,如果可以刷到3.6请指导一下,万分感谢
发表于 2015-12-29 19:02:27 | 显示全部楼层
刷不了
发表于 2015-12-29 19:41:57 | 显示全部楼层
You can install CX OSes on your TI-Nspire CM, by :
- changing its NAND model ID from CM to CX (by using nsNandMgr)
- flashing a the TI-Nspire CX Boot2 3.1 (by using nsNandMgr)
- installing Nlaunchy CXM (a fork of Nlaunchy specifically designed for TI-Nspire CM modded this way)
You'll then be able to install and run any TI-Nspire CM or TI-Nspire CX OS up to version 3.3.
Unfortunately, version 3.6 and above won't work, neither CAS nor non-CAS
TI has added new more strict ASIC flags checks in those versions, to prevent people from running CAS OSes on non-CAS hardware.
CM models are using different ASIC flags values, so as a side issue no TI-Nspire CX OS 3.6 or above is going to work. :(
Unfortunately, Nlaunchy has never been updated to patch those new checks. :'(
So the 1st thing to do would be to develop and add the missing 3.6 patches to Nlaunchy, and then to Nlaunchy CXM.
Informations and downloads : https://tiplanet.org/forum/viewtopic.php?t=16100
发表于 2017-5-17 07:55:06 来自手机 | 显示全部楼层
楼主,怎么降到3.1
发表于 2017-5-17 08:37:05 | 显示全部楼层
sunandhai 发表于 2017-5-17 07:55
楼主,怎么降到3.1
直接同步软件安装3.1就行
发表于 2017-5-17 08:40:51 | 显示全部楼层
楼主,怎么降到3.1
我原来是3.2.0.X,后面是几具体忘了,直接同步软件安装操作系统就行
GMT+8, 2025-1-22 23:00 , Processed in 0.050772 second(s), 18 queries .
