查看: 13585|回复: 23
[Nspire] Ndless 4.0.3 released !
发表于 2016-1-3 05:26:29 | 显示全部楼层 |阅读模式
Today is released the brand new version of Ndless, now compatible with the latest Nspire OS to date: 4.0.3 ! :)
For those who are not aware, Ndless is the "jailbreak" of the TI-Nspire, which allows you to run programs much more powerful than what TI normally allows (Basic, Lua), as they can be written in C/C++/ASM ("native" programming).
You can now enjoy your favorite Ndless programs on your Nspire CX or CX CAS.
For instance (in reverse order of release/update):
  • Utilities : nSonic (file browser + anti-abuse protection), KhiCAS (Xcas engine with Lua interface)...
  • Interpreters : DukTape, MicroPython, for JavaScript and Python languages respectively...
  • Lots of games, like crafti (Minecraft clone in 3D) or many others (including ports), and emulators
A big "Thank you" to the Ndless team for this new-year's gift :D
Download: Ndless 4.0 (also contains updated binaries for 3.9 and 3.6)
Install Tutorial: available here
Official website: http://ndless.me
Source code and Ndless SDK: https://github.com/ndless-nspire/Ndless (SDK tutorial here)
参与人数 1金钱 +6 收起 理由
549597890 + 6 Great!
发表于 2016-1-3 08:33:02 来自手机 | 显示全部楼层
Thanks, critor.
Is there any known issue from Ndless 4.0.3?
发表于 2016-1-3 08:33:26 来自手机 | 显示全部楼层
That is THE BEST NEW YEAR GIFT for us!
Thanks a million to Ndless team!
发表于 2016-1-3 08:39:34 来自手机 | 显示全部楼层
Execting! It's a wonderful gift for the caculator fans. Best wishes for ndless team!
Happy new year, critor
发表于 2016-1-3 09:20:18 来自手机 | 显示全部楼层
thank you very much! happy new year
发表于 2016-1-3 11:41:08 来自手机 | 显示全部楼层
This new year's gift is incredible! Thanks so much!
By the way, what's the changes of ndless 3.6 and 3.9? And what's wrong with hackspire wiki?
发表于 2016-1-3 14:28:48 | 显示全部楼层
支持一下!
发表于 2016-1-3 18:16:41 | 显示全部楼层
Known issues in these ndless apps:
1. GPSP. The calculator reboots when initialize any game that worked in Ndless 3.6, for example, Mega Man Battle Network series.
2. nClock. The mini clock doesn't work. When you tried to adjust the position of mini clock, the calculator reboots.
3. KHICAS. It takes more time to initialize the Giac CAS Engine than that in Ndless 3.6. When calculates rsolve(a(n)=a(n-1)+a(n-2),a(n),[a(1)=1,a(2)=1]), the calculator reboots, however, it didn't happen on my TI-Nspire CX CAS L.
4. nsNandMgr. Boot2 Version display unproperly as the picture below:
 楼主| 发表于 2016-1-3 18:36:05 | 显示全部楼层
1. GPSP. The calculator reboots when initialize any game that wo ...
Thank you for your reports.
#2, nClock : Yes, we already told the author the day before the release.
#4, nsNandMgr : Just download and use and up to date version :
https://tiplanet.org/forum/archives_voir.php?id=10080
I'm forwarding #1 and #3. :)
 楼主| 发表于 2016-1-3 22:42:47 | 显示全部楼层
e
I've had a look at nClock, and noticed the author hadn't even updated it for Ndless 3.9, the latest version dating from March 2014. :o
So with the help of Vogtinator, we've worked on catching up.
nClock 1.0.7 new features :
  • Full Ndless 4.0.3 support
  • Partial Ndless 3.9 support :
    • TI-Nspire CX CAS 3.9.1
    • TI-Nspire non-CAS 3.9.0
TI-Nspire CX non-CAS 3.9.1 and TI-Nspire CAS 3.9.0 aren't supported for now.
Download : https://tiplanet.org/forum/archives_voir.php?id=4416
发表于 2016-1-4 11:57:32 来自手机 | 显示全部楼层
critor 发表于 2016-1-3 22:42
I've had a look at nClock, and noticed the author hadn't even updated it for Ndless 3.9, the latest  ...
Thanks, critor.
However, I find the nclock still doesn't work on my TI-Nspire CX CAS, and it behaves even worse than previous version. the hardware revision is L. One of my friend told me that in his TI-Nspire CX CAS with 4.0.3.29, GPSP works well.
Maybe the compatibility depends on the hardware revision?
 楼主| 发表于 2016-1-4 18:51:08 | 显示全部楼层
I think it's the nClock setup file which was corrupted while trying to use nClock 1.0.6 with the unsupported OS 4.0.3.
I've had something similar.
On the calculator, rename the 'nClock' file to 'uninstall' and launch it.
It should ask you if you confirm the setup file removal.
Then, rename the file back to 'nClock' and reset the calculator.
For me, nClock 1.0.7 then behaved perfectly well. :)
发表于 2016-1-4 23:05:18 | 显示全部楼层
Can OS3.6.x use the new nclock?
 楼主| 发表于 2016-1-5 01:46:19 | 显示全部楼层
Yes. :)
发表于 2016-1-5 08:48:26 | 显示全部楼层
It  means that if I want to enjoy ndless4.0,I must update my OS version from 4.0 to 4.03?
 楼主| 发表于 2016-1-5 19:25:08 | 显示全部楼层
Yes.
 楼主| 发表于 2016-1-7 04:12:10 | 显示全部楼层
By the way, what's the changes of ndless 3.6  ...
The hackspire server is down.
Hardware failure...
发表于 2016-1-27 09:20:48 | 显示全部楼层
我的妈呀,简直太棒了!我的老师原本把我们的计算器升到4.0不让我们搞ndless的,这下可好,神器啦~
发表于 2016-2-1 00:33:11 | 显示全部楼层
And....Who can tell me is it different from 3.9,the way to use?
 楼主| 发表于 2016-2-1 08:35:46 | 显示全部楼层
No difference once installed. :)
GMT+8, 2025-1-23 02:14 , Processed in 0.061479 second(s), 22 queries .
