查看: 7089|回复: 10
[Nspire] Ndless4.2已发布!
发表于 2016-2-20 12:25:29 来自手机 | 显示全部楼层 |阅读模式
德州仪器在前一段时间更新了Nspire OS 4.2,封堵了Ndless4.0。
然而,法国大神的效率令人惊叹--就在昨天,TI-Planet计算器论坛传出Ndless4.2发布的消息。
Ndless4.2的安装方式和Ndless 4.0的安装方式相同,并且仍会在重启后失效。
目前该版本Ndless的稳定性和兼容性尚未经过测试。此外,该版本Ndless仍不适用于硬件版本为W的机型。
来源地址: https://tiplanet.org/forum/viewtopic.php?p=197261#p197261
参与人数 1金钱 +2 收起 理由
洛天依 + 2 很给力!
发表于 2016-2-20 19:16:13 | 显示全部楼层
沙发
发表于 2016-2-20 20:22:05 | 显示全部楼层
好快
发表于 2016-2-20 23:12:59 | 显示全部楼层
德仪出新系统只是为了封堵ndless么?
发表于 2016-2-21 08:54:03 | 显示全部楼层
极速
发表于 2016-2-21 17:31:26 | 显示全部楼层
发表于 2016-2-21 21:58:09 | 显示全部楼层
这个有点快的
 楼主| 发表于 2016-2-22 00:31:48 来自手机 | 显示全部楼层
OS4.0可以这么说,4.2不是。4.2较4.0增加了一些功能。
当然,封堵Ndless是德仪的日常。
发表于 2016-3-5 21:05:17 | 显示全部楼层
今天4.2越狱了。
发表于 2016-3-8 10:33:00 | 显示全部楼层
天哪噜效率好恐怖啊
发表于 2016-3-13 08:58:00 | 显示全部楼层
Ndless 4.2 has now been updated with support for the new TI-Nspire CX CR4 (hardware revision W+) screen (mirrored 240x320 instead of 320x240 - more informations).
It includes a compatibility layer to help not yet updated Ndless programs working with the new screen.
The compatibility mode does intercept the display outputs and fix them.
The compatibility mode won't work with Ndless programs installing hooks (nSonic and nClock for example).
The compatibility mode may not work well with some other programs, depending upon the way they're writing to the screen, especially games which need to refresh the screen many times per second.
If you find an Ndless program which doesn't work well on the new TI-Nspire CX CR4 despite the compatibility mode being triggered, the program will need to be updated.
In that case please contact the author or report the program - thanks.
More informations : https://tiplanet.org/forum/viewtopic.php?p=198255#p198255
GMT+8, 2025-1-23 02:12 , Processed in 0.063007 second(s), 20 queries .
