查看: 3394|回复: 1
[fx-9860/9750] 关于SDKBdisp_WriteGraph_DDVRAM的问题
发表于 2016-7-1 09:36:04 来自手机 | 显示全部楼层 |阅读模式
我想呈现一张照片,编好了程序,系统就给我说C1016 (W) Argument mismatch,我认为draw_picture实参和形参相同,求大神指导。
以下是程序
#include<fxlib.h>
#include<stdio.h>
int AddIn_main(int isAppli, unsigned short OptionNum)
{void draw_picture (int x,int y,int width,int height,int kind,int mod,unsigned
char * pGraph);
const char G[]=
{0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
0x0,0xC,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x7C,0x0,0x0,
0x0,0x38,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x3,0x80,0x0,
0x0,0x20,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xE0,0x0,
0x0,0xE0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x30,0x0,
0x1,0x80,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x18,0x0,
0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xC,0x0,
0x0,0x0,0x3F,0xFF,0xFF,0xFE,0x0,0x0,0xE0,0x0,0x0,0x3,0x80,0x0,0x4,0x0,
0x0,0x0,0x3F,0xFF,0xFF,0xFE,0x0,0x0,0xE0,0x0,0x0,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x3F,0xFF,0xFF,0xFE,0x0,0x0,0xF0,0x0,0x0,0x7,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x1E,0x0,0x0,0xF8,0x0,0x0,0x7,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x3C,0x0,0x0,0xF8,0x0,0x0,0xF,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x38,0x0,0x0,0xF8,0x0,0x0,0xF,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x78,0x0,0x0,0xF8,0x0,0x0,0xF,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0xF0,0x0,0x0,0xFC,0x0,0x0,0x1F,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x1,0xE0,0x0,0x0,0xFC,0x0,0x0,0x1F,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x3,0xC0,0x0,0x0,0xEE,0x0,0x0,0x3F,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x7,0x80,0x0,0x0,0xEE,0x0,0x0,0x3B,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x7,0x80,0x0,0x0,0xEF,0x0,0x0,0x3B,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0xF,0x0,0x0,0x0,0xE7,0x0,0x0,0x73,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x1E,0x0,0x0,0x0,0xE7,0x80,0x0,0x73,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x3C,0x0,0x0,0x0,0xE3,0x80,0x0,0xF3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x78,0x0,0x0,0x0,0xE3,0xC0,0x0,0xE3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x70,0x0,0x0,0x0,0xE1,0xC0,0x0,0xE3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0xF0,0x0,0x0,0x0,0xE1,0xC0,0x1,0xC3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x1,0xE0,0x0,0x0,0x0,0xE0,0xE0,0x1,0xC3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x3,0xC0,0x0,0x0,0x0,0xE0,0xE0,0x3,0xC3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x7,0x80,0x0,0x0,0x0,0xE0,0x70,0x3,0x83,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0xF,0x0,0x0,0x0,0x0,0xE0,0x70,0x3,0x83,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0xF,0x0,0x0,0x0,0x0,0xE0,0x38,0x7,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x1E,0x0,0x0,0x0,0x0,0xE0,0x38,0x7,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x3C,0x0,0x0,0x0,0x0,0xE0,0x3C,0xF,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x78,0x0,0x0,0x0,0x0,0xE0,0x1C,0xE,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0xF0,0x0,0x0,0x0,0x0,0xE0,0x1E,0xE,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0xE0,0x0,0x0,0x0,0x0,0xE0,0xE,0x1C,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x1,0xE0,0x0,0x0,0x0,0x0,0xE0,0xF,0x1C,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x3,0xC0,0x0,0x0,0x0,0x0,0xE0,0x7,0x3C,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x7,0x80,0x0,0x0,0x0,0x0,0xE0,0x7,0x38,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0xF,0x0,0x0,0x0,0x0,0x0,0xE0,0x3,0xB8,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x1E,0x0,0x0,0x0,0x0,0x0,0xE0,0x3,0xF0,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x1E,0x0,0x0,0x0,0x0,0x0,0xE0,0x1,0xF0,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x3F,0xFF,0xFF,0xFE,0x0,0x0,0xE0,0x1,0xF0,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x3F,0xFF,0xFF,0xFE,0x0,0x0,0xE0,0x1,0xE0,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x3F,0xFF,0xFF,0xFE,0x0,0x0,0xE0,0x0,0xE0,0x3,0x80,0x0,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x8,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x18,0x0,
0x4,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x30,0x0,
0x3,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x60,0x0,
0x1,0x80,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x40,0x0,
0x0,0x70,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xC0,0x0,
0x0,0x1F,0xE0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x80,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xE,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x18,0x0,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,};
draw_picture (0,0,128,64,1,2,G);
char * pGraph)
{typedef struct tag_GRAPHDATA{
int width;
int height;
unsigned char *pBitmap;
} GRAPHDATA;
typedef struct tag_DISPGRAPH{
int x;
int y;
GRAPHDATA GraphData;
WRITEMODIFY WriteModify;
WRITEKIND WriteKind;
} DISPGRAPH;
DISPGRAPH dg;
dg.x = x;
dg.y = y;
dg.GraphData.width = width;
dg.GraphData.height = height;
dg.GraphData.pBitmap = pGraph;
dg.WriteModify = mod;
dg.WriteKind = kind;
Bdisp_WriteGraph_DDVRAM(&dg);
 楼主| 发表于 2016-7-1 10:31:07 | 显示全部楼层
还有这又是什么问题?Invalid parameter specified in option "input"
GMT+8, 2025-1-31 07:25 , Processed in 0.052375 second(s), 18 queries .
