查看: 5659|回复: 4
[fx-9860/9750] 用c语言写的简单的计算方位角的程序
发表于 2016-10-3 00:34:55 | 显示全部楼层 |阅读模式
#include "string.h"
#include "ctype.h"
#include "mathf.h"
#include <stdlib.h>
#include <stdio.h>
#include <fxlib.h>
#include <math.h>
#include <stdarg.h>
#include <dispbios.h>
int cur_row=1;
char buf[256]={0};
double a,b,c,d,e,f,g,h,i,j,k,l,m,n;
unsigned char *sp1="                      ";
void message(char *msg)//send message
locate(1,8);
Print(sp1);
Print((unsigned char *)msg);
int printf(const char *cpFormat, ...)//show string in current line
    char cpBuffer[300]={0};
    int i=0;
    va_list pArgList;
    va_start(pArgList, cpFormat);
    vsprintf(cpBuffer, cpFormat, pArgList);
    va_end(pArgList);
    cpBuffer[299]=0;
    if(cur_row>7)
          int x,y,dot;
          for(x=0;x<=127;x++)
          for(y=0;y<=55;y++)
              Bdisp_SetPoint_VRAM (x,y,Bdisp_GetPoint_VRAM(x,y+8));
          Bdisp_PutDisp_DD;
          cur_row=7;//current line
    //clean up screen below current line
    for (i=cur_row;i<=8;i++)
        locate(1,i);
        Print(sp1);
    locate(1,cur_row);
    Print((unsigned char *)cpBuffer);
    cur_row++;
    return cur_row;
void cls()
    int i=0;
    cur_row=1;
    for (i=1;i<=8;i++)
        locate(1,i);
        Print(sp1);
void pause()
    unsigned int key;
    locate(1,8);
    Print((unsigned char *)"            - Disp -");
    do
        GetKey(&key);
    while(!key);
//file system"\\\\fls0\\" "\\\\crd0\\"
FONTCHARACTER *ToFileName(const char *f1)
  static FONTCHARACTER f2[50]={0};
  int p=0;
  while(f2[p]=f1[p])p++;
  return f2;
int CloseFile(int Handle)
  return Bfile_CloseFile(Handle);
int OpenFile(char *FileName)
  return Bfile_OpenFile(ToFileName(FileName),_OPENMODE_READ_SHARE);
int ReadFile( int handle, char *buf, int Size, int ReadPos)
  return Bfile_ReadFile(handle,buf,Size,ReadPos);
int WriteFile(int handle ,char *buf,int size)
  return Bfile_WriteFile(handle,buf,size);
int SeekFile(int handle,int pos)
  return Bfile_SeekFile(handle,pos);
int FileSize(int handle){
  return Bfile_GetFileSize(handle);
int CreateFile( char *FileName, int size)
    return Bfile_CreateFile( ToFileName(FileName), size);
int DeleteFile(char *FileName)
    return Bfile_DeleteFile(ToFileName(FileName));
//==========angle fuction=============================
double dfmtod(double dfm)
    double a,b,c,temp;
    while(dfm<0)dfm+=360;
    while(dfm>=360)dfm-=360;
    a=(int)dfm;
    temp=(dfm-a)*100;
    b=(int)temp;
    c=(temp-b)*100;
    return (a+b/60+c/60/60);
double dtodfm(double d)
    double a,b,c,temp;
    while(d<0)d+=360;
    while(d>=360)d-=360;
    a=(int)d;
    temp=(d-a)*60;
    b=(int)temp;
    c=(temp-b)*60;
    return(a+b/100+c/10000);
double deg(double x)// change to deg
    return (180*x/3.1415926535);
double rad(double x) // change to rad
    return (x/180*3.1415926535);
double pol(double x1,double y1)// get azimuth
    double d1=sqrt(x1*x1+y1*y1);
    double c1=acos(x1/d1);
    if(y1<0)c1=-c1;
    return c1;
//=====input data==============================
double input(double num){
    const int len = 14;
    unsigned int key;
    char c[30]={0},ds[30];
    //sprintf(c,"%.4f", num);
    if(cur_row>7)
          int x,y,dot;
          for(x=0;x<=127;x++)
          for(y=0;y<=55;y++)
          Bdisp_PutDisp_DD;
        cur_row=7;
        locate(1,i);
        Print(sp1);
    goto start;
    while (1){
        int n=strlen(c);
        GetKey(&key);
        switch(key)
            case KEY_CTRL_EXE:
                if (c[0]) {
                      locate(1,cur_row);
                      sprintf(ds,"%s              ",c);
                      Print((unsigned char*)ds);
                      cur_row++;
                      return atof(c);
                else{
                     locate(1,cur_row);
                     sprintf(ds,"%.4f              ",num);
                      cur_row++;
                     return num;
            case KEY_CTRL_AC:
                c[0]=0;
                break;
            case KEY_CTRL_DEL:
                if(n)c[n-1]=0;
                break;
            case KEY_CHAR_0:
            case KEY_CHAR_1:
            case KEY_CHAR_2:
            case KEY_CHAR_3:
            case KEY_CHAR_4:
            case KEY_CHAR_5:
            case KEY_CHAR_6:
            case KEY_CHAR_7:
            case KEY_CHAR_8:
            case KEY_CHAR_9:
                if(n<len){
                    c[n]=key;
                    c[n+1]=0;
                break;
            case KEY_CHAR_DP:
                if(!strchr(c, '.') && n<len){
                    c[n]='.';
                    c[n+1] = 0;
                break;
            case KEY_CHAR_MINUS:
            case KEY_CHAR_PMINUS:
                if (c[0] == '-'){
                   char buf[30]={0};
                   strcpy(buf,c);
                   strcpy(c,buf+1);
                else if(n<len)  {
                   char buf[30]={0};
                   strcpy(buf,c);
                   sprintf(c,"-%s",buf);
                break;
           start:
           locate(1,cur_row);
           sprintf(ds,"%s_              ",c);
int area_clear(int left, int top, int right, int bottom, int sel)
    DISPBOX box;
    box.left=left;
    box.top=top;
    box.right=right;
    box.bottom=bottom;
    if (sel)
        //drawing dox
        Bdisp_DrawLineVRAM (left , top   , right, top);
        Bdisp_DrawLineVRAM (left , bottom, right, bottom);
        Bdisp_DrawLineVRAM (left , top   , left , bottom);
        Bdisp_DrawLineVRAM (right, top   , right, bottom);
    //clear area
    else Bdisp_AreaClr_DDVRAM (&box);
//drawing menu
int menu (char *buf){ //tab split buf;
  int rows=n,i=0,j=0,index=0;
  unsigned key=0;
  char s[10][50]={0};
  int n=sscanf(buf,"%s%s%s%s%s%s%s%s%s%s",s[0],s[1],s[2],s[3],s[4],s[5],s[6],s[7],s[8],s[9]);
if (n<3|| n>10)return 0;
for(i=0;i<n;i++)s[i][19]=0;
Bdisp_PutDisp_DD();
SaveDisp( SAVEDISP_PAGE1);
area_clear(4,1,125,63,0);
area_clear(4,1,124,63,2);
Bdisp_DrawLineVRAM (125, 2, 125, 63);
Bdisp_DrawLineVRAM (4, 12, 124, 12);
PrintXY(7,3,(unsigned char*)s[0],0);
index=1;
while(1)
      if(index>=n)index=1;
      if(index<1)index=n-1;
      j=index>=7?7:1;
      for(i=j;i<=j+5;i++)
          int x,y,sel;
          char buf[22];
          x=7;
          y=(i-j)*8+14;
          sel=(index!=i?0:1);
          if (i<n)  sprintf(buf,"%-19s",s[i]);
          else      sprintf(buf,"%-19s"," ");
          PrintXY(x,y,(unsigned char *)buf,sel);
      GetKey(&key);
      switch(key){
          case KEY_CTRL_UP:
          case KEY_CTRL_LEFT:
               index--;
               break;
          case KEY_CTRL_DOWN:
          case KEY_CTRL_RIGHT:
               index++;
               break;
          case KEY_CTRL_EXE:
          case KEY_CTRL_F1:
               RestoreDisp (SAVEDISP_PAGE1);
               Bdisp_PutDisp_DD();
               return(index);
double jf_cos(double A1,double B1,double C1,double X2){
double t1, t2, S2=0.0, S1, eps=0.00001;
double ep=100;
    if (A1)
       double h=X2;
       double temp1=C1;
       double temp2=A1*X2*X2+B1*X2+C1;
           S1=t1=h*(cosf(temp1)+cosf(temp2))/2.0;
           while (ep>=eps)
                 double p=0;
                int n=1, k=0;
                 for (k=0;k<n;k++)
                    int x=(k+0.5)*h;
                    temp1=A1*x*x+B1*x+C1;
                    p+=cosf(temp1);
                 t2=(t1+h*p)/2;
                 S2=(4.0*t2-t1)/3;
                 ep=fabs(S2-S1);
                 t1=t2;   S1=S2;
                n=n+n;   h=h/2;
else if (B1) S2=(sinf(B1*X2+C1)-sinf(C1))/B1;
else S2=cosf(C1)*(X2);
return S2;
double jf_sin(double A1,double B1,double C1,double X2)
return jf_cos(A1,B1,C1-1.570796,X2);
int AddIn_main(int isAppli, unsigned short OptionNum)
    double x1=0,y1=0,x2=0,y2=0;
    double ret=0;
    char buf[300]={0};
    cls();
    printf("X1=%.4f",x1);
    x1=input(x1);
    printf("Y1=%.4f",y1);
    y1=input(y1);
    while(1)
    cls();
    printf("X2=%.4f",x2);
    x2=input(x2);
    printf("Y2=%.4f",y2);
    y2=input(y2);
    ret=pol(x2-x1,y2-y1);
    printf("Angle=%.4f",ret);
    pause();
    sprintf(buf,"=======Result==========\tX1=%.4f\tY1=%.4f\tX2=%.4f\tY2=%.4f\tAngle=%.4f\t===================Exit\tHelp\tAbout",x1,y1,x2,y2,ret);
menu(buf);
    return 1;
//**************                 Notice!                      ****************
//**************  Please do not change the following source.  ****************
#pragma section _BR_Size
unsigned long BR_Size;
#pragma section
#pragma section _TOP
//  InitializeSystem
//  param   :   isAppli   : 1 = Application / 0 = eActivity
//              OptionNum : Option Number (only eActivity)
//  retval  :   1 = No error / 0 = Error
int InitializeSystem(int isAppli, unsigned short OptionNum)
    return INIT_ADDIN_APPLICATION(isAppli, OptionNum);
#pragma section
 楼主| 发表于 2016-10-3 00:37:50 | 显示全部楼层
主要是要用c语言写一些常用测量程序,9860的c语言缺少基本的输入语句以及菜单命令
发表于 2016-10-3 06:38:08 来自手机 | 显示全部楼层
值得我学习,我也很喜欢代码。因为我觉得那是人类灵魂之精华。
发表于 2016-10-3 18:26:24 | 显示全部楼层
建议直接上传代码文件
 楼主| 发表于 2016-10-3 19:26:10 | 显示全部楼层
prog1.zip (173.74 KB, 下载次数: 39)
主要包括一个输入数字的input函数,一个显示字符串的printf函数,一个菜单函数,一个计算cos(a*x*x+b*x+c)这种形式的积分计算函数,用于线元法计算时会用到,cls(),pause()函数,求方位角函数等,以后写程序时可以作为代码模板使用
GMT+8, 2025-1-31 07:15 , Processed in 0.041821 second(s), 21 queries .
