查看: 16084|回复: 27
[Nspire] 哇————————Ti不是人——————
发表于 2009-8-27 21:11:39 | 显示全部楼层 |阅读模式
没想到啊没想到。。。。。。竟然有Ti nspire cas+。。。而且还这么**的配置。。。。。。
The program and data memory of the disassembled TI-Nspire CAS+ consists of one Qimonda HYB18L256160 SDRAM with 16M*16 size.
算算。。。这多少内存啊。。。连SD卡都不用了。。。。。。
而且这CPU。。。。。。
Processor: The OMAP™ processor of the TI-Nspire CAS+ preproduction unit is labelled TI-OMAP NP31AZZG. We assume that this tiny chip is actually a System-on-Chip based on the OMAP architecture from Texas Instruments hosting a 90 MHzARM9 32-bit RISC processor.
90MHz啊啊啊啊啊!
 楼主| 发表于 2009-8-27 21:12:05 | 显示全部楼层
额?Origin of manufacture:  China (S) 奇怪了吧。。。
 楼主| 发表于 2009-8-27 21:12:57 | 显示全部楼层
话说。。。CPU是32位的?加上32MB运存。。。运行98不成问题。。。。。。
 楼主| 发表于 2009-8-27 21:14:19 | 显示全部楼层
郁闷。。。就是不提软件的事情。。。
The TI-89 Titanium graphing calculator and Voyage 200 personal learning tool will continue to be offered and supported by TI. Because the TI-Nspire CAS handheld and computer software combine new TI-Nspire features with Computer Algebra System capabilities built in, they offer educators an added option to incorporate CAS into their lessons.
 楼主| 发表于 2009-8-27 21:14:44 | 显示全部楼层
 楼主| 发表于 2009-8-27 21:17:37 | 显示全部楼层
可是并没有提到nspire cas的频率。。。The current (April 2007) chips with the TI-NS2006A-1 / L9A0654 identification are designed in a 0.13um process and manufactured in any of LSI Logic's foundries, which include Semiconductor Manufacturing International, Taiwan Semiconductor Manufacturing and United Microelectronics.
发表于 2009-8-27 22:20:58 | 显示全部楼层
**配置啊!!!!!!!
发表于 2009-8-27 22:22:30 | 显示全部楼层
彻底无语,十分钟被屏蔽两次
发表于 2009-8-27 22:26:55 | 显示全部楼层
Ti nspire cas应该可以升级成Ti nspire cas+
配置嘛,你就恨你RP不够吧
发表于 2009-8-27 23:13:07 | 显示全部楼层
都可以当掌上电脑了
可惜没程序
发表于 2009-8-27 23:57:12 | 显示全部楼层
SDRAM只是内存而已..不是存储数据用的
32位控制器,但是是ARM的,不能运行x86系统。
发表于 2009-8-28 09:29:51 | 显示全部楼层
chsi 发表于 2009-8-27 23:57
抢我的台词..CASIO,TI的厂商没钱买效率不算很高但价格昂贵X86授权
发表于 2009-8-28 12:32:43 | 显示全部楼层
LZ 请注意,Ti本来就不是人,它只是个公司
qq446015875 发表于 2009-8-28 12:06
同意,就像qq446015875不是人,
只是个网名一样。
发表于 2009-8-28 15:25:05 | 显示全部楼层
发表于 2009-8-30 01:17:01 | 显示全部楼层
991es82es 发表于 2009-8-28 09:29
也抢了我的-_-||
半夜回复,Casio不做Cpu,也不是没钱的问题,主要是各平台的适应范围。
小小的掌上嵌入式平台用不着完整的指令集,精简的构架大幅减小耗电。
不过如果真想在arm上跑98,在系统允许的情况下,完全可以使用软件代码模拟X86平台,跑dos、98、Linux等,在WM手机上已经有相应的软件了。
不过我想德州仪器的软件开发放得没那么开吧
发表于 2009-8-30 09:49:20 | 显示全部楼层
95就行了psp都可以
发表于 2009-9-2 21:05:10 | 显示全部楼层
不过ls要清楚,指令多次转换,这个效率有多高楼上要清楚,运行98?!估计得跟幻灯片似的,而且间隔是N年
qq446015875 发表于 2009-8-30 09:04
效率还可以,经过我的多次优化,调试CPU仿真DLL文件,成功在一块Intel XScale PXA270 416MHz处理器上跑了98。主要模拟x86环境是为了随时随地写程序,准备参加NOIP嘛。。
幻灯片倒是不至于
发表于 2009-9-2 21:07:27 | 显示全部楼层
忘了说,Cpu超频到了624Mhz,不敢用太久,电池好烫啊,之后降到520Mhz,日常用了。
发表于 2009-9-3 19:27:18 | 显示全部楼层
bruce55 发表于 2009-9-2 21:07
不用电池,直接用一个LM317供电
 楼主| 发表于 2009-9-3 19:46:37 | 显示全部楼层
这样的频率似乎很高呀。。。我家的老长城P3的,600Mhz而已,照跑Xp。。。
GMT+8, 2025-2-2 12:21 , Processed in 0.065631 second(s), 18 queries .
