查看: 4616|回复: 3
Fx-es加仿真器请求 / Fx-es plus emulator request
发表于 2016-12-4 18:33:22 | 显示全部楼层 |阅读模式
任何人都有一个fx-es加仿真器可以下载? 我在tieba.baidu.com上找到了一些网站(http://tieba.baidu.com/p/1829238288),在这个网站上有一个网站(http://www.cncalc.org/thread-3746-1-1。 html),但几乎所有的都有死链接。 只有一个可以下载在http://tieba.baidu.com/p/1831710874然而,当我运行模拟器,我得到“发生内部错误0x000010002”。
我还在https://tiplanet.org/forum/archives_voir.php?id=79086找到了一个未解密的版本。
注意:我需要一个fx-es加仿真器而不是一个fx-es仿真器,因为我已经找到了一个永久升级fx-82es仿真器的简单方法。
此外,任何人都可以将密钥集保存在http://www.cncalc.org/forum.php? ... hlight=fx-es%2Bplus
(由Google翻译翻译)
Do anyone have a fx-es plus emulator that can be downloaded? I found some sites on tieba.baidu.com (http://tieba.baidu.com/p/1829238288) and one on this site (at http://www.cncalc.org/thread-3746-1-1.html), but almost all of them have dead links. The only one that can be downloaded is at http://tieba.baidu.com/p/1831710874 however when I run the emulator I get "An internal error occurred. 0x000010002".
I also found a uncracked version at https://tiplanet.org/forum/archives_voir.php?id=79086 .
Note: I need a fx-es plus emulator and not a fx-es emulator because I already found an easy way to upgrade the fx-82es emulator permanently.
Moreover, anyone keep the keyset at http://www.cncalc.org/forum.php? ... hlight=fx-es%2Bplus ?
 楼主| 发表于 2016-12-12 23:27:50 | 显示全部楼层
我发现了模拟器自己(在fx-es加研究PDF)。 但是,是4.0版本(特别是fx-570es plus)可用吗? 我想没有,因为程序非常罕见,我想。
I found the emulator myself (in the fx-es plus research PDF). But, is version 4.0 (specifically fx-570es plus) available? I think no, because the program is very rare, I think.
发表于 2017-9-6 10:01:35 | 显示全部楼层
user202729 发表于 2016-12-12 23:27
我发现了模拟器自己(在fx-es加研究PDF)。 但是,是4.0版本(特别是fx-570es plus)可用吗? 我想没有,因 ...
Already have, before the end of this year, the fx-Manager PLUS 2.2 will be packed and only for study use.
发表于 2017-9-6 10:05:14 | 显示全部楼层
Keyset is too old, it was compiled by Visual Basic 6.0, and it relies on some pictures on a discontinued 5d6d.com domain of Discuz. So, it can no longer worked any more.
fx-ES PLUS Emulator contains key-log functions, but now although it was cracked and can be runned without the CD, the keylog option in the popup menu was disabled.
So, maybe it should be some other Disassembly?
GMT+8, 2025-1-22 22:00 , Processed in 0.038186 second(s), 18 queries .
