楼主: Mike
[fx-9860/9750系列] [Add-in]Eigenmath现加入自然输入
 楼主| 发表于 2017-10-11 22:59:59 | 显示全部楼层
他天一 发表于 2017-10-8 00:08
这个…
“F:\数据\Prog\Console-fx-master\collect2.exe        [Error] ld returned 1 exit status”
电脑上要用的话,依赖GLFW。你可以安装GLFW之后使用CMAKE来构建。
发表于 2017-11-7 05:55:57 | 显示全部楼层
BEST CAS EVER
发表于 2017-11-7 06:19:27 | 显示全部楼层
is that the source in the zip?
 楼主| 发表于 2017-11-7 15:18:17 | 显示全部楼层
Yes, but the add-in still contains some bugs... i wish some one could help.
发表于 2017-11-12 07:14:35 | 显示全部楼层
时隔一年终于等到了,谢谢大神的奉献!
发表于 2017-12-3 13:13:51 | 显示全部楼层
支持资磁
发表于 2017-12-20 05:58:44 | 显示全部楼层
Hi everyone
I have an older version of this CAS on my 9860GII.
It works great but it does not calculate the result of a matrix multiplication.
Am I doing something wrong or this is a limitation?
 楼主| 发表于 2017-12-22 15:32:27 | 显示全部楼层
Mohammadtt 发表于 2017-12-20 05:58
Hi everyone
It works great but it does not calc ...
Hi. Thanks for your feedback. Can you please explain a bit more about how it went wrong? So that we may be able to identify the problem.
发表于 2018-1-29 08:20:42 | 显示全部楼层
is it possible to add the int64 patch?
 楼主| 发表于 2018-1-30 16:33:55 | 显示全部楼层
int64 is supported by replacing the tool chain. you may refer to https://www.cncalc.org/thread-9800-1-1.html for more detailed information.
the major problem we are now facing is that, due to memory limitation, some functions are not able to work properly, leading to calculation failures/errors.
发表于 2018-2-2 02:00:59 | 显示全部楼层
我看到这里的更新日期新一点,http://www.planet-casio.com/Fr/programmes/programme2632-1-eigenmath-fx-Mike-add-in.html#
和中国论坛版本的有什么区别吗
发表于 2018-5-22 22:54:02 | 显示全部楼层
感谢大佬分享,这下计算器可总算舒服了诶
发表于 2018-6-3 18:59:41 | 显示全部楼层
Great
发表于 2018-9-14 09:44:11 | 显示全部楼层
感谢
发表于 2018-9-14 09:45:06 | 显示全部楼层
感谢
发表于 2018-10-12 22:04:42 | 显示全部楼层
必须支持
发表于 2019-12-30 10:34:54 | 显示全部楼层
感谢楼主!!!
发表于 2020-2-8 18:27:35 | 显示全部楼层
支持一下
发表于 2020-3-21 09:59:21 | 显示全部楼层
感谢分享
发表于 2020-12-29 16:56:31 | 显示全部楼层
太厉害了,没想到用了五年的计算器还可以这样
GMT+8, 2025-1-30 07:32 , Processed in 0.079450 second(s), 20 queries .
