查看: 7145|回复: 6
[Nspire] 在Nspire CX上安装4.4版CAS系统
发表于 2017-10-28 22:09:09 | 显示全部楼层 |阅读模式
原贴地址:https://www.reddit.com/r/nspire/comments/6a2cd7/tutorial_install_cas_on_tinspire_cx_works_on/
Hello,
I've been trying to find a way to do this for a while. I finally did, and it seems not a lot of people know about this method. Basically, you will overwrite the manuf and boot1 with a custom image. It's a bootloader for your TI-Nspire, capable of doing a number of things, such as changing the hardware type (as we will use in this tutorial).
我一直在尝试寻找刷CAS的方法,终于成功啦!然而似乎很多人不知道这个方法的样子。这个方法总的来说就是刷入manuf,boot1和自制系统。这三个玩意是你的nspire的引导程序,能够做很多骚事情,比如更改你的硬件类型(本教程就这么玩)
The Computer Algebra System (CAS) will provide you with many helpful functions, such as:
CAS能带给你很多有用的功能
•        Solving for variables
•        Factoring
•        Differentiation
•        Integration
•        And more...
自己看看吧我数学不好不翻译了
This method of installing CAS:
下面是安装CAS的方法
•        works on ANY CX hardware revision V or less
本教程适用于任何硬件版本不大于V的nspire CX
•        works on the newest OS 4.4
本教程将安装最新的(?)4.4版本的OS
•        will work 100% of the time after initial setup
安装本教程安装的CAS系统……嗯,CAS不会失效……就这么翻译吧
•        is very simple to update to a newer OS, and will work as long as Ndless can be installed on the target OS
更新OS很简单,只要在目标OS上安装ndless即可
However, it is quite detailed. Just follow along, and you'll be fine.
教程非常的详细,但只要跟着我做就没问题
WARNING: ALL data will be lost. Please back it up.
警告:所有的数据会丢失
WARNING: Do not use if you have a hardware revision W-Z. This will not work and may brick your calculator.
警告:如果你的CX的硬件版本属于W到Z版,本教程对这种CX没辙,请立刻关掉浏览器,硬要上的话,不仅没有什么用,而且你还有一定可能获得砖头一块
If you would like to know your hardware revision, look on the back of your calculator near the docking port.
如果你想知道你的CX的硬件版本,看看你计算器的屁股后面(尾部接口附近)
You'll see 5 digits P-XXXXD.
你将看到如P-XXXXD的5个字,XXXX是数字,D是字母
The last letter is the hardware revision.
最后一个字母是硬件版本
If you have two letters such as AA or AB, that is a later hardware revision than Z. Those models are not compatible as well.
如果你的计算器上写的是两个字母,那么恭喜你,你的计算器很新,硬件版本实际上高于了Z版,那意味着你也可以关掉本教程了。
All links (download them all now if you want to, and put them in a folder):
所有的下载链接(如果你决定要大干一场了,那么把他们全部下载了,丢在同一个文件夹里)
所有文件打包下载地址(能自己下最新版的最好自己下吧):
链接: https://pan.baidu.com/s/1dEWmCNJ 密码: m3jg
•        4.4 non-CAS OS
•        Ndless
•        nsPartManagic
•        nBoot
•        nsNandMgr+BtMg
•        boot2 4.0.3
•        ControlX
•        4.4 CAS OS
•        CAS Patcher 4.4
译者的补充:本教程的第一步至第四步其实是安装ControlX的教程,如果需要图片参考,可参考本站内的相关教程,但具体操作与本文为准,一些分区的大小,与其他教程的大小有出入,如果按照其他教程操作,我不能准确的预计后果。
Step A: Install OS 4.4
第一步:安装4.4版的OS
1.        Download the 4.4 non-CAS OS.
下载4.4 非CAS版的OS
2.        Install the OS on your calculator (use Student/Teacher/TiLP, drop OS file on calc).
把4.4非CAS版的OS安装到你的计算器(用学生端,老师端,TiLP都可以)
3.        Boot into the OS, select language, etc.
启动你新安装的系统,选择语言等等
Step B: Install Ndless
第二步:安装Ndless
1.        Download Ndless.
下载ndless
2.        Unzip.
解压
3.        Create a new folder on the root level of your calc: ndless.
在计算器的根目录下新建名为“ndless”的文件夹
4.        Drop files in ndless: ndless_resources.tns,ndless_installer_4.4.0.tns.
上传ndless_resources.tns,ndless_installer_4.4.0.tns两个文件到你新建的ndless文件夹里
Step C: Repartition the NAND
第三步:重新给内置存储分区
1.        Download nsPartManagic.
下载nsPartManagic
2.        Transfer nsPartManagic to your calc (in any folder).
上传nsPartManagic到你的计算器(随便什么文件夹都可以)
3.        Install Ndless (open ndless installer file, press [Ctrl]+[W]).
安装Ndless(打开ndless_installer_4.4.0.tns,然后按[Ctrl]+[W])
4.        Open nsPartManagic.
打开nsPartManagic
5.        Press [3] to select BootData (BootD).
按下[3]来修改BootData (BootD)分区
6.        Press [left] to resize BootD until its size matches 0080 pages (the number in parenthesis beside BootD, green).
按下[left]来调整BootD分区大小,直到该分区的大小为0080页(这个数字在BootD旁边的括号里,是绿色的)
7.        Press [esc] to return.
按下[esc]来返回
8.        Press [6] to select Filesystem (FileS).
按下[6]来修改Filesystem (FileS)分区
9.        Press [left] and [right] to adjust the size of ExtnD (NOT FileS: you are moving the filesystem therefore shrinking/growing ExtnD, not the filesystem itself) to 0480 pages (the number in parenthesis beside FileS, gray).
按下[left]and[right]来调整ExtnD分区的大小到0480页(这个数字是在ExtnD分区旁边的括号里,是绿色的。PS:这是本人的做法,亲测可行,但原文说要看FileS的大小)(不要管FileS分区,给我看到ExtnD分区,因为你移动了filesystem分区,所以你才挤出空间给ExtD分区,它的大小才跟着改变)
10.        Press [esc] to return.
按下[esc]返回
11.        Press [esc] to commit. Your calc will warn you that it may cause bricking, etc (which will NOT happen if you followed the instructions). Press [Y] to confirm.
按下[esc]确认,你的计算器将会警告你,如果你确认了,本程序有可能会让你的计算器变砖云云。(诶,如果你严格按照本教程的话,这是不会发生的,如果你有弱智操作的话就……呃)按下确认。
12.        The calculator will reformat the NAND. Once it is done, press[esc] to exit.
计算机接下来会格式化存储芯片,一旦执行完毕,你就可以按来退出程序
13.        Press the reset button. Your calc will reboot, asking for a new OS.
捅py(复位按钮,在计算器背面),你的计算器会重启,并要求安装新的系统
14.        Install OS 4.4, as you downloaded earlier.
像你之前安装4.4版的OS那样再安装一次非CAS版的4.4版的OS
15.        Boot into OS and select language, etc.
启动到系统,设置语言等等
Step D: Install ControlX
第四步:安装ControlX
1.        Reinstall Ndless on calculator (follow Step B steps above)
重新安装给你的计算器安装Ndless(同第二步)
2.        Download these files: nBoot nsNandMgr+BtMg boot2 4.0.3ControlX
下载文件
3.        Unzip all files.
解压所有的文件
4.        Transfer nBoot/manuf.img.tns to any folder,
把nBoot/manuf.img.tns上传到任意文件夹
nsNandMgr/BtMg.tns to /ndless,
把nsNandMgr/BtMg.tns上传到ndless文件夹
tinspirecx_boot2_4.0.3.49.img.tns to any folder,
把tinspirecx_boot2_4.0.3.49.img.tns上传到任意文件夹
controlx.img to any folder.
把controlx.img上传到任意文件夹
5.        Open BtMg. When you see the menu, press [esc]. This completes the file association.
打开BtMg,当你看到了菜单时,按下[esc],完成程序关联的建立(你打开程序就是了,这句话什么意思不重要)
6.        Open manuf.img. This will open in BtMg.
打开manuf.img,这将会跳转到BtMg
7.        Press [4] to select the manuf partition, [2] to flash manuf image.
按下[4]选择到manuf分区,按下[2]刷入manuf镜像
8.        Press [esc] twice to exit.
按下[esc]两次退出
9.        Open tinspirecx_boot2.... This will open in BtMg.
打开tinspirecx_boot2,这将会跳转到BtMg
10.        Press [6] to select the ExtendeD partition, [2] to flash boot2.
按下[6]来选择到ExtnD分区,按下[2]来刷入boot2镜像
11.        Press [esc] twice to exit.
按下[esc]两次退出
12.        Open controlx.img. This will open in BtMg.
打开controlx.img,这将会跳转到BtMg
13.        Press [3] to select the Diags partition, [2] to load ControlX.
按下[3]选择Diags分区,按下[2]来安装ControlX
14.        Press [enter] to select the first position. ControlX will be flashed.
按下[enter]来选择到第一个位置,ControlX将会被刷入
15.        Press [0] to return to main menu.
按下[0]来返回到主菜单
16.        Press [5] to select BootD partition.
按下[5]来选择BootD分区
17.        If you see boot=Boot2 Diags, press [8] to switch it toboot=Diags Boot2, then [0] to exit. Otherwise just press [0]to exit.
如果你看到了boot=Boot2(这是我看到的情况,并不是原文所述情况,这句话在屏幕下方),那么按下[8]来切换到boot=Diags。如果已经是boot=Diags可以直接按下[0]退出菜单了
18.        Press [0] to exit.
按下[0]来退出程序
Step E: Install CAS
第五步:安装CAS系统(关键部分,仔细按教程操作)
1.        Press the reset button. The next screen should show CtrlX 4.43 TI-NspireCXnum.enUSNapoca64M 4.X.XX+ or something similar. If you see this, ControlX is installed and working.
捅菊花重启,接着计算器的屏幕应该显示CtrlX 4.43 TI-NspireCXnum.enUSNapoca64M 4.X.XX或者差不多的东西(在屏幕下方),如果你看到了,那意味着ControlX已经被正确安装并正常工作了
2.        Reset again. This time, hold [ctrl] while pressing reset.
这次,你要一直按住[ctrl],再捅一次菊花重启
3.        The ControlX options will appear. Perform the following (you will need to hold down Ctrl while pressing buttons, unlike in the OS, where you can press Ctrl then press the button):
ControlX选项将会显示,按着接下来的教程操作(你需要同时按下Ctrl键和另一个按键,就像电脑一样,而不是像在计算器系统那样,先按下Ctrl再按另一个按键)
4.        Press [Ctrl+0] to revert to default boot settings
按下 [Ctrl+0] 来恢复默认启动设置
5.        Press [Ctrl+5] to specify min OS 0.0.0
按下 [Ctrl+5] 来指定允许启动的OS的最低版本为0.0.0
6.        Press [Ctrl+8] to specify CAS
按下 [Ctrl+8] 来指定启动CAS系统
7.        Press [0] to reset the calc
按下 [0] 来重启
8.        This time do not hold any buttons. You will arrive at the OS not found screen. Make sure your model at the bottom of the screen reads TI-NspireCXCAS.XXXXXXXXXX64M 0.00.0+. (Where X can be anything.)
这一次启动什么都不要按,你将看到OS未安装的提示,再次确认在你屏幕底下可以看到
TI-NspireCXCAS.XXXXXXXXXX64M 0.00.0+. (X可以是任意的字符)
9.        Download 4.4 CAS OS.
下载4.4带CAS的系统
10.        Use the software to transfer to your calculator. It should be detected as a CX CAS and installed as such. If you get an errorWrong handheld type for OS being sent or OS file is invalid or corrupted, reset and hold [ctrl]. Repeat steps 4-7.
用软件给你的计算器安装4.4 CAS版系统,软件应该检测到你的计算器为CX CAS的型号,然后像你之前装非CAS版系统那样安装CAS版系统。如果你看到机型不匹配或操作系统文件无效或损坏的警告,捅菊花重启,按住[ctrl],重复第五步的4-7步操作
11.        After the OS installs and begins to boot, place an object at the reset button. You will need to press it soon.
高潮来了,在OS安装和启动的过程中,把你的小牙签摆在计算器的菊花前,你接下来很快需要捅菊花重启
12.        Once the progress bar disappears and the black and white screen with the clock icon appears, IMMEDIATELY press reset (within 0.75 or so seconds, if possible). Otherwise, the OS will uninstall itself, and you will have to install it again.
一旦进度条结束,有着时钟图标的黑白屏界面出现了。立刻!立刻!立刻!捅菊花重启(最好在0.75秒内捅下),否则OS将会自毁,你又要重新安装OS
13.        Once it reboots again, you should see the language selection as normal. Do not open anything yet.
一旦计算器完成重启,你应该像之前那样看到语言设置,设置完以后,别瞎唧叭乱操作。
14.        Download CAS Patcher 4.4 and transfer to /ndless/startup.
下载,然后上传到ndless文件夹下的startup文件夹里(如果没有自己建一个)
15.        Reset the calculator.
捅菊花重启
16.        When it boots up, open the calculator and perform some CAS calculations, such as solve() or integration. If you get a reboot, the patcher is not installed correctly. Make sure it's in the right folder.
当计算器启动,打开计算器程序,随便输入几个CAS表达式,比如solve()什么的。如果你的计算器重启了,那就说明之前的补丁没有正确安装,请确认补丁程序放在了正确的文件夹下
17.        If everything works okay, you're done!
如果一切正常,收工!Enjoy!
Congrats: You now have CAS installed on your Nspire CX!
恭喜:你已经给你的计算器安装了CAS了
DISCLAIMER: The word CAS will show on your home screen to indicate you are running a CAS OS. Do not use CAS if it is not allowed where you are using the calculator, such as some exams. If the supervisor sees "CAS" they may cancel your score or dismiss you from the test. If you need to install a non-CAS OS, perform steps E2-E4, E9 (with non-CAS OS), E10.
免责声明:CAS会显示在主屏幕上,表明你运行的是CAS系统,不要在禁用CAS的场合(如某些考试)中秀操作,如果你的考官点亮了捉奸的技能,在考场上活捉你,你被取消成绩,或者禁止参加考试,那和我一点关系都没有。如果你需要恢复非CAS系统,请执行步骤五-2到步骤五-4,步骤五-9(这次是非CAS系统),步骤五-10.
Tell me if this works for you guys. I compiled this from very hard to find tutorials, in hopes that it gets more publicity. CAS on the CX is far from dead. It's alive and thriving.
如果这对你有用,请告诉我(告诉译者我也可以),我非常努力的写这个教程(是啊,我也非常努力的翻译这个教程),希望能宣传,让Nspire CX跑CAS的工作没停止,它还在继续并蓬勃发展(是的,你的愿望实现了,感谢我吧)
最后献上我的信仰
参与人数 2金钱 +12 收起 理由
晨皓小盆友 + 6 很给力!
stj2002 + 6 赞一个!
发表于 2017-11-23 22:43:49 | 显示全部楼层
我要是没认错的话,那个WP是lumia730或735?
 楼主| 发表于 2017-12-16 20:24:22 | 显示全部楼层
恭喜你认错了,那是NuAns NEO
发表于 2017-12-17 15:48:25 | 显示全部楼层
os4.5的能刷吗。。。
发表于 2019-10-9 09:07:38 | 显示全部楼层
时隔两年翻出压箱底的计算器终于刷成功了,感谢。
发表于 2019-10-31 14:28:31 | 显示全部楼层
stigbro 发表于 2017-12-17 15:48
os4.5的能刷吗。。。
亲测4.5能刷,不过最后传的CAS系统安装包必须是4.4的,否则使用CAS公式会一直重启
发表于 2022-4-5 07:52:03 | 显示全部楼层
亲测 v版成功
GMT+8, 2025-1-22 16:53 , Processed in 0.052943 second(s), 19 queries .
