查看: 3665|回复: 2
[fx-9860/9750] SDK的非官方插件---Revolution fx的介绍【E文】
发表于 2009-10-7 14:00:27 | 显示全部楼层 |阅读模式
这个插件来自UCF(http://www.casiocalc.org/)和CASIO Kingdom,似乎有许多能让SDK更强的功能……
Revolution-FX is a open source library created to provide programmers using the CASIO fx-9860 SDK to create better add-ins. It's a must-have for anyone serious in doing some rad programming for the fx-9860G and compatibles. Revolution-FX allows you to:
* Create possible calc-to-calc gaming with access to the serial port
* Create cool graphics with grayscales (upto 8 colors)
* Gather user input and place it into a string
* Fast routines for drawing graphics or sprites to either buffers or to the screen with transparency
* Access the RTC (Real time clock) to either store or retrieve the time
* Change the speed of your CPU by making it faster
* Reset_Calc() eliminates the hassle of having to run another addin just after running one
* Text display with new fonts
* Fast keyboard routines
Plus it's now optimized for speed!
Revolution-FX comes packaged in a setup program eliminating the hassle of having to configure your SDK to detect the library. Download it and try it out. :D
Google直译(翻译水平不够)
革命- FX是一个开放源码库,旨在提供程序员使用卡西欧FX - 9860 SDK来建立更好的加载项。这是一个必须拥有的任何人做的FX一些抗辐射的编程严肃9860G和兼容机。革命效果使您能够:
*创建联机游戏
*创建不同灰度图形(8种颜色)
*收集用户输入,并把它转换为字符串
*快速绘制程序图形或显示渐变或透明屏幕
*访问的RTC(实时时钟),以存储或检索的时间
*改变你的CPU速度使更快
* Reset_Calc()就消除了运行过一个插件再运行另一个插件时的麻烦
*新的文字字体显示
*快速键盘程序
另外它现在已经优化了速度!
革命效果已制作成为安装包以消除需要配置你的SDK来检测程序库的麻烦。下载并试用它。 :D
就是这个东西……虽然我们还不会SDK,但是看起来似乎不错。
revolution-fxv1.0_setup.rar
275.4 KB, 下载次数: 212
发表于 2009-10-7 14:01:56 | 显示全部楼层
这个…………能不能植入classpad的SDK啊~~~
发表于 2009-10-7 14:03:19 | 显示全部楼层
Reset_Calc()???
也需要这么输入命令么。。。那nspire岂不是SDK编程了。。。。。。
GMT+8, 2025-1-31 07:19 , Processed in 0.059139 second(s), 25 queries .
