查看: 4806|回复: 5
[fx-9860/9750] 关于9860连接网络的猜想
发表于 2018-4-5 19:22:02 | 显示全部楼层 |阅读模式
RT,看到外国大神利用arduino来让TI-83/84连入了互联网(Global CALCnet):
Global CALCnet lets you connect your TI graphic calculator to the Internet and use your favorite services like instant messaging and Internet relay chat. It also provides the option of worldwide multiplayer functionality for games ported to the device such as Scorched Earth and Tetris. We looked in on [Christopher Mitchell’s] CALCnet in December when it was being used to create local area networks with the adding machines. He’s taken that up a notch with a helping hand from Arduino. An Arduino board is used to connect the serial communications from the calculator to an Internet connected PC via the Arduino’s USB capabilities.
Think this will waste a lot of time in schools? Unlikely since an Internet connected computer is integral for this system to work. If you have a computer in front of you why waste time on the calculator network? Still, how hard would it be to build a WiFi module that can directly connect them to an access point? That may be a moot point as the Slashdot article that pointed us to global CALCnet also links to a calculator port of DOOM. It runs quite well, as you can see in the video after the break. This is a must-have for anyone owning a TI Nspire that can run it.
(Github项目:https://github.com/KermMartian/gCn,创始人的官方论坛:https://www.cemetech.net/forum/viewtopic.php?t=5754&start=0)
于是猜想9860可否通过类似的方式连接互联网?
 楼主| 发表于 2018-4-5 19:34:42 | 显示全部楼层
作者已经完成了如下内容:
·网络浏览器(https://www.cemetech.net/programs/index.php?mode=file&path=/83plus/asm/programs/gossamer.zip)
·IRC聊天(https://www.cemetech.net/news.php?id=436)
·在线联机多人小游戏(https://www.cemetech.net/news.php?id=414)
·FTP服务器(https://www.cemetech.net/forum/viewtopic.php?t=7096)
这里有一份原理文档(https://www.cemetech.net/programs/index.php?mode=file&path=/text/misc/buildgcn.zip)。
发表于 2018-4-5 21:49:30 | 显示全部楼层
似乎在哪里见过有9860联网的应用
 楼主| 发表于 2018-4-6 13:13:51 | 显示全部楼层
arduinogeek 发表于 2018-4-5 21:49
似乎在哪里见过有9860联网的应用
是kucalc的termfx吗?那玩意是连接两台计算器或计算器和电脑用的,貌似是聊天,但算不上连接互联网
发表于 2018-4-9 07:55:04 | 显示全部楼层
可以的,可以用ESP8266,直接连WiFi,不需要经过PC了
参与人数 1金钱 +1 收起 理由
zyf722 + 1 很给力!
 楼主| 发表于 2018-4-13 14:07:26 | 显示全部楼层
大神能具体讲讲吗?@ZephRay
GMT+8, 2025-2-5 23:02 , Processed in 0.082746 second(s), 22 queries .
