查看: 3735|回复: 14
[聊天] 出TI-82
头像被屏蔽
发表于 2009-12-18 12:16:28 | 显示全部楼层 |阅读模式
提示: 该帖被管理员或版主屏蔽
头像被屏蔽
 楼主| 发表于 2009-12-18 12:18:34 | 显示全部楼层
图片下午奉上~
已经很超值啦!! 同志们~  速速来啊  急用RMB
发表于 2009-12-18 13:30:06 | 显示全部楼层
话说。。。怎么付款呢?。。。你是哪里的。。。
发表于 2009-12-18 13:35:29 | 显示全部楼层
我比较感兴趣~
发表于 2009-12-18 13:39:26 | 显示全部楼层
82有背光吧~
发表于 2009-12-18 13:39:54 | 显示全部楼层
转自:DATAMATH.org
Texas Instruments TI-82
Date of introduction:  1993 Display technology:  LCD dot matrix
New price:   Display size:  8 * 16 characters
Size:  6.8" x 3.1" x 0.85"
Weight:  5.6 ounces Serial No:  13031722
Batteries:  4*AAA + CR1620 (35mA) Date of manufacture:  mth 01 year 1994 (K)
AC-Adapter:   Origin of manufacture:  ** (I)
Precision:  14 Integrated circuits:  CPU: Toshiba T84C00
ASIC: Toshiba TC14L010
ROM: LH531©1993
RAM: SRM2A256
Display: Toshiba T6A04
Memories:
Program steps:  28k Bytes Courtesy of:  Joerg Woerner
The TI-82 was released after the TI-81 and TI-85 and filles the gap between them neatly. The TI-82 introduced a serial inte**ce to connect either two calculators or one calculator and a personal computer. Later Graphing calculators like the TI-83 got a smoother housing, view the restyled TI-82, too.
Dismantling this TI-82 manufactured in January 1994 reveals no surprises. There are a lot of rumors that the TI-82 was based on the TI-85 but we have our doubts: This TI-82 and a TI-81 manufactured in February 1994 use an identical printed circuit board (PCB) with just different RAM and ROM chips populated.
The hardware consists of a Z80 compatible Toshiba T84C00 CPU, a Toshiba TC14L010 ASIC (1.0 micron C-MOS gate array with 1,000 usable gates) for the glue logic, a Sharp LH531©1993 with 128k Bytes capacity and a Suwa Seikosha SRM2264 RAM with 8k Byte capacity for both user programs and user data. Don't miss an early TI-82 using a Toshiba TC541001AF OTP ROM (One Time Programmable ROM), instead the Mask ROM. Recebtly we discovered a TI-82 manufactured in July 1993 with ROM-Verison 10.0 burned into a Sharp LH531©1993 ROM!
The driver circuit of the LC-Display was reduced from three Quad-Flat-Pack chips of the original TI-81 to just one bare Toshiba T6A04 chip mounted on a flexible piece of circuit board attached between the display and the main PCB.
A special "teacher version" called TI-82 VSC combines the standard TI-82 features with a port to connect to a ViewScreen panel via a cable. Placing the panel on the overhead projector enlarges the image of the handheld screen so that each student can follow along.
The TI-82 got in 1995 a slightly modified appearance, please focus on the color of the TI-82 designator.
The TI-82 was mentioned in TI's press release dated August 15, 2002 to celebrate the 35th anniversary of its invention of the electronic calculator.
ROM-Versions:
15.0
16.0
17.0
18.0
You can check the ROM version of your TI-82 using the following key sequence and reading the number on your screen:
[MODE] [ALPHA] [S]
Information provided by ticalc.org and Xavier Andréani.
Exam acceptance:
The TI-82 is permitted (as of September 27, 2007) for use on SAT, ACT, PSAT and AP exams.
The TI-82 is featured in the Texas Instruments Incorporated sales catalog CL-1233 dated 1994.
发表于 2009-12-18 13:41:53 | 显示全部楼层
发表于 2009-12-18 19:45:30 | 显示全部楼层
我可能要买啊
发表于 2009-12-18 21:52:34 | 显示全部楼层
Me too...
头像被屏蔽
 楼主| 发表于 2009-12-22 11:58:12 | 显示全部楼层
ddd?
发表于 2009-12-22 21:33:38 | 显示全部楼层
召唤LZ~~~
发表于 2009-12-23 02:07:49 | 显示全部楼层
这个价格可以了
发表于 2009-12-23 11:32:08 | 显示全部楼层
我想要呀~~~
发表于 2009-12-23 13:50:14 | 显示全部楼层
朔雪X忆 :直接电话联系就OK了
头像被屏蔽
 楼主| 发表于 2009-12-25 14:59:40 | 显示全部楼层
提示: 该帖被管理员或版主屏蔽
GMT+8, 2025-1-23 03:16 , Processed in 0.059120 second(s), 22 queries .
