返回列表 发新帖
楼主: 朔雪X忆
关于TI-nSpire cas的Test mode
发表于 2010-10-12 16:20:38 | 显示全部楼层
http://www.cncalc.org/thread-4919-1-1.html
我发了详细方法。。
发表于 2010-10-12 16:37:16 | 显示全部楼层
恩,方法就是:
To disable Press-to-Test mode through a computer:
If you choose to disable Press-to-Test mode through a computer, you must have TI-Nspire Computer Link software installed on your system. After installing TI-Nspire Computer Link:
• Create a folder on your computer called “Press-to-Test”
• In that folder, place an empty tns document called “Exit Test Mode”. This file is the only file that should be in that folder. Note: folder and file names are case-sensitive
• Send this file to your connected device and you will exit Press-to-Test mode
发表于 2010-10-12 21:31:46 | 显示全部楼层
1 把线插到USB上
2 直接打开,然后选Press-to-Test即可
GMT+8, 2025-1-22 18:54 , Processed in 0.064810 second(s), 17 queries .
