返回列表 发新帖回复
楼主: 不锈钢
[fx-9860/9750] 完了,slim挂了
发表于 2010-2-7 17:30:13 | 显示全部楼层
暴力的修理肯定不行…………………………
 楼主| 发表于 2010-2-7 19:58:26 | 显示全部楼层
这个第一次坏的时候不知道怎么的修好了,然后第二次坏,接着这次又坏
发表于 2010-2-7 19:59:55 | 显示全部楼层
那去维修店修吧~~~~
 楼主| 发表于 2010-2-7 20:12:25 | 显示全部楼层
哪来的维修店
发表于 2010-2-7 20:44:01 | 显示全部楼层
产品包装里面的特约维修店...
发表于 2010-2-8 21:16:31 | 显示全部楼层
寄回CASIO原厂返修- -b
是不是不小心被老师敲过了
 楼主| 发表于 2010-2-8 21:24:11 | 显示全部楼层
没敲
Isn't it "F2"?
"F2" "Ln(" "OPTN" "," "→“ and "↓" correspond to bit 7 of the MPU-port B (on the slim). Maybe bit 7 of port B is broken or there is a weak solder joint. If guarantee has run out, you could disassemble the calc and have a look. It is not very likely, but perhaps you are lucky and the reason is only some dirt or corrosion on the PCB.
以上是卡西欧王国的外国朋友的回答
发表于 2010-2-8 23:10:18 | 显示全部楼层
Boeing 618怎么了啊啊啊
发表于 2010-2-9 10:01:34 | 显示全部楼层
哈哈,你们在卡西欧王国的表现很不错么,被我看到了……
你们去看看我的回帖~~
GMT+8, 2025-1-31 07:12 , Processed in 0.039009 second(s), 16 queries .
