查看: 4008|回复: 6
[fx-9860/9750] fx-9860G系列错误:Build was not successful.
发表于 2020-3-8 22:19:49 | 显示全部楼层 |阅读模式
RT,想编译一下DL2.1,结果错了……
  1. Executing Hitachi SH C/C++ Compiler/Assembler phase
  2. set SHC_INC=F:\fx9860g_sdk_100\software\OS\SH\include
  3. set PATH=F:\fx9860g_sdk_100\software\OS\SH\bin
  4. set SHC_LIB=F:\fx9860g_sdk_100\software\OS\SH\bin
  5. set SHC_TMP=G:\aaaaaaaaa\a\Debug
  6.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 92
  7.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 109
  8.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 126
  9.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 143
  10.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 160
  11.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 177
  12.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 194
  13.         WARNING: The following dependant file(s) do not exist: "dl2_all.h" "fxchslib.h". Line: 211
  14. Executing Hitachi OptLinker04 phase
  15. "F:\fx9860g_sdk_100\software\OS\SH\bin\Optlnk.exe" -subcommand=C:\Users\ADMINI~1\AppData\Local\Temp\hmkFC50.tmp
  16. ** L2300 (E) Duplicate symbol "_AddIn_main" in "G:\aaaaaaaaa\a\Debug\Revolill.obj"
  17. Optimizing Linkage Editor Abort
  18. HMAKE MAKE UTILITY Ver. 1.1
  19. Copyright (C) Hitachi Micro Systems Europe Ltd. 1998
  20. Copyright (C) Hitachi Ltd. 1998
  21.         ERROR: Process failed with return code: 1
  22. Build was not successful.
希望有人解答~
发表于 2020-3-9 07:47:12 | 显示全部楼层
  1. The following dependant file(s) do not exist
看起来是缺少必须的库?
 楼主| 发表于 2020-3-9 12:25:56 | 显示全部楼层
zyf722 发表于 2020-3-9 07:47
看起来是缺少必须的库?
"dl2_all.h" "fxchslib.h"明明在啊……
发表于 2020-3-11 14:28:28 | 显示全部楼层
要把那两个文件放在左边的 header files里
 楼主| 发表于 2020-3-11 19:36:15 | 显示全部楼层
已经放了,不过不是这个的锅吧
5.包含头文件时会出现WARNING: The following dependant file(s) do not exist: “9860g.h”. Line: 74这样的警告,但是头文件能正常编译。
https://hhacker.com/casio-9860g-sdk%e7%bc%96%e7%a8%8b%e4%b8%ad%e9%81%87%e5%88%b0%e7%9a%84%e9%97%ae%e9%a2%98.html
发表于 2020-3-15 13:27:38 | 显示全部楼层
你拿这个文件自己看下吧
dl2.2.zip
1.68 MB, 下载次数: 17
 楼主| 发表于 2020-3-15 19:54:57 | 显示全部楼层
最后出了一些毛病:
  1. -subcommand=C:\Users\ADMINI~1\AppData\Local\Temp\hmk43DD.tmp
结果呢?
  1. Optimizing Linkage Editor Abort
  2. HMAKE MAKE UTILITY Ver. 1.1
  3. Copyright (C) Hitachi Micro Systems Europe Ltd. 1998
  4. Copyright (C) Hitachi Ltd. 1998
  5.         ERROR: Process failed with return code: 1
所以这个“hmk43DD”到底是啥
GMT+8, 2025-1-31 01:29 , Processed in 0.052041 second(s), 21 queries .
