查看: 2804|回复: 2
fx-82ES PLUS II 骇客 - 字符转换器项目 - PoIB Project
发表于 2020-8-2 19:25:26 | 显示全部楼层 |阅读模式
This is a repost of my original post on Baidu Tieba
这是我在铁巴上制作的主题的转贴
First of all, sorry for my bad Chinese. I am using online translation software to translate English into Chinese.
首先,抱歉我的中文不好。我正在使用在线翻译软件将英语翻译成中文。
Principle: After entering the abnormal state mode, the input 9-pixel-high characters can be converted into 6-pixel-high characters.
原理:进入异常状态模式后,可以将输入的9个像素高的字符转换为6个像素高的字符。
Method / Method:
English
When inputting a hackstring in the form:
     (A/B)ANYTEXT)))))
where:
(A/B) is the A/B coefficients, which can be located anywhere in the hackstring before the brackets
ANYTEXT is any arbitrary string , can be as short or as long as you want
))))) are brackets (0920) of a quantity of 5+
Chinese
以以下形式输入hackstring:
     (A / B)ANYTEXT)))))
哪里:
(A / B)是A / B系数,可以放在方括号中的任何位置
ANYTEXT是任何字符串,可以短或长
)))))的括弧范围是5+(0920)
I am publishing my research on this document: [Tencent document] information
https://docs.qq.com/doc/DQ1dnVnhoT1pTaERH
and will continue to make major update posts at  https://community.casiocalc.org/topic/8015-fx-82es-plus-ii-hacking-poib-project/
Thank you for your interest!
我正在此文件上发布我的研究结果:[腾讯文件]信息信息https://docs.qq.com/doc/DQ1dnVnhoT1pTaERH
并将继续在https://community.casiocalc.org/topic/8015-fx-82es-plus-ii-hacking-poib-project/发布主要更新帖子。
感谢您的关注!
Edit: add chinese translation / 添加中文翻译
发表于 2020-8-3 22:09:13 | 显示全部楼层
直接写英文就可以了,不用翻译
发表于 2020-8-5 17:32:25 | 显示全部楼层
加了中文看不懂了
GMT+8, 2024-12-31 00:11 , Processed in 0.057224 second(s), 18 queries .
