查看: 2890|回复: 6
Windows上不使用ExistOS_Updater烧录HP39GII ExistOS的方法
发表于 2022-8-25 02:31:38 | 显示全部楼层 |阅读模式
准备edb.exe与sb_loader.exe,如此前未烧录过OSLoader,则首先使用命令:
.\sb_loader.exe -f OSLoader.sb
将OSLoader写入内存。接下来在保持上电的同时重新连接计算器,使用:
.\edb.exe -r -s -f .\OSLoader.sb 1408 b
将OSLoader写入闪存。之后通过:
.\edb.exe -r -s -f .\ExistOS.sys 1984
将系统写入闪存。
发表于 2022-11-10 11:47:13 | 显示全部楼层
windows7 64位操作系统,在官网下载了edb.exe与sb_loader.exe,但运行均提示不支持的操作系统,怎么解决呢?
发表于 2022-11-10 15:45:58 | 显示全部楼层
只能换台有win10的机器试试了
发表于 2022-11-10 17:23:45 来自手机 | 显示全部楼层
molucule 发表于 2022-11-10 15:45
只能换台有win10的机器试试了
win10试了也不行,提示找不到Qt6Widgets.dll,网上下了一个,还是出错。
发表于 2022-11-12 20:58:09 | 显示全部楼层
Hello.
I would gladly have newsed about this very promising project, but it immediately crashes my HP 39gII.
Note this is my first attempt at installing ExistOS.
I followed the steps under the Flashing with automated tools section in the english readme.
I used ExistOS Updater under Windows 10 64 bits with both images from the latest build 77 release.
And the only thing I get is a "system panic" screen :
Any help will be appreciated. Should I retry with different files or tools ? Which ones ?
Thank you very much.
 楼主| 发表于 2022-11-15 22:26:50 | 显示全部楼层
Try v0.6.8. System can’t run correctly without matched boot loader and OS. Those in builds named as build xx may have a newer version of OS than boot loader and can’t correctly start.
发表于 2022-11-19 09:58:58 | 显示全部楼层
mbox2008 发表于 2022-11-10 11:47
windows7 64位操作系统,在官网下载了edb.exe与sb_loader.exe,但运行均提示不支持的操作系统,怎么解决呢 ...
我这边也是Windows7 64 专业版,可以使用,不知是不是要安装最新.net?
GMT+8, 2025-1-22 17:50 , Processed in 0.066890 second(s), 18 queries .
