返回列表 发新帖回复
楼主: universalcwt
[Nspire] 求助!nspire CX启动时system Error如何处理
 楼主| 发表于 2022-10-16 22:17:13 | 显示全部楼层
mrlgs 发表于 2022-10-12 20:05
我以前的经验是刷的boot2低于1M的没有成功的
刷了你的这个还是卡在一半,显示是这样的
Boot Loader Stage 1 (4.0.1.43)
Build: 2015/7/20, 14:47:25
Copyright (c) 2006-2015 Texas Instruments Incorporated
Using production keys
Last boot progress: 46060
Available system memory: 28072
Checking for NAND: NAND Flash ID: Generic 1 GBit (0xA1)
SDRAM size: 64 MB
External Power Detected: VBUS.
SDRAM memory test:   Pass
Clearing SDRAM...Done.
Clocks:  CPU = 156MHz   AHB = 78MHz   APB = 39MHz
Boot option: Download Boot2
Keypad request - installing BOOT2 software...
Checking battery level.
Battery level is OK.
Ready to download BOOT2 software...
Begin XMODEM file transfer.
Erasing BOOT2 partition.
Updating BOOT2 partition with 1212416 bytes.
BOOT2 partition has been updated.
Restarting now.
Last boot progress: 1075
SDRAM size: 64 MB
Boot option: Normal
Loading from BOOT2 partition...
100%
BOOT1: loading complete (294 ticks), launching <BOOT2> image.
Boot Loader Stage 2 (4.0.3.49)
Build: 2015/11/6, 12:44:23
This device is a CXCR.
TI_PM_SetShipMode:  FALSE
GP LCD.
Initializing graphics subsystem.
GP LCD.
Boot option: Normal
Initializing filesystem.
  Skipping NAND workaround.
Datalight Reliance v2.10.1150
Copyright (c) 2003-2006 Datalight, Inc.
Datalight FlashFX Pro v3.00 Build 1358
Nucleus Edition for ARM9
Copyright (c) 1993-2006 Datalight, Inc.
Patents: US#5860082, US#6260156.
FB NAND Flash Controller
FlashFX: 0: Factory Bad Block (0x06000000)
发表于 2022-10-17 08:38:12 | 显示全部楼层
改了boot2 的分区大小了。应该是废了主板,换个主板吧
 楼主| 发表于 2022-10-17 15:03:37 | 显示全部楼层
问下是哪一段看出大小变了呢
发表于 2022-10-19 16:47:05 | 显示全部楼层
universalcwt 发表于 2022-10-17 15:03
问下是哪一段看出大小变了呢
是不是提示坏块太多,我是解决不了了,要是我遇上这种情况,只能拆芯片了
 楼主| 发表于 2023-2-27 20:01:03 | 显示全部楼层
有人嘛
发表于 2023-2-28 15:36:47 | 显示全部楼层
还没解决吗
 楼主| 发表于 2023-3-1 13:29:00 | 显示全部楼层
还没,我正在研究是不是硬件问题
GMT+8, 2025-1-22 18:05 , Processed in 0.080928 second(s), 17 queries .
