查看: 1850|回复: 4
[Nspire] 咨询各位大神,绿豆nspire 右上角亮绿灯表示什么意思
发表于 2023-3-5 21:09:24 | 显示全部楼层 |阅读模式
无法进入系统,进度条到一半就白屏了,通电右上角亮绿灯,正面看是左上角,按开机键这个灯就灭掉
但是不进系统
 楼主| 发表于 2023-3-5 21:10:30 | 显示全部楼层
各种组合键都用了,什么也进不去
 楼主| 发表于 2023-3-6 08:56:18 | 显示全部楼层
好不容易进入刷机boot2 界面竟然是下面的错误
Last boot progress: 41864
Clocks:  CPU = 90MHz   AHB = 45MHz   APB = 22MHz
Available system memory: 37292
Checking for NAND: NAND Flash ID: Samsung K9F5608Q0C
PM is turning the device OFF
PM has turned the device ON
SDRAM memory test:   Pass
Clearing SDRAM...Done.
Boot option: Download Boot2
Keypad request - installing BOOT2 software...
Checking battery level.
Battery level is OK.
Ready to download BOOT2 software...
Begin XMODEM file transfer.
Download error: 255BOOT1 Error:
Halting boot due to download error.Shutdown: Critical Voltage detected.
 楼主| 发表于 2023-3-6 08:57:58 | 显示全部楼层
直接开机是这样的
Boot option: Normal
Loading BOOT2 software...
99%
BOOT1: loading complete (309 ticks), launching image
 楼主| 发表于 2023-3-6 14:56:17 | 显示全部楼层
Boot Loader Stage 1 (1.1.8916)
Build: 2007/4/23, 23:37:16
Copyright (c) 2006, 2007 Texas Instruments Incorporated
Using production keys
Last boot progress: 0
Boot option: Normal
99%
BOOT1: loading complete (299 ticks), launching image.
GMT+8, 2025-1-22 17:59 , Processed in 0.064500 second(s), 21 queries .
