查看: 4129|回复: 3
国外牛人。。。拆Voyage 200。。。
发表于 2010-3-13 11:59:34 | 显示全部楼层 |阅读模式
http://jhproject.wordpress.com/2008/09/25/el-**-no-sabe-lo-que-tiene-programando-en-ti-voyage-200/
震惊。。。
可惜不知道是哪国文字。。。。。。
正面:
背面:
 楼主| 发表于 2010-3-13 12:00:31 | 显示全部楼层
CPU还是Motorola 68000
http://en.wikipedia.org/wiki/Motorola_68000
The 68EC000 is a microprocessor from Motorola. It is a low-cost version of the Motorola 68000, designed for embedded controller applications. The 68EC000 can have either a 8-bit or 16-bit data bus, switchable at reset.[8]
The processors are available in a variety of speeds including 8 and 16 MHz configurations, producing 2,100 and 4,376 Dhrystones each. These processors have no floating point unit and it is difficult to implement an FPU coprocessor (MC68881/2) with one because the EC series lacks necessary coprocessor instructions.
The 68EC000 was used as a controller in many audio applications, including Ensoniq musical instruments and sound cards where it was part of the MIDI synthesizer.[9] On Ensoniq sound boards, the controller provided several advantages compared to compe**s without a CPU onboard. The processor allowed the board to be configured to perform various audio tasks, such as MPU-401 MIDI synthesis or MT-32 emulation, without the use of a TSR program. This improved software compatibility, lowered CPU usage, and eliminated host system memory usage.
The Motorola 68EC000 core was later used in the m68k-based DragonBall processors from Motorola/Freescale.
It also was used as a sound controller in the Sega Saturn game console, and as a controller for the HP JetDirect Ethernet controller boards for the mid-90s LaserJet printers.
 楼主| 发表于 2010-3-13 12:01:12 | 显示全部楼层
compe t i t o rs干嘛屏蔽?
发表于 2010-3-13 16:10:33 | 显示全部楼层
你拆拆nspire吧
GMT+8, 2025-1-22 16:00 , Processed in 0.088929 second(s), 22 queries .
