查看: 4583|回复: 9
[聊天] 大家用啥显卡
发表于 2010-4-4 12:57:33 | 显示全部楼层 |阅读模式
大家用啥显卡
将3D测试的分数截图发上来
我的显卡信息:
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
    GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
    GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
    GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
    GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_frame_usage,
    GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
OpenGL vendor string: VIA Technology
OpenGL renderer string: Mesa DRI UniChrome (KM400) 20060710 x86/MMX+/3DNow!+/SSE
OpenGL version string: 1.2 Mesa 7.6
OpenGL extensions:
    GL_ARB_draw_buffers, GL_ARB_imaging, GL_ARB_multisample,
    GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_texture_compression,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_mirrored_repeat, GL_ARB_transpose_matrix,
    GL_ARB_vertex_buffer_object, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
    GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array, GL_EXT_convolution,
    GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
    GL_EXT_histogram, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels,
    GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
    GL_EXT_secondary_color, GL_EXT_separate_specular_color,
    GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_lod_bias,
    GL_EXT_texture_object, GL_EXT_vertex_array, GL_APPLE_packed_pixels,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_MESA_window_pos, GL_NV_blend_square,
    GL_NV_light_max_exponent, GL_NV_texgen_reflection, GL_OES_read_format,
    GL_SGI_color_matrix, GL_SGI_color_table, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
Linux底下没啥通用的测试软件,就用glxgears代替吧
发表于 2010-4-4 15:31:58 | 显示全部楼层
1950PRO
发表于 2010-4-4 18:01:05 | 显示全部楼层
780G
发表于 2010-4-4 18:01:25 | 显示全部楼层
还有一块geforce2 mx400
发表于 2010-4-4 19:57:25 | 显示全部楼层
台式fx-5200 128mb
还有个gt-240m 1024mb
都不算太好。。
发表于 2010-4-5 20:18:48 | 显示全部楼层
intel g31 真的是杯具啊
 楼主| 发表于 2010-4-5 22:21:55 | 显示全部楼层
大家算算我的显卡在如此简单的画面之下的帧率吧,图片里的终端里头有数据。
红色的字是我的显卡型号
发表于 2010-4-6 18:18:20 | 显示全部楼层
还Ubuntu啊……
打算买个GTX480……
等暑假啦~
发表于 2010-4-30 22:24:21 | 显示全部楼层
杯具的64MB显存显卡
 楼主| 发表于 2010-4-30 22:29:56 | 显示全部楼层
杯具的64MB显存显卡
maox2223 发表于 2010-4-30 22:24
咱们是兄弟啊。。。
GMT+8, 2025-1-15 23:37 , Processed in 0.060069 second(s), 24 queries .
