查看: 9315|回复: 22
其实casio最强的图形机,不是cp,而是...
发表于 2010-8-5 09:10:21 | 显示全部楼层 |阅读模式
 楼主| 发表于 2010-8-5 09:15:26 | 显示全部楼层
Model        CASSIOPEIA A-22T / A-21S
Display        640x240 dots FSTN LCD,
4 grayscale monochrome
CPU        SH3(80MHz)
RAM        16MB
Built-in
Flash Memory        2MB
Interfaces        RS-232C 115.2kbps
Data communication jack
PC card slot (A-22T only)
CompactFlash(TM) / ROM card slot
Infrared port (IrDA-compatible protocol):
Communication distance: 10 to 70cm
Maximum Speed: 115.2kbps
Power Supply
Main:        Two AA-size alkaline batteries LR6 (AM3)
A-B11LT Rechargeable Battery Pack
(lithium ion batteries) [Option]
AD-C50200 AC Adapter [Option]
Backup:        One CR2032 lithium ion battery
Power
Consumption        2.5W
Battery Life
Main:         AA-size alkaline batteries:
         Approximately 23 hours
Repeating one minute of input in Pocket Word, followed by 10 minutes of input standby
Approximately 10 hours
Input of 90 characters per minute in Pocket Word
Rechargeable Battery Pack:
         Approximately 15 hours
Approximately 7 hours
*Main battery life is shortened by use of a modem card or PC card.
Backup:        Approximately 5 years
When main batteries are replaced immediately after display of the message: "Your main batteries are running very low on power. Please change the batteries at your next opportunity."
Approximately 3 weeks
When no power is supplied from the main batteries.
Operating Temperature        0oC to 40oC(32oF to 104oF)
Charging Temperature        10oC to 35oC(50oF to 95oF)
Dimensions HxWxD        Folded: 27.5x185x94mm(1.1"x7.3"x3.7")
Unfolded: 29.5x185x180(1.2"x7.3"x7.1")
Weight        A-22T: 455g(16 oz) / A-21S: 470g(16.6 oz)
(with two-AA-size alkaline batteries)
好吧其实更接近于pda
发表于 2010-8-5 09:17:46 | 显示全部楼层
好像是Classpad 的前身
发表于 2010-8-5 09:57:00 | 显示全部楼层
现在很难买到。。
发表于 2010-8-5 10:28:19 | 显示全部楼层
那不就是一个PPC吗?Windows CE界面,熟悉的Start按钮……
发表于 2010-8-5 10:29:37 | 显示全部楼层
handheld PC……上面写着的
还有,那个东西其实就是Maple for PPC
发表于 2010-8-5 11:05:23 | 显示全部楼层
还是感觉cp更厉害.
发表于 2010-8-5 11:05:41 | 显示全部楼层
maple 13更厉害.
可惜那个是maple 5
发表于 2010-8-5 12:10:33 | 显示全部楼层
这个计划好像停止了
发表于 2010-8-5 13:08:08 | 显示全部楼层
那个3D好像质量不是很高,和CP不能比
发表于 2010-8-5 13:59:04 | 显示全部楼层
屏幕越小质量越高
发表于 2010-8-5 19:11:36 | 显示全部楼层
我还是觉得microsoft math最好用
发表于 2010-8-5 19:17:20 | 显示全部楼层
屏幕越小质量越高
zhj 发表于 2010-8-5 13:59
不一定吧
 楼主| 发表于 2010-8-5 21:36:59 | 显示全部楼层
12# CyEvXa
MM的图形功能很渣。
CAS一般,factor有的不行
发表于 2010-8-5 22:09:15 | 显示全部楼层
真的买不到了- -
发表于 2010-8-11 20:18:45 | 显示全部楼层
无语
发表于 2010-8-12 14:12:57 | 显示全部楼层
12# CyEvXa
MM的图形功能很渣。
CAS一般,factor有的不行
urill 发表于 2010-8-5 21:36
3.0的不错了
发表于 2010-8-12 14:14:04 | 显示全部楼层
说实话,Microsoft 除了Windows与Math造的不错,其它程序简直不能与其它公司的相同程序比
发表于 2010-9-30 19:08:50 | 显示全部楼层
期待的机型
发表于 2011-6-30 22:04:18 | 显示全部楼层
我有一个  a-22t 有两张cf卡 一个是maple v 一个是 几何画板
GMT+8, 2025-1-31 07:51 , Processed in 0.056986 second(s), 22 queries .
