查看: 4226|回复: 6
[fx-9860/9750] [HELP!!!!]9750闪存优化终止的异常,无法正常使用!
发表于 2011-3-18 22:21:28 | 显示全部楼层 |阅读模式
我的9750在周一时中午使用时,退出e-act时卡死。无奈摁了Restart
发现进不了主界面了
好像是9750刷机文档中提到的界面
If even this does not happen any more, start the primary OS updater by resetting the calculator with the P-button while having P104 closed or as P104 is not easily reachable with a GII (9860 as well as 9750), trigger the primary emergency OS update on the Gipadously holding down F2, 4 and AC/ON and pressing the RESTART-button (the calc should show a blank display after releasing the keys) and finally pressing 9 and x consecutively.
我试着做了,好像没有用
此界面没有任何反应,无法关机,只显示繁忙提示符(小黑块)
请大家帮我!!
发表于 2011-3-18 22:35:47 | 显示全部楼层
9860g slim报废满一周年+1个月的路过
参与人数 1金钱 +1 收起 理由
diameter + 1 ...
 楼主| 发表于 2011-3-19 11:48:11 | 显示全部楼层
没人吗?
发表于 2011-3-19 13:16:40 | 显示全部楼层
电池拆了重装?
 楼主| 发表于 2011-3-19 16:22:32 | 显示全部楼层
电池拆了重装?
GWHBOB 发表于 2011-3-19 13:16
没用,重装后自动重启
发表于 2011-3-19 18:13:02 | 显示全部楼层
拆机,戳UPDATE和RESET
发表于 2011-3-19 22:42:42 | 显示全部楼层
联机重刷?
GMT+8, 2025-1-2 22:31 , Processed in 0.543613 second(s), 21 queries .
