查看: 9604|回复: 18
[fx-9860/9750] CASIO KINGDOM真的衰退了——已经改版为Casio Scene
发表于 2012-4-14 21:06:51 | 显示全部楼层 |阅读模式
果然CASIO KINGDOM这个当年统治一方的王国走向了解体,取而代之的是新的CASIO SCENE。为王国的崩溃默哀吧,还有那上面数以千计的程序呢……一并下载不能了……还有那些讲授高深技巧的帖子………………这和原站长SeanTan的退出显然有很大的关系,新站主matt也没有能尽到自己的责任啊。。。
发表于 2012-4-14 21:26:50 | 显示全部楼层
可惜啊
发表于 2012-4-14 21:31:27 | 显示全部楼层
唉……确实很可惜啊
发表于 2012-4-14 21:32:45 | 显示全部楼层
太可惜了...
发表于 2012-5-5 15:43:21 | 显示全部楼层
问一下,上面的软件还能下载到么?
发表于 2012-6-2 19:08:04 | 显示全部楼层
hello chinese casio community!
As some of you already know, the casio kingdom now is casio-scene.
Im the new admin and im uploading the old files to the new website
this is the #1 international casio calculator development community. In this moment we host about than 400 files, and very good documentations like syscalls docs by simonlo. And in next days i will lauch our wiki :D
i would like invite some of this good chinese developers to join us and upload their files like  oncalc C compiler, doodle jump, etc... to the english community
in this site there are some CK files, there are any problem is i upload some fxems files to CK? 99.9% of the english community users doesnt know chinese, and never will get a orient yourself site in Chinese. i will give credits to developers like link to forum topic, and i put the name of the author!
if you join us but dont know enough english, i can try help you with descriptions (google translator + some english knowledge)
regards
helder7
(sorry for i write in english)
发表于 2012-6-2 22:32:05 | 显示全部楼层
ls是casio scene的管理员?
发表于 2012-6-3 08:41:10 | 显示全部楼层
ls是casio scene的管理员?
tian 发表于 2012-6-2 22:32
是的!!!
Yes
发表于 2012-6-3 09:30:36 | 显示全部楼层
this is the #1 internation ...
helder7 发表于 2012-6-2 19:08
But you can see,it's big problem for this forum that we can't find enough developer to make application. Most of users are busy studying.
发表于 2012-6-3 10:31:12 | 显示全部楼层
6# helder7
I wonder if you have a good way about the SH4A —— the newest 9860 , which the SDK couldn't work well.
发表于 2012-6-3 10:53:35 | 显示全部楼层
http://www.casio-scene.com/downloads.php?do=file&id=270
一份强大的文档!
记录了很多syscall,9860的扩展性可以无限发挥了。。
发表于 2012-6-3 20:52:56 | 显示全部楼层
@wtof1996, for the new fx9860 with sh4 processor, you only need change some syscalls (available in simonlother's docs). The  SDK work well, only the syscalls are different.
发表于 2012-6-3 23:42:44 | 显示全部楼层
标题
12# helder7
OK,I'll have a try.(Maybe after a large program on TI-Nspire).
But what about Revolution-FX? That's very impirtant.
And if it's OK for someone to edit a new header file for new 9860?I have no time to do this.And a new header or library will be convenient.
发表于 2012-6-4 00:14:51 | 显示全部楼层
i think the revolution fx works in sh4 processor because the syscalls used in revolution fx is syscalls to set grayscales on screen and in the latest fx9860 (sh4) the screen model is the same
however, if revolution fx doesnt work, we have other grayscale lib -> http://www.casio-scene.com/showt ... X-9680-GrayscaleLib
if you want use one monocrom... lib you can use this -> http://www.top-progcasio.com/programme-1503.html (by pierrotll)
发表于 2012-6-4 01:22:54 | 显示全部楼层
14# helder7
Thank you very much.
P.S.: Wudy,要不你来试试吧,或者看看能不能把新的syscall写一个库,我最近在忙Lua,也许暑假我和imath,557一起开发新的2D Math g1a版本可以用的到
发表于 2012-6-4 02:21:18 | 显示全部楼层
i dont know enought chinese, but you talked in lua right?
there already are one Lua interpreter for fx9860
http://www.planet-casio.com/Fr/l ... iciel&showid=83
is in french, but in summer we will translate the docs to english and put in in our wiki (we are dev a wiki in collaboration with the french community planet-casio)
发表于 2012-6-4 09:34:26 | 显示全部楼层
14# helder7
wtof1996 发表于 2012-6-4 01:22
不用的。。2d math应该就只用计算和绘图吧,SDK提供的函数够用了。
而且我手边也没用新版,不方便测试。
发表于 2012-6-4 13:28:37 | 显示全部楼层
16# helder7
I am doing some work for TI-Nspire 's Lua,and it has great  different between the standard Lua.
Maybe I will have a try after I  will  have  done the hard work.
 楼主| 发表于 2012-6-4 14:20:58 | 显示全部楼层
6# helder7
Very Cool!
Very glad to see the communication between Chinese and foreign calculator fans. Our forum are the biggest calculator forum in China.
I am going to have College Entrance Examination and maybe next year I can learn enough knowledge for the CASIO development.
By the way, in order to communciate better, you really need a friend who can speak Chinese or you can learn by yourself.
Good luck!
GMT+8, 2025-1-22 21:07 , Processed in 0.066561 second(s), 22 queries .
