查看: 8258|回复: 11
自制开源计算器OurCalc——进展贴7 更新视频
发表于 2012-4-29 07:54:47 | 显示全部楼层 |阅读模式
2012.4.29 7:51
    昨天晚上一直在编译Qt4.8,我的电脑(Core 2 Duo 1.6GHz+2GB RAM)会编译了2个钟头!今天早上测试,它只丢给我一句:FATAL:kernel too old.一查,我的文件系统用的libc是2.9版本的,要求内核版本2.6.32以上,而我现在测试用系统内核为2.6.30,之前3.3内核linuxrc一直执行不起来,所以就没继续研究。看来问题总是要面对的。现在在移植linux 2.6.39
2012.4.29 9:34
    太激动了,3.3.4内核终于启动成功了(显示出控制台)!现在继续移植驱动
完整启动信息:
  1. Start Linux ...
  2. Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00300000 ... Copy Kernel to SDRAM done,NOW, Booting Linux......
  3. Uncompressing Linux... done, booting the kernel.
  4. Booting Linux on physical CPU 0
  5. Linux version 3.3.4-nbzwt (root@nbzwt-x61t) (gcc version 4.4.3 (ctng-1.6.1) ) #8 Sun Apr 29 09:32:01 CST 2012
  6. CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
  7. CPU: VIVT data cache, VIVT instruction cache
  8. Machine: SMDK2440
  9. ATAG_INITRD is deprecated; please update your bootloader.
  10. Memory policy: ECC disabled, Data cache writeback
  11. CPU S3C2440A (id 0x32440001)
  12. S3C24XX Clocks, Copyright 2004 Simtec Electronics
  13. S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
  14. CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
  15. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
  16. Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0,115200
  17. PID hash table entries: 256 (order: -2, 1024 bytes)
  18. Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
  19. Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
  20. Memory: 64MB = 64MB total
  21. Memory: 60212k/60212k available, 5324k reserved, 0K highmem
  22. Virtual kernel memory layout:
  23.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  24.     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
  25.     vmalloc : 0xc4800000 - 0xff000000   ( 936 MB)
  26.     lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
  27.     modules : 0xbf000000 - 0xc0000000   (  16 MB)
  28.       .text : 0xc0008000 - 0xc0427884   (4223 kB)
  29.       .init : 0xc0428000 - 0xc0446000   ( 120 kB)
  30.       .data : 0xc0446000 - 0xc046d5e0   ( 158 kB)
  31.        .bss : 0xc046d604 - 0xc0495a74   ( 162 kB)
  32. SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
  33. NR_IRQS:85
  34. irq: clearing pending ext status 00080000
  35. irq: clearing subpending status 00000003
  36. irq: clearing subpending status 00000002
  37. Console: colour dummy device 80x30
  38. Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
  39. pid_max: default: 32768 minimum: 301
  40. Mount-cache hash table entries: 512
  41. CPU: Testing write buffer coherency: ok
  42. Setting up static identity map for 0x30328f38 - 0x30328f90
  43. gpiochip_add: registered GPIOs 0 to 23 on device: GPIOA
  44. gpiochip_add: registered GPIOs 32 to 47 on device: GPIOB
  45. gpiochip_add: registered GPIOs 64 to 79 on device: GPIOC
  46. gpiochip_add: registered GPIOs 96 to 111 on device: GPIOD
  47. gpiochip_add: registered GPIOs 128 to 143 on device: GPIOE
  48. gpiochip_add: registered GPIOs 160 to 167 on device: GPIOF
  49. gpiochip_add: registered GPIOs 192 to 207 on device: GPIOG
  50. gpiochip_add: registered GPIOs 224 to 234 on device: GPIOH
  51. gpiochip_add: registered GPIOs 256 to 271 on device: GPIOJ
  52. NET: Registered protocol family 16
  53. S3C Power Management, Copyright 2004 Simtec Electronics
  54. S3C2440: Initialising architecture
  55. S3C2440: IRQ Support
  56. S3C244X: Clock Support, DVS off
  57. bio: create slab <bio-0> at 0
  58. SCSI subsystem initialized
  59. usbcore: registered new interface driver usbfs
  60. usbcore: registered new interface driver hub
  61. usbcore: registered new device driver usb
  62. Advanced Linux Sound Architecture Driver Version 1.0.24.
  63. NET: Registered protocol family 2
  64. IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
  65. TCP established hash table entries: 2048 (order: 2, 16384 bytes)
  66. TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
  67. TCP: Hash tables configured (established 2048 bind 2048)
  68. TCP reno registered
  69. UDP hash table entries: 256 (order: 0, 4096 bytes)
  70. UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
  71. NET: Registered protocol family 1
  72. RPC: Registered named UNIX socket transport module.
  73. RPC: Registered udp transport module.
  74. RPC: Registered tcp transport module.
  75. RPC: Registered tcp NFSv4.1 backchannel transport module.
  76. NetWinder Floating Point Emulator V0.97 (extended precision)
  77. JFFS2 version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
  78. ROMFS MTD (C) 2007 Red Hat, Inc.
  79. msgmni has been set to 117
  80. io scheduler noop registered
  81. io scheduler deadline registered
  82. io scheduler cfq registered (default)
  83. Console: switching to colour frame buffer device 30x40
  84. fb0: s3c2410fb frame buffer device
  85. Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
  86. s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
  87. console [ttySAC0] enabled
  88. s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
  89. s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
  90. lp: driver loaded but no devices found
  91. ppdev: user-space parallel port driver
  92. brd: module loaded
  93. loop: module loaded
  94. S3C24XX NAND Driver, (c) 2004 Simtec Electronics
  95. s3c24xx-nand s3c2440-nand: Tacls=1, 10ns Twrph0=3 30ns, Twrph1=1 10ns
  96. s3c24xx-nand s3c2440-nand: NAND ECC disabled
  97. NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
  98. NAND_ECC_NONE selected by board driver. This is not recommended!
  99. Scanning device for bad blocks
  100. Bad eraseblock 1111 at 0x000008ae0000
  101. Bad eraseblock 1274 at 0x000009f40000
  102. Bad eraseblock 1361 at 0x00000aa20000
  103. Bad eraseblock 1988 at 0x00000f880000
  104. Creating 3 MTD partitions on "NAND":
  105. 0x000000000000-0x000000040000 : "UBoot"
  106. 0x000000200000-0x000000500000 : "Kernel"
  107. 0x000000500000-0x000010000000 : "Yaffs2"
  108. dm9000 Ethernet Driver, V1.31
  109. ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  110. s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
  111. s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
  112. s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
  113. hub 1-0:1.0: USB hub found
  114. hub 1-0:1.0: 2 ports detected
  115. usbcore: registered new interface driver libusual
  116. usbcore: registered new interface driver usbserial
  117. USB Serial support registered for generic
  118. usbcore: registered new interface driver usbserial_generic
  119. usbserial: USB Serial Driver core
  120. USB Serial support registered for FTDI USB Serial Device
  121. usbcore: registered new interface driver ftdi_sio
  122. ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
  123. USB Serial support registered for pl2303
  124. usbcore: registered new interface driver pl2303
  125. pl2303: Prolific PL2303 USB to serial adaptor driver
  126. mousedev: PS/2 mouse device common for all mice
  127. S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
  128. s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq disabled
  129. ALSA device list:
  130.   No soundcards found.
  131. TCP cubic registered
  132. NET: Registered protocol family 17
  133. drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
  134. yaffs: dev is 32505858 name is "mtdblock2" rw
  135. yaffs: passed flags ""
  136. VFS: Mounted root (yaffs filesystem) on device 31:2.
  137. Freeing init memory: 120K
  138. hwclock: can't open '/dev/misc/rtc': No such file or directory
  139. input_polldev: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  140. insmod: can't insert '/lib/input-polldev.ko': invalid module format
  141. /bin/qt4: line 32: syntax error: unexpected "else"
  142. mac80211: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  143. insmod: can't insert '/lib/mac80211.ko': invalid module format
  144. rt2x00lib: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  145. insmod: can't insert '/lib/rt2x00lib.ko': invalid module format
  146. rt2x00usb: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  147. insmod: can't insert '/lib/rt2x00usb.ko': invalid module format
  148. rt73usb: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  149. insmod: can't insert '/lib/rt73usb.ko': invalid module format
  150. zd1211rw: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  151. insmod: can't insert '/lib/zd1211rw.ko': invalid module format
  152. ov9650: version magic '2.6.30.4-EmbedSky mod_unload ARMv4 ' should be '3.3.4-nbzwt mod_unload ARMv4 p2v8 '
  153. insmod: can't insert '/lib/ov9650.ko': invalid module format
  154. ifconfig: SIOCGIFFLAGS: No such device
  155. open device leds: No such file or directory
  156. ifconfig: SIOCSIFHWADDR: No such device
  157. ifconfig: SIOCSIFADDR: No such device
  158. route: SIOCADDRT: Network is unreachable
  159. [01/Jan/1970:00:00:10 +0000] boa: server version Boa/0.94.13
  160. [01/Jan/1970:00:00:10 +0000] boa: server built Jul 29 2009 at 14:27:34.
  161. [01/Jan/1970:00:00:10 +0000] boa: starting server pid=1018, port 80
  162. Please press Enter to activate this console.
  163. [root@EmbedSky /]#
2012.4.30 10:39
QT4演示视频正在上传
2012.4.30 11:17
http://player.youku.com/player.php/sid/XMzg5MDg4NTgw/v.swf
发表于 2012-4-29 08:42:31 | 显示全部楼层
加油
发表于 2012-4-29 10:24:30 | 显示全部楼层
加油
发表于 2012-4-29 17:19:34 | 显示全部楼层
加油!
发表于 2012-4-29 18:41:07 | 显示全部楼层
给个开机界面好不好?
发表于 2012-4-29 18:41:35 | 显示全部楼层
加油!
发表于 2012-4-29 19:26:26 | 显示全部楼层
不错,激动人心!
发表于 2012-4-29 20:09:47 | 显示全部楼层
求开机界面……
发表于 2012-4-29 22:07:05 | 显示全部楼层
求整机图片
发表于 2012-4-30 16:27:27 | 显示全部楼层
发表于 2012-4-30 18:19:44 | 显示全部楼层
LS??
发表于 2012-4-30 18:27:29 | 显示全部楼层
11# 936854586
lss的意思其实就是がんばって(加油)...
GMT+8, 2025-1-22 20:56 , Processed in 0.073591 second(s), 22 queries .
