查看: 7263|回复: 13
[Nspire] NSPIRE CAS CX 3.2版发布推迟原因
发表于 2012-6-6 21:28:05 | 显示全部楼层 |阅读模式
NSPIRE CAS CX 3.2版发布推迟原因是中文OS兼容性的问题。中文版的软件内部已经开始测试,但是不太稳定,与无线AP连接时有延迟,不过增加了lua功能.TI官方提供的工具就不需要了。5月31日,本人参加了在上海的LUA培训.
发表于 2012-6-6 22:02:42 | 显示全部楼层
为了照顾中国,德克萨斯的春天推迟了。
发表于 2012-6-6 22:20:32 | 显示全部楼层
楼主知道大概什么时候可以发布吗?
发表于 2012-6-6 23:08:53 | 显示全部楼层
我想知道的是什么时候能够发布
发表于 2012-6-7 06:56:34 | 显示全部楼层
logxu 发表于 2012-6-6 21:28
那其他机型的呢?一并推迟还是会先放出来?
发表于 2012-6-7 06:56:54 | 显示全部楼层
还是说根本就没有le.....
发表于 2012-6-7 10:50:56 | 显示全部楼层
Today, Wednesday, 6th, June 2012, TI updated its OS for the TI-Nspire series (CX or not and CAS or not), to version 3.2 (more precisely 3.2.0.1212).
However, we do not encourage -whoever has to take exams with calculators allowed to update yet, since :
- This OS, as we announced it months ago, comes with an additional protection that fixes the flaws used by Ndless 3.1. You then will NOT be able to use Ndless 3.1 on it (thus not all the programs that require it, especially mViewer for example). Ndless 3.2 will have to be needed, whenever it comes out (it may take months) (But you can donate to Extended ! :P) But apparently the downgrade protection only got set to 3.1.0 (and not 3.2.0 as expected), so you can go back to OS 3.1 and use Ndless without problem! You can no longer downgrade to 3.0.1 though.
- No independant tests have been made to see if there still are some bugs (or new ones), on different points like maths (CAS), or on a general usage level, or also on a deeper technical level (boot …) (We remember the OS 3.X which contained a bug causing some Nspires to become unusable....).
- It is possible that some documents created with OS 3.2 aren't fully compatible with previous OSes. This will especially be the case of scripts using the new functions of the 3.2 API.
This OS was quite expected, since TI improved the math features and the Lua scripting ones, and created quite some buzz around it. Some features of the OS 3.2 had been annouced duting the 2012 international "T3" conference in Chicago.
Few weeks ago, TI published a PDF showing its main new features, which we summarized in this topic
Here are some previews in images (some are animated) :
http://imgur.com/a/rIG8E
If you are not affected by the warnings above, or that you are willing to take some risks let us know what you think of this new OS. We can't recall enough the the use of TNOC, the for Clickpad and Touchpad models, who still have a boot2 which remained at 1.4, a version allowing users to keep some control of their machines. Works even after having updated to a "downgrade-protected" OS since DowngradeFix breaks it.
有的,版本和我手上的一致
 楼主| 发表于 2012-6-7 13:21:02 | 显示全部楼层
美国佬对中文版的支持不够快、不够好。5月底的时候见两个工程师,说还在测试。cx耗电量太大。OS3.2不知道会不会改善一下。增加的圆锥曲线功能比较鸡肋。个人认为cas功能确实强大。TI推出的产品线太多,不知道主推哪一款了。不过工程师说以后推出速度回较慢。话说那款cm-c小白是一款阉割版的cx-cas。
发表于 2012-6-7 14:10:58 | 显示全部楼层
已经刷了,很好用
触摸板这次有福了
发表于 2012-6-7 17:40:55 | 显示全部楼层
不知道这个项目究竟有多少个人在做
发表于 2012-6-11 00:48:06 | 显示全部楼层
LZ能不能公布一下LUA的培训资料?
发表于 2012-6-30 11:16:13 | 显示全部楼层
1# logxu 求问楼主参加的Lua培训是TI官方的?你是怎么知道有这样的活动的?
 楼主| 发表于 2012-7-1 13:16:14 | 显示全部楼层
 楼主| 发表于 2012-7-1 13:17:00 | 显示全部楼层
12# NspireMaster
TI公司邀请的。
GMT+8, 2025-1-22 18:57 , Processed in 0.079290 second(s), 22 queries .
