查看: 13041|回复: 31
[Nspire] OS 3.2!
发表于 2012-6-7 11:00:31 | 显示全部楼层 |阅读模式
终于来了……没说错,就是这个星期!
http://education.ti.com/downloads/files/ti-nspire/3.2/TI-NspireCXCAS-3.2.0.1212.tcc
http://education.ti.com/downloads/files/ti-nspire/3.2/TI-NspireCAS-3.2.0.1212.tnc
不过可能就是由于前面一个老师发帖说的原因,官网没有提供这个更新
连接来自omi
版本和我手上的te是一样的
想要的自己先更新吧
 楼主| 发表于 2012-6-7 11:02:25 | 显示全部楼层
day at 01:52:27 by Juju
Hi everyone,
Today, Wednesday, 6th, June 2012, TI updated its OS for the TI-Nspire series (CX or not and CAS or not), to version 3.2 (more precisely 3.2.0.1212).
However, we do not encourage -whoever has to take exams with calculators allowed to update yet, since :
- This OS, as we announced it months ago, comes with an additional protection that fixes the flaws used by Ndless 3.1. You then will NOT be able to use Ndless 3.1 on it (thus not all the programs that require it, especially mViewer for example). Ndless 3.2 will have to be needed, whenever it comes out (it may take months) (But you can donate to Extended ! ) But apparently the downgrade protection only got set to 3.1.0 (and not 3.2.0 as expected), so you can go back to OS 3.1 and use Ndless without problem! You can no longer downgrade to 3.0.1 though.
- No independant tests have been made to see if there still are some bugs (or new ones), on different points like maths (CAS), or on a general usage level, or also on a deeper technical level (boot …) (We remember the OS 3.X which contained a bug causing some Nspires to become unusable....).
- It is possible that some documents created with OS 3.2 aren't fully compatible with previous OSes. This will especially be the case of scripts using the new functions of the 3.2 API.
This OS was quite expected, since TI improved the math features and the Lua scripting ones, and created quite some buzz around it. Some features of the OS 3.2 had been annouced duting the 2012 international "T3" conference in Chicago.
Few weeks ago, TI published a PDF showing its main new features, which we summarized in this topic
Here are some previews in images (some are animated) :
http://imgur.com/a/rIG8E
If you are not affected by the warnings above, or that you are willing to take some risks let us know what you think of this new OS. We can't recall enough the the use of TNOC, the for Clickpad and Touchpad models, who still have a boot2 which remained at 1.4, a version allowing users to keep some control of their machines. Works even after having updated to a "downgrade-protected" OS since DowngradeFix breaks it.
(If you have any qyestion or a doubt, please reply in this topic)
发表于 2012-6-7 11:44:31 | 显示全部楼层
MS不是中文的....
 楼主| 发表于 2012-6-7 12:17:44 | 显示全部楼层
下载回来看了看,有中文
(我还没有刷,不确定)
发表于 2012-6-7 13:30:50 | 显示全部楼层
建议暂不升级,观望为妙。
 楼主| 发表于 2012-6-7 14:16:57 | 显示全部楼层
刷了,挺好的
字体有所改进,界面紧凑了
lua的错误提示也好一些了
触摸板更好用了
发表于 2012-6-7 14:42:19 | 显示全部楼层
终于等到了,升级要用模拟器吧,无法淡定了。赶回家刷机。
发表于 2012-6-7 15:14:35 | 显示全部楼层
迫不及待啊
 楼主| 发表于 2012-6-7 15:35:58 | 显示全部楼层
升级用link软件就可以,只要是能连接到计算器的都可以
另外,ndless尝试过了,不行的
发表于 2012-6-7 16:07:02 | 显示全部楼层
用TNOC去除boot2后刷机,感觉没有太大惊喜,平面几何作图增加了等式作图,分析中增加了对圆锥曲线的支持,3维作图增加了参数方程(其余暂时没发现有重大改变)。还有那个化学式,我没找到自动配平功能,而且貌似现在还很不完善,氢氧根的H它竟然是小写的... 就这样吧,个人觉得一般般...
发表于 2012-6-7 16:24:22 | 显示全部楼层
感觉字体不如以前好看,化学式怎么书写啊?
 楼主| 发表于 2012-6-7 16:46:54 | 显示全部楼层
本来就没有说有配平的……
一般般是表面的,lua变化很大
字体我觉得圆滑了一些
另外,界面紧凑了一些
触摸板好用很多
可能是cx上看的变化比较明显吧
发表于 2012-6-7 17:18:26 | 显示全部楼层
触控版是灵敏多了,化学式那个感觉没什么用,3d参数的话就可以画漂亮的图形了
 楼主| 发表于 2012-6-7 17:28:28 | 显示全部楼层
发现一个小bug
绘图时按菜单键打开的菜单那个“设定”写的是繁体的
发表于 2012-6-7 17:34:05 | 显示全部楼层
每个设定都是繁体。cx的参数绘图还是有参数范围限制,要手动调节,这个太不爽了。应该给ti反应一下
发表于 2012-6-7 17:37:16 | 显示全部楼层
不知道官方什么时候更新,会不会比这个版本更新
发表于 2012-6-7 21:39:39 | 显示全部楼层
貌似没有抗锯齿
发表于 2012-6-8 00:23:40 | 显示全部楼层
倒是多了些我想要的,教师版软件什么时候能发布呃,另外支持的LUA怎么用?
 楼主| 发表于 2012-6-8 00:44:57 | 显示全部楼层
Lua有一份文档,我暑假会进行翻译工作
不过原来的3.1的用法可以照抄,只需要在第一行代码加一句这个:
platform.apiLevel='1.0'
默认的api是2.0,和原来的有一些区别
另外,官方的文档里面有一些1.0的用法没有说,期末考试完了以后我会整理一份
先透露一个,也是我目前准备添加到LB的功能之一:
菜单功能,3.1就有,可以按菜单键弹出一个自定义菜单,写起来稍微有点麻烦,LB计划加入一个菜单编辑器来辅助工作
 楼主| 发表于 2012-6-8 00:51:55 | 显示全部楼层
模拟器里面会内置一个ide用来直接写代码,可以设置权限来进行代码的保护,包括一个密码。
LB II会在7月初发布(主要是添加对OS3.2的一些支持)
如果有人想参加LB内测请和我站内信联系,或者加我qq,注明是参加内测的(目前迟迟不放出主要是不太稳定还有一个就是内测人员太少,os3.2的发布也有一定原因)
GMT+8, 2025-1-22 21:47 , Processed in 0.053243 second(s), 23 queries .
