查看: 12661|回复: 24
[fx-CG10/20/50] CG模拟器和谐有苗头了?
发表于 2012-6-26 11:29:36 | 显示全部楼层 |阅读模式
比较一下9860模拟器和CG模拟器的dll文件(用dll文件编辑器)
发现CG的比9860多了一个叫“2”的项目,里面都有一个单词false
难道……
发表于 2012-6-26 19:07:29 | 显示全部楼层
已经用万能和谐工具的路过……
发表于 2012-6-27 16:09:24 | 显示全部楼层
用沙盘的飘过
 楼主| 发表于 2012-6-27 21:52:05 | 显示全部楼层
2# wtof1996 3# 936854586
真才实学!沙盘好像没用。
发表于 2012-6-28 07:31:42 | 显示全部楼层
没用就怪了,连TI-NSPIRE的那种加密都没用
发表于 2012-6-30 10:11:13 | 显示全部楼层
哪里有下载?我的早过期了。谢谢
发表于 2012-6-30 10:33:58 | 显示全部楼层
this topic look like to be interesting
can you explain in exglish? thanks
发表于 2012-6-30 14:36:36 | 显示全部楼层
7# helder7
Hi!
We are just talking about how to crack the CG10/20 emulator Trial limits.
发表于 2012-6-30 14:49:45 | 显示全部楼层
7# helder7
Hi!
wtof1996 发表于 2012-6-30 14:36
发表于 2012-6-30 17:18:30 | 显示全部楼层
Yes is possible without any hacking! I use a virtual machine and when the emulator expire in my pc, i install it in a vm in my computer, works 100%
According to my reshearchs in emulator, it Create a folder in appdata but is only for save the emulator data (installed files)... There are also 1 folder called sd card, maybe they will release a prizm sd in future
I think the trial expire checker is saved in 1 file in emulator programs directory or in regedit.exe
In the DLL files there are a reference to debug, i think the emulator have a hidden debug mode, but maybe is locked
发表于 2012-6-30 17:30:34 | 显示全部楼层
According to my reshearchs in emulator, it Create ...
helder7 发表于 2012-6-30 17:18
I use sandboxie.And I think that's so easy.
发表于 2012-6-30 18:11:54 | 显示全部楼层
imath 发表于 2012-6-30 17:30
问下,我下了你的iequation9放到公共库里,但用的时候提示“变量受保护”怎么回事?
发表于 2012-6-30 19:29:35 | 显示全部楼层
标题
12# helder7
We already have a unlimited 9860G II emulator. And it's seemed that they use the same shell,so maybe crack CG10/20 emulator is posible.
发表于 2012-6-30 19:38:45 | 显示全部楼层
一用英语,人气高涨啊。。
发表于 2012-6-30 20:27:41 | 显示全部楼层
16# wtof1996
I think it is possible.Why not to try same way to crack the fx-cg10/20,Lapras?
 楼主| 发表于 2012-6-30 20:35:37 | 显示全部楼层
12# helder7
I did found all the things named with "Casio","CG","emulator" inregedit.exe.
But no way worked...
 楼主| 发表于 2012-6-30 23:05:03 | 显示全部楼层
Even,when I modify the time in the taskbar,(with restart the computer),(modify the time that is not expired),the expire alert still on!(BIOS?)
发表于 2012-7-1 03:08:54 | 显示全部楼层
Some experience from TI:
Maybe the  emulator will check the date of some special files.So the trail limits  was still there.
发表于 2012-7-1 04:05:03 | 显示全部楼层
hello chinese guys, I've been investigating and i found the "license files", i think.
i tried delete it and my emulator return the license expired error, and generate others (maybe emulator use regedit.exe also to do some checks). if i put the original files, emulator works again!
this files are hidden (You must enable viewing hidden files in windows)
patch:
C:\ProgramData\CASIO\Manager PLUS Trial
for who have emulator expired:
download this files: http://www.crocko.com/D801D1C55F ... 41A83D7/casio-7.rar
and extract it (winrar) to C:\ProgramData\CASIO\Manager PLUS Trial
and then say the result obtained
i dont know if work, maybe emulator use this files + reg key in regedit.exe or some hardware id to verify a trial license
other interesting dicovers in my investigation (not related with "hacking")
emulator use this folder in APPdata:
C:\Users\HELDER\AppData\Roaming\CASIO\fx-CG10_20 Manager PLUS (90 Day Trial)\EmulatorData
in this directory there are 1 folder called Sd card
and in this files:
CG10M.dlp
CG10M.dlm there are references to sd card, maybe they will release 1 prizm sd in future
(you should replace HELDER by your windows username
Ps: i think in windows xp the patch is different)
this folder is to save emulator data only
i installed the emulator also in a virtual machine, and i save all changes in pc in a html file (regedit.exe, etc)
download: http://www.crocko.com/275EAEB2EA ... 24/file-helder7.rar
发表于 2012-7-1 21:27:04 | 显示全部楼层
desktop shortcut patch:
"C:\Program Files\CASIO\fx-CG10_20 Manager PLUS (90 Day Trial)\ManagerPLUS.exe" /n"fx-CG10_20 Manager PLUS (90 Day Trial)"
if you open in windows explorer the patch will be somewone like:
why in shortcut casio put
/n"fx-CG10_20 Manager PLUS (90 Day Trial)" ?
GMT+8, 2025-1-22 18:45 , Processed in 0.107608 second(s), 22 queries .
