查看: 7588|回复: 4
[Nspire] 新版Nspire CAS Clickpad拆解
发表于 2012-12-10 12:24:11 | 显示全部楼层 |阅读模式
这里拆的是我去年年底在美国亚马逊入手的美行全新Nspire CAS。和Datamath之前公布的拆机图相比,PCB设计上存在较大区别。此机采用了和Touchpad一样的TI-NS2007C主控芯片,PCB整体布局也和Touchpad差不多。图片为手机拍摄,画质比较一般,请大家见谅。
生产日期不详,不知从哪里可以看出?
Nspire CAS PCB背面
Nspire CAS PCB背面
Nspire CAS PCB正面
Nspire CAS PCB正面
显示板
显示板
FPC连接器特写
FPC连接器特写
键盘板
键盘板
发表于 2012-12-10 14:03:52 | 显示全部楼层
主要是电源部分简化了,提高了可靠性,新版的可靠性更好
发表于 2012-12-12 04:29:03 | 显示全部楼层
Very intereting find.
Maybe I have not understood everything, but do you have the back case with the serial number?
The production date and hardware revision is encoded with 6-7 characters on the right (the datestamp).
For exemple:
Datestamp here is P-0210A, meaning:
- factory code P
- february 2010
- hardware revision A
Could you give us the datestamp of your CAS?
It could help us very much.
Thanks.
 楼主| 发表于 2012-12-12 09:20:07 | 显示全部楼层
Maybe I have not understood everything, but do you have the back case with  ...
Hi Critor{:biggrin:} ,
Yes I do. The datestamp says "P-1009I". I applied some highlighter ink there to make it a little more visible in the photo.
Datastamp
Datastamp
Just in case the machine translation doesn't work that well, here goes the translation of my original post:
Shown in the above photos is an Nspire CAS Clickpad I purchased from Amazon US at around the same time last year. When disassembled, the PCB turned out to be quite different from what's given on Datamath; The marking on the chip reads "TI-NS2007C-1 CAS", and the layout closely resembles that of the Touchpad version. The photos were taken using my phone, and I apologise for their poor quality.
发表于 2013-5-17 08:51:44 | 显示全部楼层
按键是什么样的啊
GMT+8, 2025-1-23 04:41 , Processed in 0.058682 second(s), 21 queries .
