查看: 9876|回复: 8
[Nspire] Ndless CM - Ndless ported to the TI-Nspire CM !
发表于 2013-3-27 05:34:53 | 显示全部楼层 |阅读模式
The latest beta version (r685) of Ndless 3.1 was published last August, nearly 8 months ago. :'(
Until now, Ndless 3.1 handled the following Nspire models:
  • TI-Nspire & TI-Nspire CAS
  • TI-Nspire TouchPad & TI-Nspire CAS TouchPad
  • TI-Nspire CX & TI-Nspire CX CAS
  • TI-Nspire CX-C & TI-Nspire CX-C CAS
In other words, until now, the users of two Nspire models were unable to use Ndless: the chinese TI-Nspire CM:  :(
  • TI-Nspire CM-C
  • TI-Nspire CM-C CAS
Tonight, we're glad to release Ndless for the Nspire CM-C!
After the Nspire CAS+, Ndless has therefore been ported to all Nspire models! :)
In fact, this CM-C support was made months ago, and it was supposed to be integrated to Ndless. It didn't get done yet.
We think that the fact that Nspire CM-C users, who will soon be taking exams, have access to reduced functionality (even more so than by the mere fact of using an inferior model, that is), is no good, so we're releasing Ndless CM 3.1 as a fork of Ndless 3.1. We hope that the integration to the main Ndless can be done some day in one of the next updates if there are any.
Obviously, Ndless CM 3.1 requires using OS 3.1, as the vulnerabilities exploited to install Ndless have been simultaneously fixed in the OS 3.2 versions.
Ndless programs which are not defining their own syscalls in the source code should work directly without the need to be rebuilt.
The others will have to be adapted and rebuilt.
Note that the TI-Nspire CM-C CAS is not supported yet.
Source & download:
http://tiplanet.org/forum/viewtopic.php?t=11458&lang=en
参与人数 4金钱 +10 收起 理由
ExAcler + 2 Woooooooooo!!!
wtof1996 + 3 Nice !
ZephRay + 2 Great!
月与映之皮丘 + 3 love to see and hear
发表于 2013-3-27 14:16:16 | 显示全部楼层
Good!:)
发表于 2013-3-28 11:48:29 | 显示全部楼层
very good
发表于 2013-3-29 11:28:01 | 显示全部楼层
how to change TI Nspire into TI Nspire CAS
 楼主| 发表于 2013-3-29 19:00:22 | 显示全部楼层
emcc wrote: "how to change TI Nspire into TI Nspire CAS"
This is in no way related to Ndless CM.
Using nsNandMgr, you can change TI-Nspire ClickPad prototypes into TI-Nspire CAS.
Using nLaunch, you can run a CAS OS on TI-Nspire ClickPad/TouchPad.
But there is currently no way to do that on TI-Nspire CX/CM.
发表于 2013-4-4 17:06:19 | 显示全部楼层
Nice.But how to do for TI-Nspire CM-C CAS users?
 楼主| 发表于 2013-4-4 17:18:33 | 显示全部楼层
You can't for now... we'll have to update.
Finding and checking all required syscalls addresses takes time.
 楼主| 发表于 2013-5-8 21:38:39 | 显示全部楼层
TI-Nspire CM-C support has now been officially integrated into Ndless with the latest r786 build.
Together with it, support for TI-Nspire CM-C CAS has been developped and added.
It works on emulator and on TI-Nspire CM-C handhelds, but we have no TI-Nspire CM-C CAS handheld.
Could anybody here test and confirm us if it works or not?
Thanks.
Sources:
http://tiplanet.org/forum/viewtopic.php?f=43&t=11809
http://ndlessly.wordpress.com/2013/05/08/ndless-for-china/
Download:
http://tiplanet.org/forum/archives_voir.php?id=13849
http://www.unsads.com/projects/n ... /download/release/1
发表于 2013-5-8 22:22:47 | 显示全部楼层
真的?
GMT+8, 2025-1-31 07:14 , Processed in 0.078305 second(s), 24 queries .
