返回列表 发新帖
楼主: m16king
要是能解开异常模式该多好……
发表于 2009-8-2 20:31:03 | 显示全部楼层
我在这里发了。。。
http://www.casiocalc.org/?showforum=1
发表于 2009-8-2 21:01:45 | 显示全部楼层
发表于 2009-8-2 21:04:31 | 显示全部楼层
仔细看。。。其实没多少英文的。。。语法错误一大堆呢。。。让chsi来看看。。。修改一下。。。冲出亚洲!走向世界!打败卡西欧。。。。。。
发表于 2009-8-2 21:05:42 | 显示全部楼层
继续修改。。。
发表于 2009-8-2 21:07:38 | 显示全部楼层
版本1.3。。。
We found this way in 2009.1~2009.3
In fact, 82es ver b also can upgrade by change the hardware, but that's very difficult. Please look this: http://tieba.baidu.com/f?kz=600120646
I corrected some problems。。。
pol(1,1)=
six □|□ [turn left and see...I don't know its english name...] one x^□ [also i don't know...]
= left delete 1
the screen will display r=1.414213562,0=45
before the "r" input sqrt(Ans) =
ten Ans,two log■□
press three right
ten (
=right,left left left press seven“sin”
=right,left,press seven (
=left,press seven (
=left,press six (
=left,press six (
。。。。。。Repeat。。。。。。
until the screen become white (it means there is nothing on the screen...)
AC SHIFT+MODE+8+2【NORM】
SHIFT+MODE+2【Line IO】
MODE
SHIFT+MODE+↓+6+←←
发表于 2009-8-3 07:13:38 | 显示全部楼层
注意国外用的不是82es,而且ms也没有B版
发表于 2009-8-3 07:48:45 | 显示全部楼层
好像是83ES吧?
发表于 2009-8-3 08:05:27 | 显示全部楼层
国外有B版。。。大家搜索一下好了。。。搜英文82es upgrade to 991es ver b
发表于 2009-8-3 08:06:50 | 显示全部楼层
这个。。。某论坛里的。。。
Hey Everyone
Im pretty new to the forum.
I own a 82ES which i upgraded to the 991(without solar power) as described. However, a friend of mine bought an 82ES recently and when i opened it up, the circuitry inside seems to h** been changed since the early 82's. The jumpers P0-P7 isnt there anymore. Anyone know if its still possible to do the upgrade? I can post a pic if required.
If someone could maybe post a pic of a newer 991's PCB maybe?
Any help would be very much appreciated, since the 991 is difficult to find here.
Thanks for a great forum!!
Hendrik
发表于 2009-8-3 10:37:13 | 显示全部楼层
而且…国外某些大学甚至都禁止使用991……我在某论坛看到了……
发表于 2009-8-3 11:26:54 | 显示全部楼层
。。。。。。Repeat。。。。。。
"white" shouldn't be used here.
"until there is nothing on screen "is better.
发表于 2009-8-3 12:33:48 | 显示全部楼层
恩……我在1.3版的括号里写了……是觉得太Chinglish了……
发表于 2009-8-3 13:01:55 | 显示全部楼层
估计外国人都很有钱,直接买TI。。。
发表于 2009-8-4 20:36:05 | 显示全部楼层
还是从模拟器入手来的可行
真的有达人的话 逆向一下模拟器绝对没问题
因为那个模拟器用的是ROM+虚拟机 并不是自己重写的代码
所以逆向的话不但能爆出来ROM 还可以从根本弄明白内存是怎么溢出的
发表于 2009-8-7 12:46:28 | 显示全部楼层
这几天很忙,忙着做国庆节的东西,没看到
发表于 2009-8-7 12:47:44 | 显示全部楼层
还是从模拟器入手来的可行
h4x 发表于 2009-8-4 20:36
没准是移植以后给整个编译了了呢
发表于 2009-8-7 15:30:39 | 显示全部楼层
用od
GMT+8, 2025-1-23 01:01 , Processed in 0.060612 second(s), 16 queries .
