查看: 15141|回复: 22
[资源下载] 发一个特别适合程序员用的简约型RPN计算器软件BinCalc
发表于 2013-7-3 08:28:00 | 显示全部楼层 |阅读模式
有windows版本和plamOS版本
Megatops BinCalc Readme
Megatops BinCalc is a binary calculator for developers.
It is available on Windows(for desktop) and Palm OS(for
smart phone & handhelds).
Main Features:
* unique binary input method
* get bin/dec/hex input & display in one screen
* supports Intel/Freescale style bit numbering
  scheme (LSB 0 / MSB 0)
* signed/unsigned int 32 support (*)
* octal support (*)
* Unix file permission indicator (*)
* classic XYZT RPN calculator (*)
(*) Windows version only
Palm OS Version System Requirements:
Palm OS 4.0+ (OS 5 Compatible)
50KB Free Memory
160x160 (OS4) or 320x320 (OS5) screen
Compatible Devices:
PDA:   Palm m500/505/515, Tungsten T/T2/T3/T5/E/E2/TX,
       Zire 21/71/72
Phone: Treo 180/270/650/680/700p
*NOT* compatible with Treo 600, Zire 21/22/31!
Windows Version System Requirements:
Windows 2000/XP/2003
Differences between Windows & Palm OS Version:
        Palm OS Ver.      Windows Ver.
Mode    Chain(simple)     Reverse Polish Notation
Stack   N/A               4 (X,Y,Z,T)
Base    Bin/Dec/Hex       Bin/Oct/Dec/Hex
Func.   Bitwise           Arithmetic, Bitwise
Key-mappings in Windows Version:
Setting the base
Tab            Cycles the keyboard input focus
Ctrl + Tab     Same as Tab, but reversed the direction
Shift + Tab    Same as Ctrl + Tab
Ctrl + A       Set the keyboard focus to ASCII Char
Ctrl + B       Set the keyboard focus to binary
Ctrl + D       Set the keyboard focus to decimal
Ctrl + H       Set the keyboard focus to hexadecimal
Ctrl + I       Set the keyboard focus to IP address
Ctrl + O       Set the keyboard focus to octal
Entering the number
1234567890     (As is)
ABCDEF         (As is)
Ctrl + S       Toggle Signed/Unsigned
Enter          Enter
Backspace      Bsp (As is)
Esc            CLx (Clear X Register)
Ctrl + Bksp    CLR (Clear all registers)
Up Arrow       Stack up
Down Arrow     Stack down
Ctrl + C       Copy to clipboard (pure number)
Ctrl + X       Same as Ctrl + C
Ctrl + V       Paste from clipboard
Do calculation
+ - * / .      (As is)
Ctrl + -       +/- (2's)
<              Shl (Shift left)
>              Shr (Shift right)
~              Not
%              Mod
&              And
|              Or
^              Xor
Left Arrow     Shift left by 1
Right Arrow    Shift right by 1
Misc.
Ctrl + R       Toggle "Hex vps calculator
Ctrl + T       Toggle "Stay On Top"
BinCalc Windows Version History:
Mar 23, 2011. v1.0.4:
* Fixed binary string copy bug
Dec 21, 2008. v1.0.3:
* Added ASCII char copy & paste support
* More hotkeys supported:
  See Readme.txt for detailed key-mapping info.
Nov 12, 2008. v1.0.2:
* Minor bug fixed
Nov 8, 2008. v1.0.1:
* Shift left/right bug fixed:
  All shift operators are arithmetic now.
Aug 10, 2008. v1.0.0:
* Added IPv4 address support
* Added ASCII character input support
* Minor bugs fixed
Jun 28, 2008. v0.2g:
* Bit indicator tool-tips added 2^N value display
Dec 17, 2007. v0.2f:
* Minor bugs fixed
Nov 18, 2007. v0.2e:
* Added form position saving (supports multi-monitor)
* Added screen edge snapping
Nov 15, 2007. v0.2d:
* Added command line support (See CommandLine.txt)
* Added status save on close (in INI file)
Nov 8, 2007. v0.2c:
* Added keyboard support
* Fixed T register bug
Nov 6, 2007. v0.2b:
* Added octal support (UNIX file permission value
  friendly)
* Added separators in decimal display
* Added pop-up menu to switch bit label style
* Fixed some minor bugs
Feb 2, 2007. v0.1c:
* First version
BinCalc Palm OS Version History:
Dec 3, 2006. v0.1c:
* Minor bug fixed.
* Size reduced.
Apr 11, 2006. v0.1b:
* Added bit numbering style switch
  o Intel style: MSB was numbered as 31 and LSB was
    marked as 0
  o Freescale style: MSB was numbered as 0 and LSB
    was marked as 31
* Bit order reverse function was removed. (Useless)
Dec 27, 2005. v0.1a:
* Added bit order reverse. (MSB-LSB/LSB-MSB)
* Cut off ANSI display function. (Useless)
Dec 25, 2005. v0.1:
* First version, a Xmas gift :)
About BinCalc:
Megatops BinCalc Palm OS Version
(c)2005-2006 Ding Zhaojie
[email protected]
Megatops Software, P.R.China
Megatops BinCalc Windows Version
(c)2007-2011 Ding Zhaojie
[email protected]
发表于 2013-7-3 16:48:00 | 显示全部楼层
回帖奖励 +1 金钱
无耻要奖励
发表于 2013-7-3 18:01:28 | 显示全部楼层
回帖奖励 +1 金钱
看看
发表于 2013-7-3 18:42:24 | 显示全部楼层
回帖奖励 +1 金钱
就是来看看的
发表于 2013-7-3 19:06:23 | 显示全部楼层
回帖奖励 +1 金钱
我也看看
发表于 2013-7-4 11:14:44 | 显示全部楼层
回帖奖励 +1 金钱
那我也看看。
发表于 2013-7-4 15:45:22 | 显示全部楼层
回帖奖励 +1 金钱
我也来。
发表于 2013-7-4 18:10:11 | 显示全部楼层
回帖奖励 +1 金钱
我也是来看看的
发表于 2013-7-4 19:52:36 | 显示全部楼层
回帖奖励 +1 金钱
Have a look...
发表于 2013-7-5 09:31:13 | 显示全部楼层
回帖奖励 +1 金钱
\Palm OS/
发表于 2013-8-25 02:50:26 | 显示全部楼层
回帖奖励 +1 金钱
来看看的
发表于 2013-8-25 09:14:36 | 显示全部楼层
回帖奖励 +1 金钱
咸丰县的
发表于 2013-8-25 14:13:33 | 显示全部楼层
回帖奖励 +1 金钱
那我也看看吧
发表于 2013-8-26 08:01:59 | 显示全部楼层
回帖奖励 +1 金钱
很久以前的软件啦,全英文,有些不适应
发表于 2013-10-27 13:34:28 | 显示全部楼层
回帖奖励 +1 金钱
PalmOS。。。都快被淡忘了吧。。。
发表于 2013-10-27 18:06:31 | 显示全部楼层
回帖奖励 +1 金钱
看看…………………………{:029:}
发表于 2014-8-7 14:37:48 | 显示全部楼层
回帖奖励 +1 金钱
我也看看,謝了
发表于 2014-8-13 09:44:05 | 显示全部楼层
回帖奖励 +1 金钱
我也是来看看的
发表于 2014-8-13 13:00:25 | 显示全部楼层
回帖奖励 +1 金钱
捞捞捞
发表于 2014-8-14 13:58:03 | 显示全部楼层
回帖奖励 +1 金钱
来看看
GMT+8, 2025-2-5 21:01 , Processed in 0.061638 second(s), 19 queries .
