查看: 5604|回复: 6
[Nspire] OS 3.3 available for the TI-Nspire CX CAS
发表于 2013-8-5 07:30:59 | 显示全部楼层 |阅读模式
In a previous TI-Planet news, we announced the release in Saudi Arabia of the 3.3 version of TI-Nspire system. This version added a 16th supported language, Arabic. But note that this addition was undoubtedly much more complicated than the Chinese one in 3.0 versions, since to respect the Arab writing from right to left, all the TI-Nspire interface was reversed horizontally:
However, we never could get our hands on this OS up to now. Indeed, it hasn't been released through TI's servers, but only through its school distributor network in Saudi Arabia.
However this evening, a TI-Planet member did finally send it to us for the TI-Nspire CX CAS! ;)
Note that in order to be able to set their calculator into arabic langage, TI-Nspire CX-C owners will first have to unlock their region code using nsNandMgr, or they'll still be presented the usual four languages after the update instead of the 16 ones.
The complete version number is 3.3.0.538.
Unlike OS 3.2.4, this OS still have the Boot2 3.1.0.16 and so doesn't prevent Nlaunch installation if you still haven't installed OS 3.2.4 with its Boot2 3.2.4.7! {:thumbsup:}
However OS 3.3.0.538 installation raises the minimum version of installable OS on the calculator to 3.2.0.1229. Officially, following its installation, it becomes impossible to return to the OS 3.1 and use Ndless. But in practice, you just have to use Nlaunch which just ignores the minimal version. If needed, Ndless utility nsNandMgr then allows you to reset the minimal version and to put back your calculator in the same state it was in before installing this 3.3 OS. :)
(menu 5 "Boot Data" puis options 4 ou 5)
Source & Download:
http://tiplanet.org/forum/viewtopic.php?t=12788&lang=en
发表于 2013-8-5 07:55:08 | 显示全部楼层
It 's a really exciting news. I want to know that is there any improvements(such as bugs in OS3.2) in the new OS?
发表于 2013-8-5 16:55:22 | 显示全部楼层
Good!now we may able back to 3.1 if we got OS 3.3 install files.
Sorry for my english and thanks to google translate.
发表于 2013-8-5 17:39:25 来自手机 | 显示全部楼层
好像仅仅是加入了阿拉伯语的支持
发表于 2013-8-5 23:50:19 | 显示全部楼层
Sorry for my english and thanks  ...
Well, you are supposed to say  ... we may BE able TO back to ... we GET ... INSTALLATION ...  instead.
发表于 2013-8-6 04:11:59 来自手机 | 显示全部楼层
yzskyt 发表于 2013-8-5 23:50
Well, you are supposed to say  ... we may BE able TO back to ... we GET ... INSTALLATION ...  inst ...
oh...thanks..........................
发表于 2013-8-6 06:54:56 | 显示全部楼层
似乎不是官方提供的更新下载?!
GMT+8, 2024-12-27 00:11 , Processed in 0.086467 second(s), 25 queries .
