查看: 2349|回复: 2
[Nspire] OS3.1下打开lua文档数据都是乱的?
发表于 2013-8-8 13:22:33 来自手机 | 显示全部楼层 |阅读模式
用nLaunch装的3.1,同样的lua文档打开后,变量的值都是乱的,在3.2中都是正常的,求解释
发表于 2013-8-8 13:33:45 来自手机 | 显示全部楼层
变量那个是有这种bug
是OS本身问题
发表于 2013-8-9 08:12:25 | 显示全部楼层
The problem is apparently due to Ndless/nLaunch (I don't rememebr which, but I've heard that before on Omnimaga). I don't remember if a solution had been found, I'll check later.
GMT+8, 2025-1-23 08:00 , Processed in 0.059326 second(s), 18 queries .
