查看: 16815|回复: 13
HP Prime拆解与硬件配置
发表于 2013-8-9 19:25:48 | 显示全部楼层 |阅读模式
与卡西欧fx-CP400不同,HP Prime非常好拆。
简述一下配置:
屏幕:3.5寸彩色TFT电容多点触屏,320*240 (QVGA) 114ppi 65000色(16bit) (对比卡西欧CP400,4.8寸320*528 128ppi)
CPU (U101): 三星ARM9 S3C2416XH-40 频率266/400MHz
内存(U200): Hynix H5MS2562NFR 32MB DDR400 SDRAM
闪存(U201): 三星 K9F2G08U0C-SCB0 - 256 MB
电池 : 3.7V锂离子1500 mAh (5.55Wh), 制造商:深圳市慧通天下股份有限公司
原作者:Adriweb
Source:  http://tiplanet.org/forum/viewtopic.php?t=12821&p=146687#p146687&utm_source=twitterfeed&utm_medium=facebook
发表于 2013-8-9 19:28:39 | 显示全部楼层
软件的bug实在太多。。
发表于 2013-8-9 19:34:02 | 显示全部楼层
这个硬件几乎是目前最强的了吧……
发表于 2013-8-9 20:21:29 | 显示全部楼层
Complete article :)
Hi everyone,
Unlike the fx-CP400 which gave us a hard time (easy when you know the trick... ;) ), the HP Prime opens quite "easily" and reveals us its hardware:
We notice the references which were already at the back of our prototype: EA656MB for the motherboard and EA656KB for the keyboard and power board.
They include:
  • Touch Color Display 3.5" diagonal with a resolution of 320x240px
  • Processor (U101): Samsung S3C2416XH-40 - ARM9 clocked at 400 MHz maximum.
  • RAM Memory (U200): Hynix H5MS2562NFR - 32 MB
  • Flash Memory (U201): Samsung K9F2G08U0C-SCB0 - 256 MB
  • Battery: Li-Ion 3.7V, 1500 mAh (5.55Wh)
In short, a fairly standard and simple architecture around three main distinct chips: RAM/ROM CPU.
Let’s now look at the details ;)
Processor :
  • Architecture : ARM (ARM9 ; 32 bit)
  • Core : ARM926EJ-S
  • Manufacturer  : Samsung
  • Reference : S3C2416
  • Specs : 16KB I-cache; 16KB D-cache/MMU
  • Frequency : 2 Modes : 266 MHz and 400 MHz
  • Note : Features 2D Acceleration
  • Official "Product Brief" (PDF)
RAM Memory :
  • Type : DDR SDRAM
  • Manufacturer  : Hynix
  • Reference : H5MS2562NFR E3M
  • Capacity : 32 MB (256Mb (x16 device) = 4M x 4Bank x 16 I/O)
  • Manufacturer  Page officielle
  • Datasheet (Closest JFR MBdel)
Flash Memory :
  • Type : Flash NAND
  • Reference : K9F2G08U0C SCB0
  • Capacity : 256 MB (2 Gb)
  • Datasheet
Screen :
  • Type : TFT
  • Manufacturer  : ?
  • Reference : ?
  • Dimensions : 3.5" (8,9 cm)
  • Resolution : 320×240 px
  • Pixel density : 114 ppi
  • Color : Yes , 16-bit;
  • Other : Capacitive multi-touch layer
Battery :
  • Type : Rechargeable Battery
  • Technology: Lithium-Ion
  • Manufacturer : WiseWod Tehnology Co.
  • Reference : 484461AR
  • IEC 61960 Number : 1ICP6/51/63
  • Dimensions : 4.8 * 43.8 * 61 mm
  • Nominal voltage  : 3.7 V
  • Max. capacity : 1500 mAh
  • Energy: 5.55 Wh
  • Impedance : <= 60 mΩ
In short, only documented and standard chips instead of proprietary ones or hidden in an ASIC, which is a nice change from the TI-Nspire or even more from the fx-CP400 :)
This calculator is positioning itself as a potential competitor to the TI-Nspire CX, as we wrote in our hands-on review  and the hardware confirms this idea, despite a slight weakness in the RAM amount.
In fact, some people already think of a Prime emulator on the Nspire and a Nspire one on the Prime, given the similar architecture! (But first, the machine will have to be open to native development ;) )
You can also compare the technical specs of the CX and the Prime with our comparator :
http://tiplanet.org/forum/compare.php?nspirecxcas,prime
See you later :)
Source : http://tiplanet.org/forum/viewtopic.php?f=55&t=12821&lang=en
发表于 2013-8-9 21:09:17 | 显示全部楼层
CPU不错,没有SDK真是可惜了
发表于 2013-8-9 21:11:08 来自手机 | 显示全部楼层
上市后第一时间收一个!
发表于 2013-8-9 21:17:49 来自手机 | 显示全部楼层
imath 发表于 2013-8-9 19:28
软件的bug实在太多。。
试试正式版模拟器啊
发表于 2013-8-9 22:51:18 | 显示全部楼层
查了一下处理器的资料,结合硬件配置,跑塞班应该不成问题
http://www.arm.com/zh/products/processors/classic/arm9/arm926.php
发表于 2013-8-9 23:42:30 | 显示全部楼层
http://www.arm.com/zh/products/processor ...
运行塞班有何意义,况且塞班又不是开放的平台,移植不大可能吧
发表于 2013-8-10 15:24:58 来自手机 | 显示全部楼层
软件的bug实在太多。。
我也觉得
发表于 2013-8-10 17:31:03 | 显示全部楼层
320x240略弱
既然3.5吋不如直接用iPhone3Gs的480x320显示屏
好歹强一点
发表于 2013-8-10 21:05:20 | 显示全部楼层
要是能刷nSpire的系统还不错
发表于 2013-8-11 11:21:48 | 显示全部楼层
如果能找到JTAG测试点的话,在上面刷个WinCE不是问题,我玩过S3C2416。
顺便提下,S3C2416有两个版本,一个400MHz的,一个533MHz的,实测400MHz的超533MHz很简单很稳定。
发表于 2013-8-20 14:46:29 | 显示全部楼层
顺便提下,S3C2416有两个版本,一个 ...
膜拜你
GMT+8, 2025-1-22 17:52 , Processed in 0.066281 second(s), 21 queries .
