返回列表 发新帖回复
楼主: freedom
多图,爪机党慎入-hp prime真机八皇后测试
发表于 2013-8-17 22:21:59 | 显示全部楼层
92很好啊,我长期用92,舒服。而且在某些方面可以秒杀nspire。不过92洋垃圾确实百元左右就差不多了
 楼主| 发表于 2013-8-17 22:40:09 | 显示全部楼层
感觉92的键盘效率比prime高,要是按键再大一点就更好用了
发表于 2013-8-18 10:42:17 | 显示全部楼层
You can also use the function (undocumented) "TICKS()" at the start and one at the end, and substract, to see how many it took.
Then, convert to time, when you have done a precise timing of a certain known amount of ticks.
(that is, if the HP Basic doesn't have already some time functions to measure it directly.... On the Nspire, the Lua has that, but not the basic...)
 楼主| 发表于 2013-8-18 21:04:37 | 显示全部楼层
adriweb 发表于 2013-8-18 10:42
You can also use the function (undocumented) "TICKS()" at the start and one at the end, and substrac ...
thanks a lot.I will try.
发表于 2019-11-5 08:58:31 来自手机 | 显示全部楼层
挖下坟,这个输出的结果是92还是其它?
发表于 2019-12-20 12:32:10 | 显示全部楼层
用ticks()
GMT+8, 2025-1-22 17:03 , Processed in 0.051878 second(s), 17 queries .
