楼主: frustreated
[Nspire] nspire 2.0.0.851系统升级失败
 楼主| 发表于 2013-8-18 18:58:34 | 显示全部楼层
critor 发表于 2013-8-18 18:30
Hi,
The Boot1 and Boot2 might be using the development RSA keys instead of the production ones, a ...
and i have read the current research about the pro-type calculator .
the method to lower the current system is as downward
i download the current edition
TI-NspireCXCAS-3.2.3.1233.tcc
and change its name to TI-NspireCXCAS-3.2.3.1233.tnc
then it allow me to refresh this rom
but it will cast an error
and then i can refresh it to 3.1 edition
i think may be when the newest edition rom first thing is going to wipe all data,and when it is almost finished ,it will going to write the protect code to the machine.
so it is this.
i have not try this:
whether i can use the 3.1 edition rom  name
3.1***.tcc
and change it to 3.1***.tnc
and then i can refresh my machine to 2.0 rom
because i have a rom (i think it is the pro-type rom,because the interface is almost same to my fist rom when i bought)
发表于 2013-8-18 19:06:26 来自手机 | 显示全部楼层
the method to lower the curr ...
你的英文水平实在拙计。。edition应该是version,pro-type应该是prototype。。。不过,请不要乱刷系统!!!nspire的保护措施也不是随便能和谐的。
发表于 2013-8-18 19:10:37 来自手机 | 显示全部楼层
首先,tcc是给CX CAS用的系统,tnc是给TP/CP CAS用的系统。
其次,你似乎没有备份任何2.0.0.8xx的系统,而网上能下载到的是2.0.0.11xx的系统,界面相似是没有用的。
 楼主| 发表于 2013-8-18 19:13:21 | 显示全部楼层
nbzwt 发表于 2013-8-18 19:06
你的英文水平实在拙计。。edition应该是version,pro-type应该是prototype。。。不过,请不要乱刷系统!! ...
嘿嘿,随便回复下而以。我单词一般,gre也背过,只会读点,写起来真的是很菜
不过至少我发现了一种把现在最新的系统降级到3.1.0.392的方法了吧,嘿嘿
不知道非工程机是不是也可以成功。不敢实验的就别走这条路了哦。
反正我的机器试验成功了
嘿嘿~
发表于 2013-8-18 19:13:44 | 显示全部楼层
So if it didn't work, I suppose your calculator is currently without any Operating System?
If that's the case, try to install the 1.4 development OS (it's the highest version I have for TI-Nspire CAS prototypes).
http://tiplanet.org/forum/archives_voir.php?id=8751
发表于 2013-8-18 19:17:25 | 显示全部楼层
If that' ...
He has successfully installed OS 3.1.0.392
发表于 2013-8-18 19:18:42 | 显示全部楼层
不过至少我发现了一种把现在 ...
高端方法,不知道3.2.4行不行,嘿嘿。
表示正在着手开发keypad修改工具
 楼主| 发表于 2013-8-18 19:24:19 | 显示全部楼层
If that' ...
i have a rom ,its interface is same  to the interface when i first get this machine.
if you need ,i can post it to you.
some one say it is the 2.0 edition.
i don't know whether it is true or ……
3q!
发表于 2013-8-18 19:27:10 | 显示全部楼层
if you need  ...
能不能把你的那个rom发我看看?
如果是一开始的那个界面,确实是2.0的。但是我不确定你手上的ROM是开发版的还是正式版的,如果是正式版,*可能*还是没有用。
 楼主| 发表于 2013-8-18 19:31:07 | 显示全部楼层
nbzwt 发表于 2013-8-18 19:27
能不能把你的那个rom发我看看?
如果是一开始的那个界面,确实是2.0的。但是我不确定你手上的ROM是开发版 ...
就论坛里面他们上传的一个,貌似主题是什么什么新的rom或者新的系统
我一看界面和我拿到的系统一样
你看看能找到不,找不到我发给你
发表于 2013-8-18 19:34:20 | 显示全部楼层
我一看界面和我拿到的系统一样
你看 ...
那就不用了,在tiplanet上能下载到所有版本的os。
界面一样没用的,2.0系统都是这个样子。你的版本是2.0.0.851,是早于正式版本的,是个开发版本,能下载到的都是正式版本。当然如果你不介意,可以降级2.0普通版试试。如果你还能联系上那个卖家,他不是说还有台坏了吗,卖给我,我可能可以把里面系统提取出来。
发表于 2013-8-18 19:37:59 | 显示全部楼层
我一看界面和我拿到的系统一样
你看 ...
如果你要降级系统,我写过降级工具:http://www.cncalc.org/thread-9236-1-1.html,需要OS3.1+Ndless才能运行。你的按键不是不能用吗,放到ndless/startup里面,这样就会开机自启动,然后重启,降级工具应该会自动执行,执行完按任意键退出,这时已经可以用联机软件降级系统了!
 楼主| 发表于 2013-8-18 19:38:32 | 显示全部楼层
界面一样没用的,2.0系统都是这个样子。你的版本是2.0 ...
嘿嘿
那太好啦!
我把卖家的地址发给你不就得了
而且他有clic版本的,估计都是工程版
你提取出来了,给我发个系统呗,我也可以让自己的机器运行起来
我专业是土木,在这方面实在是不专业……
嘿嘿
发表于 2013-8-18 19:40:54 | 显示全部楼层
frustreated 发表于 2013-8-18 19:38
嘿嘿
那太好啦!
我把卖家的地址发给你不就得了
地址pm给我吧,不过我是高中生,很快要开学了,所以可能你得等一段时间了{:sad:}
 楼主| 发表于 2013-8-18 20:10:13 | 显示全部楼层
嘿嘿
我毕业了。我研究生。
好好加油哈
没事儿,我等等的。我现在刷成3.1了,在找咋样能降成那个老外给的1.4呢
不知道你知道不……
谢谢啦,我慢慢等得,也等等你滴那个改键盘顺序的,谢谢哈!!
http://trade.taobao.com/trade/de ... eID=401170502727691
刚刚去吃饭,所以现在才给你发这个链接。{:grin:}
发表于 2013-8-18 20:14:41 | 显示全部楼层
Sorry, I had answered without noticing there was a 2nd page.
发表于 2013-8-18 20:58:34 | 显示全部楼层
OK, now, the only problem is the keypad.
Though the touchpad has been installed, but the OS thought it was a Clickpad, so keys were missed up.
Is there any way to change keyboard type?
发表于 2013-8-18 22:30:42 | 显示全部楼层
Could you check your diagnostics software version?
Esc+Menu+G + reset.
发表于 2013-8-18 23:23:17 来自手机 | 显示全部楼层
frustreated 发表于 2013-8-18 18:58 and i have read the current research about the pro-type calculator . the method to lower the curr ...
烦请您注意大小写,标点符号,动词时态,单词用法…让国外网友看了…
 楼主| 发表于 2013-8-18 23:29:57 | 显示全部楼层
嘿嘿
没事儿,老外一看便知……
{:grin:}
我暂时只能这样儿了
不过也谢谢你滴建议,确实应该提高……
GMT+8, 2025-1-23 07:54 , Processed in 0.105534 second(s), 17 queries .
