查看: 5031|回复: 8
[Nspire] 【求助】TI-nspire cx cas 3.2.2.1231 可以降级吗?
发表于 2013-8-18 21:28:41 | 显示全部楼层 |阅读模式
听说3.2 的部分版本加入了防降级,这个版本是预装的,我想降到os3.1,刷ndless。
顺便问一下怎么ndless刷啊,刷了ndless能干什么,能用C语言吗?
发表于 2013-8-18 21:29:43 | 显示全部楼层
关于ndless作用,请参考置顶帖。3.2.2降级应该是可行的,直接刷入3.1.0.392系统即可。
 楼主| 发表于 2013-8-18 22:07:52 | 显示全部楼层
哪个贴?置顶的太多了。
发表于 2013-8-18 23:16:22 来自手机 | 显示全部楼层
…别管这么多,直接刷
发表于 2013-8-19 07:32:03 | 显示全部楼层
Hi,
No problem with OS 3.2.2.
According to the TI-Planet wiki, it will let you install any OS version 3.1.0.392 or above.
http://wiki.tiplanet.org/Versions_Nspire#Les_OS_TI-Nspire_CX:
So you'll be able to downgrade to OS 3.1.0.392 and install Ndless! {:thumbsup:}
But may I ask something before you do that?
The 3.2.2 OS has never been released on TI website and only comes preflashed on some Nspire models.
So it's quite rare and has never been dumped to a computer file.
Before installing OS 3.1 and so overwriting your 3.2.2 copy, could you please try to generate such a file? You've got a program linked for that purpose there:
http://www.omnimaga.org/index.php?topic=16422.msg295920#msg295920
This would benefit the whole TI community.
Thanks for reading.
发表于 2013-8-19 07:45:51 | 显示全部楼层
怕你看不懂楼上的英文,我简单翻译下。
首先不要刷掉你现有的3.2.2 OS!
先把现有的OS保存下来!(保存工具我等会去编译下)
保存好之后,直接用Link软件刷3.1.0.392吧,wiki里写着是没问题的。
 楼主| 发表于 2013-8-19 08:01:35 | 显示全部楼层
好吧,在我看到5、6楼之前已经被我刷掉了.......................
发表于 2013-8-19 11:22:01 来自手机 | 显示全部楼层
目前除了世界上某些特殊地区外,尚无3.2.3系统报告,所以都是可以降级的
发表于 2013-8-19 11:28:00 | 显示全部楼层
好吧……
GMT+8, 2025-1-23 08:08 , Processed in 0.047778 second(s), 18 queries .
