查看: 2757|回复: 1
[Nspire] nover3的正确用法
发表于 2013-8-26 18:06:10 | 显示全部楼层 |阅读模式
CX CAS本想发个帖子问问nover到底能超频超到多少
自己先试了试
结果玩脱了
第一项满,第二项一半,第三项四分之一
当时我就觉得不妥,想改回来
刚打开我的文档,就重启了
结果进度条到一半时显示System Error
急救模式删OS时显示System Error,那个进度条却一直往前
没办法忍痛全删,到了安OS的时候了
估计和这个帖子差不多http://www.cncalc.org/forum.php?mod=viewthread&tid=8956
不过他是nover3发布以前写的
那么就回到帖子的开头吧,发个帖子问问nover到底能超频超到多少?LZ重新弄机器去了
Eng
Calculator Model:CX CAS
I wanted to ask how much can nover3 boost my calculator
so I had a try myself just now
As a result I played myself
with 1st row full , 2nd row half ,3rd row a quarter
then I felt something would be wrong and wanted to undo
but just i open "My Documents",it restarted
and the progress bar went half and displayed "System Error"
so I went to recovery mode (DOC + ENTER +EE) and failed to  tried to delete os
now I format my calc,and i am installing os
i think my situation is similar to http://www.cncalc.org/forum.php?mod=viewthread&tid=8956
but his is not nover3 according to time
be back to this this subject's title ,how much can nover3 boost my calculator,I am going to deal with calculator
发表于 2013-8-27 00:32:39 | 显示全部楼层
System errors on startup are quite rare.
If you got one some time after installing Nover 3, then your setup was probably a little instable.
Did you try the Nover 3 automatic installation?
- just remove the nover.cfg file if present
- send Nover 3 to your /ndless/startup folder
- reboot the calculator
Nover 3 will then automatically look for your calculator best stable config and freeze at least 2 times - just reboot the calculator when this happens.
Nover 3 usually sets both base and cpu frequencies to something between 210 and 260MHz - this depends on the calculator hardware.
If you did use the automatic setup last time, then run Nover after the setup, lower the frequency by one step and save it.
GMT+8, 2025-1-23 07:59 , Processed in 0.047959 second(s), 18 queries .
